Old 10-17-2007, 12:39 AM   #1
StretchSTI
Member#: 148656
2007 STI
Default How To: DIY Radiator Cooling Panel
I got bored the other day and started to make a template for a cooling panel and it turned into a nice little project so i thought i would do a little DIY
Parts:
-Poster Board
-Sheet Metal
Tools:
-10mm and 12mm Socket
-Screwdriver
-Scissors
-Pencil
-Ruler or Straight Edge
-Dremel w/ cutoff wheel and grinder
-Drill w/ bits
-Hammer (optional)
Time:
-1.5-3 Hours
Heres what you start with
First, start by taking the Intake ram, Radiator mounts
Take the pop rivets out by first popping the head up and then grab the base and lift up. should come out easy.
Then make a template
-Cut out the general shape
-then go through and cut out the areas for the screws and radiator mounts.
-Lot of trial and error in this step
Once you have a template, Transfer it to a piece of sheet metal and cut the metal
-Mines a little thick, it doesnt need to be very thick
After you have your panel cut you can start to test fit
-grind with the dremel if you need to open your hole some.
-Bend the front a little to match the contours of the bumper
Once you are satisfied with the panel you can paint it or clear coat it to keep it from rusting
Heres my end result compared to my template.
Insert the pop rivets. push on the base to get it in the hole, then pop the head down
Install radiator mounts and intake ram
Here it is on the car
StretchSTI is offline   Reply With Quote
Old 10-17-2007, 12:43 AM   #2
Pssshhhhh!
Member#: 125871
Nice job!
Pssshhhhh! is offline   Reply With Quote
Old 10-17-2007, 12:45 AM   #3
StretchSTI
Member#: 148656
2007 STI
thanks... ill have it clear coated and final install tomorrow... will have better non- dead of night pics...
Old 10-17-2007, 12:47 AM   #4
Dforce
Member#: 93435
2008 STi DGM
+1 Berk Technology!
Where did you buy the sheet metal? and how much?
Dforce is offline   Reply With Quote
Old 10-17-2007, 12:53 AM   #5
SIBzzz
Member#: 129888
Liquid Copper
o man i was lookin for one of these. Great job bro
SIBzzz is offline   Reply With Quote
Old 10-17-2007, 02:03 AM   #6
Remnex
Member#: 83790
Nicely done my good sir.
Remnex is offline   Reply With Quote
Old 10-17-2007, 08:48 AM   #7
Schnitz
Member#: 119499
2006 STI
Looks great! Can you put the template into a PDF file so we can use it too?
Schnitz is offline   Reply With Quote
Old 10-17-2007, 09:01 AM   #8
bthomas
Member#: 50004
02 wrb
Great idea. Great job. DIY FTW
bthomas is offline   Reply With Quote
Old 10-17-2007, 09:01 AM   #9
YCT
Member#: 122167
2008 Mazda CX-9 GT
Liquid Platinum Metallic
^^ word, you did all the measuring for us, might as well share it hehe
YCT is offline   Reply With Quote
Old 10-17-2007, 11:47 AM   #10
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
I was just thinking that as well!
STiShawn is offline   Reply With Quote
Old 10-17-2007, 11:50 AM   #11
Uber Wagon
Member#: 39600
2008 STi
Dark Grey Metallic
I did the same thing a while ago. Mine looks almost identical. Great job!
Uber Wagon is offline   Reply With Quote
Old 10-17-2007, 12:15 PM   #12
PSI_XTC
Member#: 123386
'12 IS-F
'08 Saab 9-3 TurboX
Hellooo project for this weekend.
PSI_XTC is offline   Reply With Quote
Old 10-17-2007, 12:28 PM   #13
StretchSTI
Member#: 148656
2007 STI
You lazy bastards... haha i would ask the same thing.
when i got some time ill do all the measurements and lay it out on the computer.
there wasnt too much measuring... more of just a trial and error deal with the template. ill make a more legit template on the computer for you guys when i get time.
i went to a friend of mine that is a fabricator and had him cut out the general shape for me, not the cheapest idea. there is a metal yard right down the street from me im sure would have what is needed. you can also just try to find something at home depot or an auto parts store that would work.
Thanks for all the good words!
Old 10-17-2007, 01:10 PM   #14
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
I was thinking of roof flashing, thin guage comes in a roll for pretty cheap, easy to work with
I also have a roll of mudflap material I was looking at, not the rubber but the poly
Old 10-17-2007, 01:31 PM   #15
xdrian
Member#: 104200
828 WHP BUGEYE
Street Proven Performance
how thick is that aluminum ?
xdrian is online now   Reply With Quote
Old 10-17-2007, 02:15 PM   #16
lokies
Member#: 51554
2004 psm wrx
Now with 2 car seats...!
thats awesome....i'm assuming its the same for 04-05s....
lokies is offline   Reply With Quote
Old 10-17-2007, 02:18 PM   #17
o2sys
Member#: 43842
200? WRX STI
wow thats pretty good, better than most cooling JDM panels i've seen...
o2sys is offline   Reply With Quote
Old 10-17-2007, 02:36 PM   #18
StretchSTI
Member#: 148656
2007 STI
I was thinking of flashing too when i typing the post about going to home depot... not to sure on it, might try it.
Too thick. he said it was 8 thousandths or something. go with something much thinner.
Im not sure... never really payed attention to the Radiator support on 04-05's
Thanks
Old 10-17-2007, 02:42 PM   #19
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
The flashin may work, whats the rough rectangular dimensions on it (ie Length width)
Old 10-17-2007, 02:46 PM   #20
WRXLTD
Member#: 136314
2014 Grand Cherokee
If you could make those for $25 or less a piece and put it up on eBay, I'd bet you'd make some money on that bad boy.
Good job.
WRXLTD is offline   Reply With Quote
Old 10-17-2007, 06:19 PM   #21
I Love Boobies
Member#: 146137
06 WRX R.I.P.
06.06 - 10.08
when you post final pictures, can u also show what it looked like stock?
I Love Boobies is offline   Reply With Quote
Old 10-27-2007, 01:31 AM   #22
StretchSTI
Member#: 148656
2007 STI
updated the post
heres a pic of the general dimensions. they may be off, i dont know. i did the template completely from trial and error so the measurements are rough.
**NOTE: the cut out for the latch has a 3/4" dia.
Old 10-27-2007, 12:00 PM   #23
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
I made mine last weekend out of some spare sheet poly I had...too bad it was purple.
Old 10-28-2007, 12:42 AM   #24
StretchSTI
Member#: 148656
2007 STI
take it out and paint it... the purple does look a little outta place
Old 10-29-2007, 03:11 PM   #25
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Does this really have a significant benefit? or is it just in theory?
BeBop86 is offline   Reply With Quote
How To: DIY TGV Deletes Jasper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 125 01-18-2016 08:00 AM
How-To: DIY aftermarket Downpipe CEL fix WorldRallyX05 Service & Maintenance 52 05-14-2010 07:04 PM
How to: DIY 3.3Ohm resistors jas0nn Interior & Exterior Modification 20 08-07-2009 11:26 AM
How To: DIY Angled Licence Plate StretchSTI Interior & Exterior Modification 29 10-18-2007 04:41 PM
Cusco Turbo Heatshields and Radiator Cooling Panels! Z1 Performance Engine/Power/Exhaust 6 07-01-2005 09:14 AM
