Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC > MWSOC Vendor Classifieds
Closed Thread
Old 10-20-2007, 06:05 PM   #1
P&L Motorsports Inc.
Vendor Sales Rating: (26)
Member#: 67199
07 [email protected] STI
97 RS [email protected]
Default P&L Motorsports Signature Series: An overview of all our products!
We've been hard at works for months bringing the Subaru community top quality products for their vehicles. Instead of having a bunch of spread out threads discussing what we create here, why not have all the good stuff right here in one place!
All questions, concerns, comments, and criticisms are welcome here.
If you would like to view a condensed version of our current catalog, please view our online PDF available here:
http://www.pandlmotorsports.com/images/2007_flyer.pdf
Ty Curtin
[email protected]
TEL: 847-678-4311
Without further ado,
The P&L Motorsports Signature Series Line:
P&L Motorsports Inc. is offline
Old 10-20-2007, 06:05 PM   #2
Member#: 67199
P&L Motorsports GT30r Kit
P&L has spent over half a year designing, refining, and testing our turbo kit offerings for the Subaru Impreza. After having had to install and work with several companies other products, there were some shortcomings we simply knew could be overcome. So we started from scratch and started designing a kit from the ground up that covered fitment issues, quality control issues, etc.
Hand crafted in house by our fabricators, each kit is built and designed with pride in very small batches to keep quality control high. We've extensively tested all of our kits with various model year cars to make sure there are absolutely no fitment issues.
The heart of the system is the Garrett GT3076R turbocharger. For those looking for power levels under 450WHP (recommended for stock internal EJ257s) we have a .63 A/R exhaust option that is optimized well between 20-26 PSI. For those looking to get everything out of it, the .82 A/R exhaust option will spool up a few hundred RPM later, but flow well between 25-30 PSI (octane being appropriate of course).
Believe it or not, our kits are designed to work with high quality, upgraded top mount intercoolers (Spearco and TurboXS being our preferred choice). For those applications our kit comes with a 4" to a 3" intake with integrated MAF adapter. If you'd like to go with a front mount solution, the kit will come with a weld in 3" MAF adapter for blow through applications. Specify which you'd like at time of ordering.
Only the best components are used to keep maintenance down, and installation simple. Wastegate control is via a high quality Tial 44MM external wastegate. The Tial's V-band clamp assembly keeps maintenance at a minimal as there are no gaskets to blow out.
A custom stainless steel power steering line is included to replace the unwieldy factory unit, dramatically cleaning up the look of the engine compartment as well.
Our 30R kit includes:
-Garrett GT3076R turbocharger (.63 or .82 A/R)
-Stainless Up-pipe
-Stainless Downpipe with two O2 sensor bungs
-Tial 44MM EWG, V-bands and dump tube
-Choice of 4"-3" intake with integrated MAF, or 3" blow through MAF pipe
-Stainless steel power steering line
-Associated couplers and clamps
-Detailed instructions
Tuning required. For off-road use only.
$3499
OR $3149 plus install!!
P&L is now offering 10% off the hardware kit if you have it installed by us!! $350 off!!
93 OCT
100 OCT
Old 10-20-2007, 06:06 PM   #3
Member#: 67199
P&L Motorsports Tial BOV Kit
We always knew that Tial's products had been legendary in terms of reliability, but never had a way of packaging their BOV design in such a way that every Impreza owner could leverage them. That has changed with the release of our new BOV kit for the 2002-2007 Impreza lineup.
We start off with a custom designed and waterjet cut flange. That is precision tig-welded onto a v-band flange that the Tial high performance BOV is bolted onto. Then the entire assembly is machined to make sure the flange surface is flat and true.
Our kit has been designed and tested around several of the common aftermarket intercoolers, as well as the standard OEM units.
All kits will include our custom flange assembly, v-band flange, the Tial unit, a new 3 layer BOV gasket, and a machined plug for your factory return line. You supply the elbow grease, and about 3 minutes later, you're done.
We are now offering our BOV Kits with a REUSABLE O-ring gasket built in to the flange! Instead of paying for a new gasket each time you want to take the intercooler or BOV off, you can reuse this one which is pressed into the flange. It also provides better protection against boost leaks as pressure is applied evenly around the hole to ensure a proper seal!
Our kits are competitively priced at $355
More info and you can buy online here! :
http://www.pandlmotorsports.com/~pan...9430acf4bf0cf4
Old 10-20-2007, 06:07 PM   #4
Member#: 67199
P&L Motorsports 3" MAF HighFLO Intake System
Continuing with the success of our signature series products, P&L Motorsports would like to introduce you to their HighFLO intake system for the Subaru Impreza.
http://www.pandlmotorsports.com/~pan...20b01347af0df6 <-- Full details can be found at the following link.
Designed for high horsepower applications, the HighFLO intake is a 3" cross sectional intake that can support up to 450HP on a 4.74 MAF volt limited application, and 500HP on a 5 MAF volt application.
The unit is made from aluminum, fully tig welded, and then finished with a brushed look to make it an elegant addition under the hood of your car.
