Old 10-17-2007, 08:32 PM   #1
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
Default HELP!! Header install, now mysterious oil leak from turbo area!!
As title states... wherever it is, its dripping from something above the upipe.... anyone know where this oil leak is??? this happened to a friend as well....
anyone know where to check? how to check it? how to fix it?
All4bSpinnin is offline   Reply With Quote
Old 10-17-2007, 08:37 PM   #2
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Oil drain from the turbo its located directly on the bottom of the turbo and connects to a small black hose! pretty common to com un-done easily!
renosubby is offline   Reply With Quote
Old 10-17-2007, 08:43 PM   #3
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
anything running to the turbo is completely dry.... its leaking on the upipe a little after the 02 sensor going towards the turbo
Old 10-17-2007, 09:02 PM   #4
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
Hheeeelllppp!!!
Old 10-17-2007, 09:15 PM   #5
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
my upipe is soaked...
Old 10-17-2007, 09:34 PM   #6
boquag
Member#: 133879
2003 impreza wrx
platinum silver
check the back side of the valve cover gasket...
boquag is offline   Reply With Quote
Old 10-17-2007, 09:41 PM   #7
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
has installing a header caused a leak here before?
Old 10-17-2007, 09:47 PM   #8
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
i can kinda see it spraying from somewhere if i look down by the turbo....
Old 10-17-2007, 09:50 PM   #9
boquag
Member#: 133879
2003 impreza wrx
platinum silver
no, but this side is under higher temps and is more apt to harden up a gasket espcially now that theres a header with no heat shield, the only other oil source in the area is the oil outlet on the bottom of the turbo wich has a cheesy ring clamp holding it on from the factory...
Old 10-17-2007, 10:04 PM   #10
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
it might be by the valve cover
Old 10-17-2007, 10:12 PM   #11
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
maybe turbo oil feed line got shifted during header install ,oil leaking from connection to head then running down the head to that area
a6n6d6y is offline   Reply With Quote
Old 10-17-2007, 10:24 PM   #12
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
thats a possibility... whatever was spraying oil was on the bottom and somewhere out of sight
Old 10-17-2007, 10:52 PM   #13
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
its gotta be something on the oil return line....
Old 10-18-2007, 02:37 PM   #14
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
dave..
check the hard line at the back of the head.
then check the half moon...
another person in jax did the same thing when
he tried to install the one piece header by himself.
and if you did this you sir are a dork..
Old 10-18-2007, 04:50 PM   #15
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
Originally Posted by jaxscuby View Post
dave..
lol thanks ben... i'll check it asap
do i have to pull the header back out to get to this line or is it easier to pull the turbo?
Old 10-18-2007, 05:17 PM   #16
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
pull the turbo.
this way you will be able to see if the turbo oil drain line or
hard oil line on the back of the head is the culprit..
Old 10-18-2007, 05:25 PM   #17
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
ya check that line
subaru222 is offline   Reply With Quote
Old 10-18-2007, 09:19 PM   #18
ur2s2pid
Member#: 142104
2011 STi limited
I don't think installing a header has caused a leak there before but thats not to say that something else didn't happen and now the valve cover is leaking.
ur2s2pid is offline   Reply With Quote
Old 10-19-2007, 08:42 PM   #19
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
Jaxscuby FTW!!
ben, you called it... the halfmoon on the bottom side of the head was pushed a little into the motor causing an oil leak...
trying to sneak the half moon out so i can put it back in with some silicone....
half moons ftl...
Old 10-20-2007, 07:58 AM   #20
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
PWN3D told you so..
dave..
would not have been a problem if you had jacked the passenger
side engine mount. this would have given you enough clearance..
dork...
Old 10-20-2007, 06:09 PM   #21
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
welllllll.... i had done this every time but this time i cut a corner and got burned nasty... we were jacking up the entire motor... but this time we only did one side
Old 10-25-2007, 03:22 PM   #22
nperkins
Member#: 135812
90 Miata
04 Evo Rally Car
Had the same thing doing my header... Removed the valve cover & replaced the Cam Seal. Took 30 minutes.
nperkins is offline   Reply With Quote
Oil leaking from turbo due to excessive crankcase pressure? HELP iRace559 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 30 08-21-2009 08:29 AM
oil leaking from turbo!! 07SWPSTi Newbies & FAQs 5 04-12-2008 06:44 PM
oil leak from turbo vvafivv Southern California Impreza Club Forum -- SCIC 0 10-03-2007 03:08 AM
How much oil leak from turbo is normal? VSM EXtasy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-20-2003 11:52 AM
Antifreeze leaking from turbo area Wrxified Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-10-2002 09:12 PM
