Old 10-17-2007, 11:25 PM   #1
perrin247
Member#: 129369
2005 WRX STI
World Rally Blue
Default Need gaskets for hybrid.
If it helps its a built 2.5 with wrx heads
This is where im at...i know im going to need cam seals and valve cover gaskets along with header...but what else?
whats this small seal that looks like its after the oil pump?
Finally does anyone just make a gasket kit with everything i can buy?
perrin247 is offline   Reply With Quote
Old 10-18-2007, 12:04 AM   #2
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
You can buy a factory gasket set from the dealer.
MJU1983 is offline   Reply With Quote
Old 10-18-2007, 12:33 AM   #3
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
www.thekingofparts.com. Call and ask for Tristan. Got all my stuff there, great prices, speedy service.
You're probably also gonna want to do a full set of exhaust gaskets. Turbo to DP, all UP gaskets, and manifold gaskets. Tristan can help you sort it all out, he's a real good guy
Acostafan is offline   Reply With Quote
Old 10-18-2007, 01:19 AM   #4
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
You remembered to put the headgaskets on, right?
Sko is offline   Reply With Quote
Old 10-18-2007, 01:21 AM   #5
perrin247
Member#: 129369
2005 WRX STI
World Rally Blue
haha yeah commetics with arp's holding thoes heads on.
Old 10-18-2007, 08:19 AM   #6
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Is your oil pump already mounted or did you just bolt it up temporarirly?
You need to install the crank oil seal before you mount it and did you install the small o-ring that goes between the oil pump and the block ?
LiquidForce is offline   Reply With Quote
Old 10-18-2007, 01:43 PM   #7
SAIKOU
Member#: 92718
04 WRX 2.5 Hybrid
+1 for complete STI engine gasket set. You'll still need valve cover / cam gaskets L and R, valve cover bolt gasket/o-ring things (x16 i think), intercooler/bov gaskets, plus all the exhaust gaskets mentioned above. def do ur uppipe w/ new. Don't forget to clean out the oil cooler real good b/c any oil on that big red gasket/seal and it'll expand before u get it on. hope this helps
SAIKOU is offline   Reply With Quote
Old 10-18-2007, 04:13 PM   #8
perrin247
Member#: 129369
2005 WRX STI
World Rally Blue
The oil pump is olny mocked up...that small o ring gasket goes between the block and oil pump? ans what should i use ultra black silicone behind the oil pump?
Old 10-18-2007, 08:08 PM   #9
LiquidForce
Member#: 12811
2002 2.5l Wrx
Do you have a service manual? If not you definately need to find one. Search hard enough and you can find an online copy.
I use the subaru fuji-bond instead of permatex.
Old 10-18-2007, 09:19 PM   #10
Rick539
Member#: 35997
Just got done with my hybrid, look at the stickey of the 2.5 master gasket in this forum. I used the following numbers (block was already built so I used none of the gaskets for the block assy):
14,15,16,17,32,33,34,35,39,41,45,46,50,51,52,54
hope this helps
Rick539 is offline   Reply With Quote
Old 10-18-2007, 09:40 PM   #11
perrin247
Member#: 129369
2005 WRX STI
World Rally Blue
yeah I checked that out but im to the point where I need spesific gaskets and dont know whats left. I know i need cam seals, water pump gasket, o ring behind oil pump, and valve cover. Any thing else you guys see I need??
Old 10-18-2007, 10:53 PM   #12
Rick539
Member#: 35997
I would add spark plug hole gaskets (4), valve cover washers (16), tumbler valve to block (2) and intake to tumbler (2). Also you can use hondabond verses fuji bond. Usually more available and a little bit cheaper. If you have to do the oil pan I would just get a tube (caulking gun size) of triple bond from subaru. cost about 48.00
which gaskets for hybrid? Kaldar142 Built Motor Discussion 15 10-22-2008 12:15 AM
need gasket for borla CT to dp...help gloves Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 04-01-2006 11:12 AM
Cometic Gasket for hybrid swap k_thaosta Private 'Wanted' Classifieds 8 03-28-2006 10:49 AM
Need gasket for egt probe install? [gearhead] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-02-2005 04:49 PM
AZPinstall tommorow ..needs gasket for a turbo xs dp kraizykel Tri-State Area Forum 2 09-25-2004 02:18 AM
