Old 10-20-2007, 09:09 PM   #1
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Default Help... can't get brake line off the hard line
2006 wrx wagon:
I can get the stock brake line off the hard line because there's no "hex nut" to grab onto!
The stock brake line, wear it connects to the hard line, seems to have 17mm collar which is use to hold the line in place on the chassis bracket. The collard is the only thing that seems to have anything to grip. BUT the collar is incredibly soft!! I can only grab it with a crescent wrench due to the angle and strut and wheel well liner getting in the way. I have a box wrench on the 10mm hard line's hex nut, no problem. But the stock brake line has nothing to grip.
How the heck to you get this to release?
chimchimm5 is offline   Reply With Quote
Old 10-20-2007, 10:09 PM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Unless something's changed on the newer cars you don't need to wrench anything on the flex line side - it is prevented from turning in the bracket by 'flats' on the pipe fitting - just turn the hard line flare nut
Once it's disconnected THEN you pop the flex line out of the bracket
EDIT: see Peaty's excellent thread on Scoobymods
UkNuck is offline   Reply With Quote
Old 10-20-2007, 10:28 PM   #3
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
Yes, this is key. Also make sure you use a flare wrench on that 10mm nut, it's the best (and sometimes only) way to get it loose without stripping it. A torch helps too if it's really stubborn.
boost junkie is offline   Reply With Quote
Old 10-20-2007, 11:43 PM   #4
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Thanks!! Got it off. I didn't realize that the nut spins freely from the hard line; but won't spin freely until it's cracked from the brake line.
Can't get brake caliper off fl4tsc Brakes, Steering & Suspension 8 01-16-2010 03:25 PM
Can't Get Brake Dust Off! New2Subaru! Interior & Exterior Modification 27 06-12-2007 01:16 AM
help! can't get cam pulleys off *pics* SloRice Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-06-2005 06:56 PM
Help. Can't get brakes bled using motive power bleeder wadejg Brakes, Steering & Suspension 11 08-30-2004 02:33 AM
