Welcome to the North American Subaru Impreza Owners Club Thursday October 27, 2016
Old 10-17-2007, 04:43 PM   #1
Member#: 131770
2001 Subaru Impreza
Default after swap some CEL codes
Well I finished a swap in a '97 impreza L. I took a '94 legacy ej22 and put it into my '97 impreza L . Everything went fairly smooth compared to what i thought. The '94 ej22 was in excellent shape, only 30k miles on it.
I had to use the ignition coil, and spark plugs off the '94 legacy, but all the other intake, fuel injectors, etc. from the '97 impreza.
I also put new O2 sensors in , and a custom 2" exhaust.
After driving it for about 2weeks now, I have run into a couple of CEL codes. I went home, and got the codes -
P0715 - torque converter signal
P0303 - Misfire on cyl 3
P0705 - Transmission Range Sensor Circuit Malfunction (i believe that was the code. I will check tomorrow)
and a Throttle positioning sensor weak input. (cant remember the code number)
The TPS has been acting up lately - one minute it works fine, the next it doesnt work. The oher day I was driving home and the car just about stalled, then came back to life jsut when it hit 1000rpms. It kept doing that so i pulled over, popped the hood, and unpluged the TPS (i figured htats what it was, had been having this problem for a couple of days). Now the car seems to be running a little better - not wanting to stall anyways.
I got home and hooked the computer up to the car and read those four codes. I replaced the spark plugs , and wires, and I am hoping that will help with the misfire. Any suggestions on what to do about the other ones? I am ordering a new TPS, but I am not sure about the tranny code. and is the car alright to drive ?
vipergtrdj is offline   Reply With Quote
Strange CEL codes after turbo install... F my life. Donzo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 73 06-28-2010 12:53 PM
Major Issues 2.2 Only Running On 2 Cylinders After I Cleared Cel Codes (iacv) bcustom561 Service & Maintenance 2 05-20-2010 08:17 PM
limp mode after swap two cels 0037 1088 elsanto Engine Management & Tuning 0 11-13-2007 09:15 AM
swapped to modified deatschwerk injectors - now CEL codes p0103 and p0113? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-23-2006 03:07 PM
Need some CEL code info. obyone Normally Aspirated Powertrain 3 04-15-2003 03:25 AM