One thing we also include (as far as I understand an industry first), is a fully mapped calibration that your tuner can use to build you a proper calibration for your car. Gone are the frustrations from the self tuner trying to make a non standardized intake work.
Filter placement... why we did what we did:
We actually tested several other units to determine an average of actual inlet temperatures during a real world driving environment. What we've found is that the location we've chosen averaged a 30F drop in actual inlet temperatures. Add to that the MASSIVE K&N air filter we use and you have an ample supply of cool air to meet any bolt on turbo you could want to put on your car.
-Jorge
P&L Motorsports Intake systems are priced at $229
http://www.pandlmotorsports.com/~pan...roducts_id=352
Intakes are packed up and ready to go! We are also including a bracket to support the intake and prevent any unwanted movement!
Old 10-20-2007, 06:07 PM   #5
Member#: 67199
P&L Motorsports Signature Series Exhaust
Update: 2/5/08
All of our exhaust systems are now polished to a high gloss finish! Smooth to the touch and looks great at the track or in a car show. The best part about this is that it is added at no additional cost to you on every one of our exhausts! This also includes our rotated piping on our GT30r Turbo Kit!
P&L Motorsports is proud to introduce their latest offering in their Signature Series product line!
Our fully stainless, 3" cat-back exhaust design was finalized after several iterations were tested.
Built in house by our master fabricators (one of which spent almost a decade doing nothing but being a production exhaust welder and fabricator), our exhausts leverage everything we've learned about sound attenuation, piping bend and flow design, as well as power production.
Several of our early prototypes are still in use in professional and pro/amateur motor sports with consistently winning results!
Our exhausts were designed with all types of enthusiasts in mind. You're able to get our race ready version designed to produce maximum flow while still maintaining a respectable volume and tone quality. You can also opt for our fully resonated street setup that has a great tone while still maximizing their flow characteristics.
All of our kits are designed around the factory cat-back location on the 02-07 Impreza ('08 is currently being tested), and are fully dyno tested to be a wonderful add-on to our Signature series turbo kits.
Our race series cat-backs come with or without resonators, and with your choice of a stainless or titanium tipped canister. Our street series cat-back comes with a stainless tipped factory look muffler and automatically includes our high flow resonator.
All of our exhausts also include a set of high quality Kartboy exhaust hangers, as well as all applicable gaskets.
Our signature series exhausts includes a 3 year fabrication defect and perforation limited warranty*, and is backed by our standard return policies** if you are unhappy with the quality of the product.
P&L Street Series Exhaust w/ Resonator - $640
P&L Race Series Standard Tip - $599
P&L Race Series Ti Tip - $609
*Add resonator mid-pipe to Race Series for $40*
*See package insert for specific warranty details
** See P&L website for details
P&L Exhaust systems are for off-road use only
P&L Motorsports Street Series Cat Back Exhaust
P&L Motorsports Race Series Cat Back Exhaust (Stainless Tip)
P&L Motorsports Race Series Cat Back Exhaust (Ti Tip)
-Jorge
Old 10-20-2007, 06:08 PM   #6
Member#: 67199
We took a few pictures of a Ti Race Series exhaust that we just put on a customers car.
Also, please note that the carbon deposit on the bumper is from the previous exhaust system.
Here's a nice picture which shows what the resonator looks like if you choose to have that option. Also displays our GT30R kit downpipe, and how it works in conjunction with the cat back.
Some of the Standard Tip Race Series:
-Ty
Old 10-20-2007, 06:08 PM   #7
Member#: 67199
Finally! Pictures of the Street series exhausts. Thanks to Clint at TiC for letting us snap a few pictures of his car with our exhaust!
Videos and sound of all our exhausts are in post production and should be viewable here in the upcoming days.
Old 10-20-2007, 06:09 PM   #8
Member#: 67199
We also have a dyno comparison of our un-resonated Race Series cat back vs. stock WRX cat back. The car is a 2002 WRX with a simple stage 2 set up. It is a catless downpipe and a Cobb Accessport off the shelf map.
7-12 Hp gained! The results will increase exponentially as more horsepower is added.
VIDEO !!!
We now have VIDEO of our exhaust!
Race Series / unresonated -
http://pandlmotorsports.com/videos/p...eexhaust_0.flv
Street Series -
http://pandlmotorsports.com/videos/p...texhaust_0.flv
-Ty
Old 10-20-2007, 06:09 PM   #9
Member#: 67199
P&L Motorsports External Wastegate Kit
P&L's EWG setup starts off life as a high quality TurboXS up-pipe that has been setup and modified to run a high quality Tial 44MM v-band wastegate. The TurboXS down-pipe (arguably the most difficult to fit an EWG on) was used to finalize the production jig so there would be no fitment issues at all.
We listened to our customers who wanted a high quality unit compatible with the TurboXS downpipe (one of the more widely used units here in the midwest). We selected the TurboXS up-pipe as well due to its extreme high quality, quality control, and availability. Why re-invent the wheel if it's not necessary?
MSRP will be at $749 for the up-pipe, Tial 44MM wastegate (silver), dump tube, 1 bar spring, and v-band clamps.
We will also be offering the modified up-pipe and dump tube SEPERATELEY for $399!
