Old 10-17-2007, 09:10 AM   #1
billionaire7
Member#: 122428
Default GT37R Axis S5 Cosworth Head/Cam
I'm wondering what kind of power this would make...
Axis Stage 5 Motor
Garrett GT3782R
Cosworth Head
Cosworth 274/278 Cam
1600cc injectors
Hydra EMS
And about everything else needed to run to it full potential..
billionaire7 is offline   Reply With Quote
Old 10-17-2007, 10:06 AM   #2
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
It would make A LOT of power! Good luck.
Last edited by MJU1983; 10-17-2007 at 02:07 PM. Reason: Trying to keep "on topic."
MJU1983 is offline   Reply With Quote
Old 10-17-2007, 10:21 AM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
530 something wheel and maxing 1000cc injectors...was it a stroker motor?
also your head/cam statement...makning a bold statement based off of no evidence?...if you have evidence, I'd love to see it
Old 10-17-2007, 10:44 AM   #4
billionaire7
Member#: 122428
^ True. I have made 488whp on 91oct and 56x on C16/28lbs with the Cosworth heads and 272/272 cam (street app.) along with the GT3582R. And this was all done on stock bottom end.
I'm asking because these Cosworth parts work well, very well! Along side a bulletproof motor, 9k redline, a stronger cam, and a turbo that keeps making power all the way to redline this combonation is capable of 700s. That is what I think...
Old 10-17-2007, 10:55 AM   #5
Homemade WRX
Member#: 33782
96 bastard child
I wouldn't see spinning a EJ257 with 278/274 cams and a 37r to 9k to be very productive...power should be topped off and falling before then.
Old 10-17-2007, 11:05 AM   #6
MJU1983
Member#: 14364
also your head/cam statement...makning a bold statement based off of no evidence?...i fyou have evidence, I'd love to see it
I have seen everyones work / results. I know what works better and why: air flow.
Old 10-17-2007, 11:44 AM   #7
Devan M
Member#: 83435
I assume you are referring to great results like these; http://forums.nasioc.com/forums/show....php?t=1245492
Devan M is offline   Reply With Quote
Old 10-17-2007, 12:04 PM   #8
ejh25
Member#: 65267
9k redline?
Yikes.
ejh25 is offline   Reply With Quote
Old 10-17-2007, 12:05 PM   #9
MJU1983
Member#: 14364
I certainly am partial to a certain builder, as you are. I apologize if I offended you.
Regards,
-Mike
Last edited by MJU1983; 10-17-2007 at 02:08 PM. Reason: Trying to keep "on topic."
Old 10-17-2007, 12:37 PM   #10
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
e85 maxes out injectors much much quicker
blowbyu24 is offline   Reply With Quote
Old 10-17-2007, 01:13 PM   #11
Jeremy@Cobb
Member#: 106514
Depending on the dyno 525WHP+ on C16 is not out of the question.
Should be similar to the following, but a little more lag due to the engine being smaller.
http://www.harmanmotive.com/Gallery/STI/Chase/dyno.jpg
What is the car going to be used for? .. a larger turbine housing will be needed for big power!
The car above uses a 1.06 exhaust housing.
- J.
Last edited by Jeremy@Cobb; 10-17-2007 at 02:30 PM. Reason: Keeping this thread on track.
Jeremy@Cobb is offline   Reply With Quote
Old 10-17-2007, 01:15 PM   #12
Homemade WRX
Member#: 33782
96 bastard child
true and I completely missed the e85 comment until you posted that
I really would love to do a flow bench comparison of axis, cobb, crawford and any other head...take velocity profiles on all of them and see which is the "best" on the bench. This is closest and most thorough comparison without doing numerous, tedious, head installs to get real power as the bench can only do so much.
still working on getting more toys...like an engine dyno
Old 10-17-2007, 01:38 PM   #13
MJU1983
Member#: 14364
Originally Posted by Jeremy@Cobb View Post
Please... do not post without info to back up your statement!
I have yet to see a Subaru head flow better than the Cobb CNC!
