Old 10-21-2007, 09:40 AM   #1
flyinghighlm
Member#: 156235
2002 Subaru WRX Wgn
Default ecuflash connection issues
I can not get ecu flash to read my ecu. I have read the sticky and followed the links. I connected the green plugs my jumper, and yes the key was on. This is the error I am recieving,
OpenPort 1.3 Subaru TX46y3wO6b0437d539f0b14e16f480a2e61c0abf91fb0f09
[09:35:59.171] denso02_bootloader_cmd_start
[09:36:00.406] denso02_bootloader_cmd_start
[09:36:01.625] denso02_bootloader_cmd_start
[09:36:02.843] denso02_bootloader_cmd_start
[09:36:04.078] denso02_bootloader_cmd_start
[09:36:04.515] kernel get version
[09:36:04.843] interface close
[09:36:04.859] interface close
What have I done wrong?
flyinghighlm is offline   Reply With Quote
Old 10-21-2007, 10:10 AM   #2
flyinghighlm
Member#: 156235
2002 Subaru WRX Wgn
Somehow I think I might have ordered the wrong tactrix cable. Which one should I have, openport universal or drive by wire?
Old 10-21-2007, 10:27 AM   #3
Tea cups
Member#: 103136
Read the entire section here (especially the 2nd and 3rd item):
http://www.enginuity.org/Documentati...nuityFAQ#toc12
Tea cups is offline   Reply With Quote
Old 10-21-2007, 10:44 AM   #4
flyinghighlm
Member#: 156235
2002 Subaru WRX Wgn
thank you very much, long story short I am an idiot and did not have the key far enough forward for it to read, I had it in the accessory position, not "ON" like it says.
Old 10-21-2007, 10:50 AM   #5
flyinghighlm
Member#: 156235
2002 Subaru WRX Wgn
Ok, so on to my new issue. I purchased the stage 2 map from XPT and its now telling me its the wrong size????
[10:47:54.546] image file is incorrect size.
Old 10-21-2007, 11:08 AM   #6
Tea cups
Member#: 103136
Likely you are not opening the rom but something else, maybe the .xml defs that XPT supplies for you (that should be placed in the openecu\ecuflash\rommetadata\subaru folder). You should be opening most likely a .hex file (or possibly .bin).
Old 10-21-2007, 11:18 AM   #7
flyinghighlm
Member#: 156235
2002 Subaru WRX Wgn
xpt2eo1c91oct.hex is the name of the file, I recieve an error saying that ecuflash can not reconize this rom image using any of the current definitions, you can choose from one of the following,
abort
continue using without def
use wizard to create a new def
Old 10-21-2007, 11:31 AM   #8
Tea cups
Member#: 103136
you should have received a .xml file when you purchased the xpt map. It needs to be installed in the directory I mentioned in the previous post.
Old 10-21-2007, 12:01 PM   #9
flyinghighlm
Member#: 156235
2002 Subaru WRX Wgn
Where is that at or how do I make it go there? I do not see a .xml file there, all I see is 2 adobe files, a 91 and 93 map and one other thing but when I click on that one its just computer code.
Old 10-21-2007, 12:17 PM   #10
MasterKwan
Member#: 98961
2003 WRX
It's an intelligence test. If you can't figure this out by reading the instructions, it means you shouldn't be attempting to flash your own ECU.
Old 10-21-2007, 12:24 PM   #11
flyinghighlm
Member#: 156235
2002 Subaru WRX Wgn
thank you for the nugget of wisdom
Old 10-21-2007, 12:32 PM   #12
Tea cups
Member#: 103136
Are you running windows? In explorer, go to Tools -> Folder Options -> View and uncheck 'hide extensions for known file types'. This should show you the extension of each file.
Old 10-21-2007, 12:51 PM   #13
flyinghighlm
Member#: 156235
2002 Subaru WRX Wgn
Thank you very much, I can work on cars and do all that stuff but this EM is a whole new thing for me so it takes time to learn it.
I am running windows xp right now, however I have to go to go to work. Sucks being at one of the only dealerships open on a sunday but oh well.
Old 10-21-2007, 01:50 PM   #14
MasterKwan
Member#: 98961
2003 WRX
It was a joke but, you took it very well.
Old 10-21-2007, 08:09 PM   #15
flyinghighlm
Member#: 156235
2002 Subaru WRX Wgn
Thanks Tea Cup, I got it all figured out and wow, what a difference that makes with the car.
internet connection issues, cant figure it out David Medina Off-Topic 12 05-02-2008 08:17 PM
Hey Geeks!: dell laptop connection issue skimmilk68 Off-Topic 3 01-16-2007 01:07 AM
Fueling and ECU Connection Issues UTCiv Subaru Conversions 2 04-06-2006 07:41 PM
Will the OT suck today because of connection issues? The Tree Off-Topic 23 03-08-2006 11:39 AM
UTEC connection issues gossamer_monster Engine Management & Tuning 1 10-16-2003 06:53 PM