Old 10-20-2007, 06:09 PM   #10
Member#: 67199
P&L Motorsports 780cc and 1000cc Top Feed Fuel Injector Kit
Need to upgrade your fuel system for that big turbo you want to run on your STI? P&L has a bolt on solution for you, which has been designed and tested for high horsepower applications, and is currently in use by numerous satisfied customers.
P&L Motorsports STI 780cc and 1000cc Top feed Fuel injector kit includes:
-4 top feed 780cc Low imp. injectors
-2 side feed aluminum fuel rails
-High pressure hose
-Barb fittings
-Resistor box
-Full detailed installation instructions
ECU TUNING REQUIRED
780cc Injector Kit - $699
1000cc Injector Kit - $799
Old 10-21-2007, 12:10 PM   #11
bluturbowrx
Member Sales Rating: (27)
Member#: 29779
I should have wiped down my car before you shot thoes pics, or I probably shouldn't have been doing donuts in the rain the day before. This new exhaust sounds amazing! Thanks P&L
TERRY...
bluturbowrx is offline
Old 10-23-2007, 02:25 AM   #12
V8This
Member Sales Rating: (4)
Member#: 106247
2005 Evo VIII GSR
^While I will agree it does sound nice on my car, even with the equal length headers (I hate the stock Subie sound), I was very disappointed with fitment. Just to get the exhaust to come out far enough so that it would not burn the crap out of my bumper we had to add a 3" flex to it, which is when I found out it is not a 3" inner diameter pipe, instead it is a 3" outer diameter. Before adding the flex, the exhaust was almost hitting the actual chassis and the rear subframe, this of course was fixed by manipulating the flex that we added with some extra true 3" pipe. After modding the exhaust, I was much happier with it!
V8This is offline
Old 10-23-2007, 07:42 AM   #13
RiftsWRX
Member Sales Rating: (2)
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Check the other thread you posted in Kyle.
-J
RiftsWRX is offline
Old 10-23-2007, 12:48 PM   #14
V8This
Member#: 106247
2005 Evo VIII GSR
-J
Yes, I read it and have replied. =)
I cleared up some confusion you might have.
Kyle
V8This is offline
Old 10-23-2007, 01:08 PM   #15
Member#: 67199
Kyle I wish you would have said something previously, as we would have fixed whatever problem you were having free of charge.
-Ty
Old 10-23-2007, 02:42 PM   #16
V8This
Member#: 106247
2005 Evo VIII GSR
-Ty
After how many times you guys have not helped me out, I have given up on any sort of customer service from you guys. That is why I just took action and did it myself.
V8This is offline
Old 10-23-2007, 02:47 PM   #17
Member#: 67199
I'm sorry you feel that way, but at least the opportunity to have tried would have been appreciated.
-Jorge
Old 10-23-2007, 07:52 PM   #18
see red
Member Sales Rating: (3)
Member#: 138838
A white guy with
a red car
on a happy note, Jorge, can you let me know if this would mount up to my invidia down pipe? Also let me know about a wide bamd.
brandon
see red is offline
Old 10-24-2007, 05:57 PM   #19
Member#: 67199
brandon
PM'd
-Ty
Old 10-24-2007, 05:57 PM   #20
Member#: 67199
- Ty
Old 10-26-2007, 02:55 PM   #21
Member#: 67199
Street Series -
P&L Motorsports 2008 WRX Cat back Exhaust
http://www.pandlmotorsports.com/~pan...roducts_id=355 <-- Stainless tip shopping cart link
http://www.pandlmotorsports.com/~pan...roducts_id=354 <-- Titanium tip shopping cart link
... and even we're impressed with how well it did.
Let's start off by saying that getting this right with the horrible packaging job under that car was a feat onto itself. But, I have to say that we're really proud of what we have done here.
As in all our exhausts they're a 3" diameter pipe with your choices of Titanium or standard exhaust tips, as well as an optional resonated midpipe that is actually quieter (due to the necessary shallow bends of the system) then the older year race series exhausts.
Power is definately there! 33 lb/ft of torque in the midrange, and over 15WHP towards redline!
These exhausts will be ready to ship on on 11/26/2007, and we've already received a huge interest in them, so get in soon!
As always, all our products are manufactured in house, and we take great pride in our work; so all exhausts come with our standard 3 year rust/perforation and craftsmanship defect warranty.
Please feel free to call (847-678-4311) or PM with questions.
-Jorge
Dyno plots:
Closed Thread
P&L Motorsports, we support our troops!!!---plus the product of the month P&L Motorsports Inc. MWSOC Vendor Classifieds 1 05-12-2010 02:11 PM
P&L Motorsports Signature Series Exhausts - $100 off all GD Exhausts! Thread Rating: P&L Motorsports Inc. Engine/Power/Exhaust 25 10-20-2009 12:40 PM
P&L Motorsports Signature Series: An overview of all our products! P&L Motorsports Inc. Engine/Power/Exhaust 23 12-13-2007 01:11 PM
July 4th Weekend Sale. FREE shipping on all our products! Subaru of Plano Wheels/Tires 2 07-11-2006 06:06 PM
