Old 10-17-2007, 09:13 PM   #1
Dave_MacKinnon
Member#: 10823
2007 STi
Default DTC and DCCD Reset
I need to clear some codes from my DCCD CPU - does anyone know if any software can 'see' it? I have the Tactrix and OBD-2.com cables.
Dave_MacKinnon is offline   Reply With Quote
Old 10-18-2007, 10:15 AM   #2
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
where do those show up?
Hyper is online now   Reply With Quote
Old 10-18-2007, 10:33 AM   #3
Dave_MacKinnon
Member#: 10823
2007 STi
There is a 'procedure' that allows the DCCD position indicators to blink out a trouble code pattern.
Mine shows codes 31 and 37... and doesn't engage the DCCD - leaves it open.
I accidentally powered up the car with the DCCD controller unplugged and it hasn't worked since.
Here is the procedure from the 2007 Impreza service manual.....
1. WHEN USING THE DIAGNOSIS
INDICATOR LIGHT
NOTE:
Perform steps 4) to 8) below within 30 seconds.
1) Securely apply the parking brake.
2) Switch the center differential control dial in the
differential free position.
3) Start the engine.
4) Switch the center differential control dial in the
differential lock position.
5) Release the parking brake.
6) Switch the center differential control dial in the
7) Securely apply the parking brake.
8) Repeat steps 4) to 7) two more times.
DTC Item Content of diagnosis Reference target
21 Accelerator Position Sensor E
Open or short in the accelerator pedal position sensor circuit
<Ref. to 6MT(diag)-56, DTC P2125 ACCELERATOR POSITION SENSOR E, Diagnostic Procedure with Diagnostic Trouble Code DTC).>
22 Lateral Acceleration Sensor Circuit
Open or short in the lateral G sensor circuit
<Ref. to 6MT(diag)-39, DTC P1759 LATERAL ACCELERATION SENSOR CIRCUIT, Diagnostic Procedure with Diagnostic Trouble Code
(DTC).>
23 Circuit of Center Diff. Open or short in the driverís control center differential circuit
<Ref. to 6MT(diag)-50, DTC P1875 CIRCUIT OF CENTER DIFF., Diagnostic Procedure with Diagnostic Trouble Code (DTC).>
24 Check Center Differential Control Dial
Open or short in the center differential control dial circuit.
<Ref. to 6MT(diag)-59, DTC 24 CHECK CENTER DIFFERENTIAL CONTROL DIAL, Diagnostic Procedure with Diagnostic Trouble Code
(DTC).>
25 DCCD CAN system circuit CAN communication circuit is open or shorted.
<Ref. to 6MT(diag)-35, DTC P1720 DCCD CAN SYSTEM CIRCUIT, Diagnostic Procedure with Diagnostic Trouble Code (DTC).>
26 DCCD engine rpm signal system Open or shorted engine speed
signal circuit
<Ref. to 6MT(diag)-37, DTC P1721 DCCD ENGINE RPM SIGNAL SYSTEM CIRCUIT, Diagnostic Procedure with Diagnostic Trouble Code (DTC).>
27 Yaw rate side G sensor reference system circuit
Open or short in the yaw rate & lateral G sensor reference circuit
<Ref. to 6MT(diag)-45, DTC P1765 YAW RATE SIDE G SENSOR REFERENCE SYSTEM CIRCUIT, Diagnostic Procedure with Diagnostic Trouble Code (DTC).>
28 Yaw rate sensor system circuit Open, short or stuck in the yaw
rate & lateral G sensor circuit
<Ref. to 6MT(diag)-42, DTC P1764 YAW RATE SENSOR SYSTEM CIRCUIT, Diagnostic Procedure with Diagnostic Trouble Code (DTC).>
29 DCCD Steering Angle Sensor Open, short or communication
failure of the steering angle sensor circuit
<Ref. to 6MT(diag)-48, DTC P1767 DCCD STEERING ANGLE SENSOR, Diagnostic Procedure with Diagnostic Trouble Code (DTC).>
31 Manual mode switch
Open or short in the manual mode switch circuit
<Ref. to 6MT(diag)-61, DTC 31 MANUAL MODE SWITCH, Diagnostic Procedure with Diagnostic Trouble Code (DTC).>
32 Check Parking Brake Switch
Open or short in the parking brake switch circuit
<Ref. to 6MT(diag)-64, DTC 32 CHECK PARKING BRAKE SWITCH, Diagnostic Procedure with Diagnostic Trouble Code (DTC).>
33 Stop Light Switch Circuit Range
Open or short in the stop light switch circuit
<Ref. to 6MT(diag)-33, DTC P1521 BRAKE SWITCH CIRCUIT RANGE, Diagnostic Procedure with Diagnostic Trouble Code (DTC).>
37 Neutral position switch
Open or short in the neutral position switch circuit
<Ref. to 6MT(diag)-67, DTC 37 NEUTRAL POSITION SWITCH, Diagnostic Procedure with Diagnostic Trouble Code (DTC).>
Old 10-19-2007, 10:12 AM   #4
R & H Garage
Member#: 139767
just a guess, but it seems the standard 'unplug the neg bat terminal and hold the brake for 30 years' technique should work.
