Old 01-18-2002, 05:03 PM   #1
jeffg
Member#: 2958
2001 WRX (GC8)
Default DOHC ecu vs SOHC ecu q's?
EJ25 questions, not EJ20
I am wondering if a DOHC ECU would work on a SOHC engine. The obvious problems I see are:
MAF vs MAP
re-ordering of the pins
more than 1 cam sensor on the DOHC?
Can anyone answer the question about what would need to be changed to make a DOHC ecu work on a SOHC engine?
What about a DOHC head swap?
Also, can anyone verify if the SOHC EJ25 is an EJ25D?
Thanks..
Jeff
jeffg is offline   Reply With Quote
Old 01-19-2002, 12:39 PM   #2
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
The DOHC and SOHC use completely differant fuel injection systems. Although they both have 1 cam sensor and 1 crank sensor, the injectors are differant, the IAC valves are differant, the TPS are differant, etc.
SubyTechMaster is offline   Reply With Quote
Old 01-21-2002, 12:11 PM   #3
jeffg
Member#: 2958
2001 WRX (GC8)
Okay, so if I was putting DOHC heads on my SOHC bottom end, I would need to also switch the injectors, fuel rails, TB (TPS and IAC), what else?
It sounds like I would need the whole upper half of the engine.
Jeff
Old 01-21-2002, 01:03 PM   #4
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
NOPE!! It'll DEFINITELY WORK BECAUSE I'VE DONE IT!! I seem to be the only one so far who has a SOHC engine in a 97 GT using the DOHC ecu! It actually ended up being cheaper for me to use to old ecu with the new engine than to try and find a newer model ecu!! If you have any questions about the swap, shoot them over to me.
Jason
2.5GT is offline   Reply With Quote
Old 01-21-2002, 01:46 PM   #5
jeffg
Member#: 2958
2001 WRX (GC8)
sent you email.
Jeff
Old 01-21-2002, 02:27 PM   #6
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
e-mailed ya back.
3B ecu vs. Z5 ecu wrxtypr Pre-2002 Factory Turbo Powertrain 6 09-19-2009 02:40 PM
United States ECU vs. European ECU fly dutchie AccessPort 1 04-29-2007 11:58 AM
02 ECU vs. 03 ECU jlogan9 Engine Management & Tuning 2 05-02-2005 12:36 AM
5mt ecu vs 4eat ecu staticfritz Engine Management & Tuning 3 04-12-2005 07:02 PM
USDM ECU VS UKDM ECU, Any differences? Spec C Wannabe Engine Management & Tuning 10 02-19-2005 07:13 PM
