Old 10-18-2007, 08:17 AM   #1
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Default CEL P0442 (evap small leak) + instable boost
Recently my 03 WRX sedan with AccessPort stage 2 started having boost issues, it seems to happen since the outside temperatures got colder. Yesterday the boost appeared to be even more instable, say between 12 and 18 lbs (AP stg2 should be arount 15.7 I think). That was on the highway. I came to a stop light, started at full throttle for 1st gear and second, let off the gas, and a few seconds later the CEL came on.
Lots of people say check you gas cap, but I always tighten it a lot of clicks and because of the boost problem I feel it is something else. A lot of people here also recommends to check for leaks in the vacuum hoses (the blue T fitting or any other vacuum lines). I guess I have a leak that got bigger recently due to the temperature changes ?
What do you think ?
frederik is offline   Reply With Quote
Old 10-18-2007, 08:22 AM   #2
fastjim
Member#: 103810
05 WRX
Black Pearl
i had a small leak in the evap one time after i got my car back from the body shop after a rear end accident.. dont know if this will help you but behind your right rear (passanger side) tire there is a black box under the car with hoses connected to it. this is your charcol canister and does emission stuff make sure all your hoses are connected to this.. i had the hose on top disconected.. if you can use a lift it would be easier.. or you can just unbolt it and see all the hoses that way its only two bolts 12mm i think.. hope this helps if any
fastjim is offline   Reply With Quote
Old 10-18-2007, 08:36 AM   #3
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
fastjim : I also read about the canister stuff but did'nt have much details about what to check exactly. Thanks for the additional info about the top tube and unbolting the assembly. I'll check that as well.
Old 10-18-2007, 12:48 PM   #4
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Anybody think my boost problem is related to the P0442 CEL ?
Old 10-20-2007, 11:49 AM   #5
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
I have reset the ECU with the AccessPort Reset ECU function, and the boost is much more stable than before. Can't figure why. It is still going crazy sometimes in 4th gear but the car seems to pull much better and the CEL did'nt come back.
I also had another problem the other morning, after starting up the car, the Low fuel light came on and the fuel gauge dropped from 3/4 to zero in about 30 seconds, and came back to normal after a while, and fuel light came off.
Is there a relation between the fuel gauge problem and the P0442 CEL ?
Thanks
CEL P0442 stand up imma_stocker Texas Impreza Club Forum -- TXIC 6 11-04-2007 10:19 PM
Anyone get a P0442 evap emission control turbocolin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-27-2006 08:44 PM
Cel P0442 Rando Engine Management & Tuning 5 03-29-2006 10:14 PM
CEL P0442/P0457? (Help Needed) APSWRX1 Texas Impreza Club Forum -- TXIC 4 03-28-2006 02:16 PM
Code P0442, Evap system? ascott Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-26-2003 12:41 PM