Have you tried it?
You could always take off the terminal before bed and then re connect it before work. One word of caution however, you are going to have to use the key to lock the door!! I know, it's crazy.. a key.... We are such a lazy society.
That's some great info on the diagnostic procedures you posted up there. Thanks a ton. I'm going to bookmark that **** for sure.
-Dominic
R & H Garage is offline   Reply With Quote
Old 11-08-2007, 11:45 PM   #5
Dave_MacKinnon
Member#: 10823
2007 STi
My bad for not closing this thread off.
The issue was 'logging too many paramaters' with Enginuity. Once you get the flashing ABS and lock ring, your DCCD controller goes offline. Disconnecting the battery does fix it.
Old 11-09-2007, 05:14 AM   #6
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
wow
usefull info
thanks!
Old 11-01-2008, 03:31 PM   #7
nvrenufsti
Member#: 190522
06 sti
Aspen white
How would you run the trouble codes if your DCCD doesn't move out of full rear (and blinking) when the car is started? When the key is in the on position and not started you can go through the dccd settings.
nvrenufsti is offline   Reply With Quote
Old 04-28-2010, 07:12 PM   #8
flu1d
Member#: 141586
07 STi
I'm having a similar problem. I have some trouble codes showing up and was wondering if there is any software or procedure that will clear the DCCD ecu codes. I have an Access Port.
I really do not want to spend $100 at the dealership Thanks.
flu1d is offline   Reply With Quote
Old 04-23-2013, 09:47 PM   #9
awakethroughmotion
Member#: 199512
06 wrb STi
2013 F150 XLT
bump. any way to clear the codes other than stealership? i have 31,33,29,37 i think the codes just need to be cleared after i accidently drained the battery/
awakethroughmotion is offline   Reply With Quote
Old 06-18-2015, 03:11 PM   #10
k3ogh_sti
Member#: 415968
2005 widetrack sti
48w
Mega thread revival! Did you manage to fix it, getting code 37 nps and it's still flashing ����
k3ogh_sti is offline   Reply With Quote
Old 06-23-2015, 01:59 AM   #11
Ramesh Kumar
Member#: 424168
Dear All,
I have a problem of communication of scanning tool with sti 2004. It
is showing communication with vehicle is lost . We modified sti. Currently it has only DCCD electronics unit with out any sensor and Auto/ manual switch. ABS and air bag also not installed. Only we have ABS electronic unit. Please suggest accordingly....
Ramesh Kumar is offline   Reply With Quote
Old 07-10-2015, 07:26 PM   #12
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
As long as someone revived a 7+ year old thread...
FreeSSM is the software you need to download.
mrsaturn7085 is offline   Reply With Quote
No-dccd center diff fits a DCCD 6 speed and DCCD fit no mater the year of the tranny? mudbug Transmission (AT/MT) & Driveline 21 11-21-2009 05:42 PM
06 sti DCCD Reset nvrenufsti Transmission (AT/MT) & Driveline 22 11-23-2008 02:46 PM
p0031 and misfires after a brand new front o2 sensor and ecu reset 1gcrazy Newbies & FAQs 25 09-26-2008 12:17 PM
FS: Turbo xs bov, sti clutch and fly, B&M SS, and DCCD controller! D Money Engine/Power/Exhaust 16 08-29-2006 11:29 AM
GanzFlow aftermath and ECU reset question heatseeka Normally Aspirated Powertrain 16 06-19-2001 02:21 PM
