Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Accessories & Misc
Old 10-16-2007, 05:17 PM   #1
GST Motorsports
Vendor
Vendor Sales Rating: (8)
Member#: 130434
Default New Product AMS WRX/STI small battery kit
AMS introduces the Subaru STI/WRX Small battery tray
This very easy to install piece will allow you to remove you heavy stock battery and mount a lightweight race
battery on its side to not only lower the overall weight of the car but also lower the center of gravity. The motor is
flat, why shouldn’t the battery be!
This easy to install piece bolts right into the engine bay using all the factory mounting points.
Like all AMS products this piece is assembled using only high quality material.
The kit includes:
- AMS Anodized Aluminum Battery Tie down plate
- Zinc plated Tie down hooks to prevent rusting over time
- Nylon washers to keep the hardware from scratching the anodized aluminum tie down plate
- A Durable non slip battery pad to keep the battery in place and protected
- Wing nuts for an easy install and removal
- Adjustable for use with almost all small batteries
Pricing is $32.50 shipped.
If you would like a small battery as well with terminals please add $119.95.
GST Motorsports is offline   Reply With Quote
Old 11-05-2007, 10:44 PM   #2
subywantobe
Member#: 57509
2004 WRX STI
Plat. Silver
Looks sweet! I assume the ground wire (-) had to be relocated....?
subywantobe is offline   Reply With Quote
Old 06-03-2010, 02:26 PM   #3
saintseiyaz
Member Sales Rating: (4)
Member#: 81159
2000 GC8
PRB
can you do $155 shipped to 94111?
saintseiyaz is offline   Reply With Quote
Old 07-03-2010, 11:03 AM   #4
jsnm
Member Sales Rating: (33)
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
where and how can i order the tray and battery kit?
jsnm is offline   Reply With Quote
Old 07-04-2010, 11:23 PM   #5
ZERO260NOW
Member#: 140981
ohh5 STi
it's blue damnit!!
http://www.amsperformance.com/cart/home.php?cat=1895
ZERO260NOW is offline   Reply With Quote
Old 08-06-2010, 10:50 PM   #6
em99sport
Member Sales Rating: (3)
Member#: 172670
2011 STI 5-door
I installed this kit on my car today, so I can confirm that the ground doesn't necessarily have to be moved. If you orient the battery with the posts facing the firewall (toward the passengers), you can simply route the positive cable between the main wiring harness and connect the negative directly without re-routing the ground wire.
FYI, the install IS a pain, and it does take way longer than you'd think a battery install would take.
em99sport is offline   Reply With Quote
Old 04-12-2012, 03:15 PM   #7
sackytar
Member Sales Rating: (45)
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
Cant be that hard
sackytar is offline   Reply With Quote
NEW Product Release: AMS WRX/STI Small Battery kit - $29.95! AMS Accessories & Misc 25 05-20-2012 10:17 PM
**Product Release**AMS 08+ Subaru STI/WRX Small Battery Kit AMS Engine/Power/Exhaust 1 11-24-2009 05:36 PM
AMS WRX/STI Lightweight Battery and Install Kit blitzmr2 Suspension/Brakes/Handling 9 03-30-2009 11:06 PM
AMS Small Battery kit requires extension of ground wire? blitzmr2 Brakes, Steering & Suspension 18 03-19-2009 09:06 AM
NEW Product Release: AMS WRX/STI Small Battery kit - $29.95! AMS MWSOC Vendor Classifieds 12 10-24-2007 07:56 AM