"the difference is night and day.. trust me... but... I have no proof"
I will give you credit in that they are better than your old stuff.
Old 10-17-2007, 01:51 PM   #14
Homemade WRX
Member#: 33782
96 bastard child
well hear comes a he said she said pissing match...well, could have been in interesting thread.
I will say that I've been impressed with few of the builds that get done by some of the large engine builders/tuners...not going to name anyone, as I don't like pissing on others as I don't know if I can do any better but we'll see.
I do know of one that I would NEVER run though...and shipping from california would be costly anyhow
Old 10-17-2007, 02:06 PM   #15
MJU1983
Member#: 14364
Sorry, didn't mean to ruin the OP thread. I will go and edit my posts to help keep this on track. Afterall, I love this site. <3
Old 10-17-2007, 02:17 PM   #16
Jeremy@Cobb
Member#: 106514
Good luck with your build!
Last edited by Jeremy@Cobb; 10-17-2007 at 02:27 PM. Reason: Keeping the thread on track.
Old 10-17-2007, 02:18 PM   #17
billionaire7
Member#: 122428
Remember it is easy to get the intake ports to flow well, the exhaust ports are another story.
Aside from all of this, the real proof is power.
There is plenty more in this daily driver! The customer is currently happy with the current power levels.
I would be happy myself, with a 485whp California pump gas daily driver!
Build details...
Is this the STi with all the pink...
Old 10-17-2007, 02:51 PM   #18
Homemade WRX
Member#: 33782
96 bastard child
jeremy, what do you suspect to be choking off the top of the torque curve on that engine? I'm assuming it was just a EJ257 (or bigger?) w/heads, cams and 1.06 35r?...
still nice to see it just under 600 on c16...the nitrous run however...can you say goodbye drivetrain
Old 10-17-2007, 03:45 PM   #19
Jeremy@Cobb
Member#: 106514
Build details...
Yes this is the "all the pink" car.
http://www.harmanmotive.com/Gallery/...ase/index.html
Old 10-17-2007, 05:12 PM   #20
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
I personaly would not bother with the 37R. I would go to the GT4094. This will ensure you will get up in the 600's. The compressor is to small on that 37 turbo.
Clark
AZScoobie is offline   Reply With Quote
Old 10-17-2007, 05:15 PM   #21
Homemade WRX
Member#: 33782
96 bastard child
I'm not a fan of th 37r either...
Old 10-17-2007, 11:06 PM   #22
drewwrxrogers
Member#: 132574
04 Aspen White Sti
GT35r, axis motor,280cams
Axis Ron Ftw!!!!!!!
drewwrxrogers is offline   Reply With Quote
Old 10-17-2007, 11:15 PM   #23
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Last edited by LiquidForce; 10-17-2007 at 11:15 PM. Reason: everyone else was editing their post so I figured I'd edit mine.
LiquidForce is offline   Reply With Quote
Old 10-18-2007, 08:34 AM   #24
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
i dont think those cams will push to 9k with that turbo..
more like 7500-8000rpm imo..
tino is offline   Reply With Quote
Old 10-18-2007, 10:34 AM   #25
MJU1983
Member#: 14364
If that, need bigger ones!
FS : heads cams valves springs reatiners, valvelocks fastlanerex Engine/Power/Exhaust 51 09-30-2010 06:17 PM
07 STi UR GT35R Kit, Cosworth heads/cams/block ChrisSK Proven Power Bragging 62 10-12-2007 11:54 AM
Cosworth Heads/Cams billionaire7 Engine/Power/Exhaust 1 08-23-2007 04:46 PM
FS- Axis stg2 9500rpm jun cammed heads +more WRXpkr Mid West Subaru Owners Club Forum -- MWSOC 92 06-20-2005 05:36 PM
Axis stg2 9500rpm jun cammed heads WRXpkr Private 'For Sale' Classifieds 9 05-12-2005 10:50 AM
Message Board Statistics All times are GMT -4. The time now is 02:00 AM.
