Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 10-19-2007, 12:03 AM   #1
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Default Hydra WB Wiring
I'm not making any sense of these WB installation and calibration instructions on the Hydra website. How is the ECU side of the wideband harness supposed to be hooked up? I guess I'm supposed to identify the slots on the PNP harness but F1, F2, F9, I don't see any of that.
-n00b
ExecNav is offline   Reply With Quote
Old 10-19-2007, 05:35 AM   #2
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
You need to look at the plug for the wb harness it has letters that you need to match up to the specified slots in the pnp harness. You should have a print out telling you what the slots are in the pnp harness.
A on the wb harness goes to slot A1 in the pnp harness and so on.
B>B2
C>B9
D>A11
E>D7
speed_freak27 is offline   Reply With Quote
Old 10-19-2007, 10:58 AM   #3
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
The instructions are provided on the CD Rom:
"The pins are connected as follows:
A: Grey Connector F1 (labeled) B1
B: Grey Connector F2 (labeled) B2
C: Grey Connector F9 (labeled) B9
D: Grey Connector E11 (labeled) A11
E: Large Blue Connector D7"
4 of the 5 pins go into the small grey connector and E goes to the Large Blue connector.
Element Tuning is offline   Reply With Quote
Old 10-19-2007, 11:02 AM   #4
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
I actually don't have access to the CD rom right now but yeah. I was doing this in poor light and failed to realize there was a "grey" connector.
Anyway, I got it now and that couldn't have been easier. Thanks guys.
-Brett
Old 10-19-2007, 11:07 AM   #5
Element Tuning
Member#: 54918
673 WHP Element
-Brett
Great, glad you got it sorted.
Thanks,
Phil
www.elementtuning.com
Old 10-23-2007, 05:02 PM   #6
sean18337
Member#: 135588
2007 STI *SOLD*
Is there an easy way to get the pins back out of the harness? I had to remove the Hydra and wideband from my car ( brought it back to the dealer) and had to cut off the big connector at the end of the sensor to get the wires through the firewall.
Any ideas guys for the next time I have to remove this?
sean18337 is offline   Reply With Quote
Old 10-24-2007, 11:09 AM   #7
Element Tuning
Member#: 54918
673 WHP Element
GM Pin tools. You can also use a micro flat blade screwdriver. When done correctly the pins slides out easily but done incorrectly you will ruin the connector. Be careful.
Thanks,
Phil
Old 10-24-2007, 11:25 AM   #8
sean18337
Member#: 135588
2007 STI *SOLD*
OK, is there a way to get the big connector through the firewall? Or do most guys push the wire loom through before they connect the pins to the adapter harness at the Hydra?
Old 10-24-2007, 02:35 PM   #9
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Firewall shmirewall.
My cable is run under the passenger carpet up to the shifter area and leaves the interior of the car around there.
jblaine is offline   Reply With Quote
Old 10-24-2007, 02:53 PM   #10
sean18337
Member#: 135588
2007 STI *SOLD*
OK.. I welded a bung in my downpipe and have the wideband there. Maybe I will remove the rear 02 sensor and put it like yours..
Do I just remove the plastics around the shifter and run the wire down there?
Old 10-24-2007, 02:59 PM   #11
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Yup. Just make sure it's out of the way and secured well the whole way. Mine's been through there for almost 2 years.
Old 10-26-2007, 01:41 PM   #12
El Gato
Member#: 110648
Chapter/Region: PRSIC
2005 Hydramist 35R82
93oct 479whp 456tq
Never thought of that before. My WG dumptube fell, and the WG was blowing right on the WB cables. They melted and had to do a little rewiring.
El Gato is offline   Reply With Quote
Old 10-31-2007, 08:26 AM   #13
sean18337
Member#: 135588
2007 STI *SOLD*
I installed the wideband back in the car this weekend and ran it through the shifer area and it was much easier than snaking the wires through the firewall.
Thanks for the idea!!
Sean
Fluttering AFRs while calibrating Hydra WB O2 - Is this normal? dexterous Other Engine Management 6 03-30-2009 06:43 AM
Hydra for wire-in solution? ai42 Other Engine Management 5 08-17-2007 07:32 PM
Alternate CHEAPER Hydra WB Sensor??? White 2.5rs Other Engine Management 0 06-17-2007 07:59 PM
Hydra wb install Sparcomx Other Engine Management 2 11-13-2005 05:18 AM
HYDRA WB install oldbluwrx Other Engine Management 0 09-03-2005 03:08 PM
