Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 10-17-2007, 04:13 PM   #1
OneArmedScissor
Member#: 18958
08 STi
Black as my heart
Default about to do a 6mt tranny and diff fluid change...where to get fluid?
where has the special subaru synthetic and the rear diff dino oil that I need for my 6mt in town?
Taking car to engine logics tomorrow for some maintenance and I wanted this done with the best fluids for the 6mt and I'm a bit clueless as to the 6spd stuff.
OneArmedScissor is offline   Reply With Quote
Old 10-17-2007, 04:19 PM   #2
Butterz
Member#: 21205
2004 WRX Wagon
Brown
I would say either Royal Purple or the Subaru synthetic stuff. Chris sold me on the Royal Purple when he put the PPG's in.
Vatozone carrys Royal Purple, and I think you'll have to go to the dealership for the Subaru stuff.
Butterz is offline   Reply With Quote
Old 10-17-2007, 04:29 PM   #3
Locky1138
Member#: 73285
2004 cobb Stg2 WRX
subaru stuff has detergents in it. i've always been told to avoid that stuff. whatever you get make sure it has a friction-additive, some idiot put "normal" stuff in my 5mt and every gear ground like hell because the syncros wouldnt catch, untill they put Pensoil Syncro-mesh stuff in it.
by the way... GC8 STI v5? i'm a bit curious about your car.
Locky1138 is offline   Reply With Quote
Old 10-17-2007, 04:34 PM   #4
Rancid
Member#: 3272
2016 VW Golf R
Oh! I need some Subaru synthetic fluid too (its by far the best)! Want to pitch in together and buy a big jug of it?
Rancid is offline   Reply With Quote
Old 10-17-2007, 06:19 PM   #5
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
There is a coctail that many have used in 5mt Subarus.
1 Qt Redline Lightweight Shockproof Gear Oil
1 Qt Penzoil Synchromesh
1.5 Qt Castrol HypoyC
I'm not sure what capacity etc the 6mt uses but I can't see why if you preserved the same ratio why it wouldn't work. Also you can pickup Synchromesh/HypocC at Autozone/Orielly respectively.
ai42 is offline   Reply With Quote
Old 10-17-2007, 07:13 PM   #6
Rancid
Member#: 3272
2016 VW Golf R
Cocktails are bad. Mixing oils is bad and makes a mess inside of transmissions.
Old 10-17-2007, 09:16 PM   #7
ericwilliams
Member#: 162078
2002 WRX Sport Wagon
Definately stick with the OEM synthetic, I've never heard of anyone having a failure due to the use of Subaru's GL5. Change it every 15k miles and you can re-use the metal washer found on the drain plug. Make sure to clean off the metal debris that will collect on the magnet. Pretty straighforward service shouldn't cost you more than $50 if you have it done at the dealership. If doing it yourself you'll need a Torx T-70 and I think its only offered in a 1/2 inch drive (although some older models used a hex head 19mm) take a look for yourself and see. If having a shop do the service advise them to not overtighten the drainplug because they can be a PAIN to get off if tightened more than is needed(just a little past the point where the plug's flange/washer meets up with the case)
ericwilliams is offline   Reply With Quote
Old 10-17-2007, 10:13 PM   #8
MarkRx
Member#: 42242
2006 STI
subaru 75-90 extra-S in the gear box. you're on your own in the diff. /close thread
MarkRx is offline   Reply With Quote
Old 10-18-2007, 01:43 AM   #9
nxttruck2002
Member#: 90879
Gear Box:
Rear diff:
nxttruck2002 is offline   Reply With Quote
Old 10-21-2007, 01:07 AM   #10
chudlo
Member#: 15505
2002 JDMV8 STI Wagon
^^^^^If you have a 6mt use the above only!
Do not use Royal Purple in your Subaru transmission. RoyalPpurple doesn't suggest using it, according to my dealer.
chudlo is offline   Reply With Quote
Ready for tranny/diff fluid change...where to? fluxcapacitor Southern California Impreza Club Forum -- SCIC 12 01-07-2008 11:51 PM
when to change tranny and diff fluid, and where to get the best manual dwike Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-13-2007 11:11 AM
250 bucks for tranny and diff lfuid change?? TeamASR Tri-State Area Forum 3 01-21-2004 02:30 AM
tranny and diff oil change info needed subliminal Transmission (AT/MT) & Driveline 3 01-20-2004 11:15 AM
Looking to do a custom trunk install. Need suggestions on where to go? my02wrx Southern California Impreza Club Forum -- SCIC 25 12-05-2003 12:58 PM
