Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 10-21-2007, 07:42 PM   #1
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Default PERRIN - 2008WRX: Turbo Kit
Click Here to return to the links page
Of course we had to put a PERRIN rotated turbo kit on this car. The only question was which turbo? On the internet forum boards, everything is all about the GT3582R turbo. This is a great turbo that makes big power but it’s not my personal choice. The last two cars I had were built to be very responsive. For this build the GT3582R is too laggy and does not make for a good autocross/street car.
The turbo for me is the GT3071R, a bit smaller, bit more responsive, and still able to make 400WHP. We always tell people to buy the smallest turbo that supports your HP goals. We want to showcase the power that can be made on pump fuel and then on water injection.
To create a turbo kit for the 2008 WRX I had to design a new down pipe which was longer and must clear the fire wall. I designed these changes to also work with the new Legacy GT so be on the lookout for that turbo kit soon. The single most important part of this turbo kit was adding a CARB approved catalytic converter. Many consumers think that the only way to make power is by getting rid of cats. This is just not the case and with our last couple of PERRIN project cars, we had cats installed, and they both still made great power.
As the rotated turbo kit was being built right on the 2008 engine, we quickly discovered that the intake system had to be completely redesigned. So a few 3" bends, welding, and more of that red wrinkle finish! Just like our new turbo kits for the older cars, the air filter is now located in the fender well area to get the freshest coolest air possible.
PERRINJeff is offline   Reply With Quote
Old 10-21-2007, 07:42 PM   #2
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Old 10-29-2007, 11:14 AM   #3
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
what exhaust housing?
Capt Crunch is offline   Reply With Quote
Old 10-29-2007, 02:56 PM   #4
sharkmonkey
Member#: 118566
2005 WRX
Do you think people are really ready to remove material from the transmission to get your products to fit? I wouldn't think you would sell much that way.
sharkmonkey is offline   Reply With Quote
Old 10-29-2007, 08:29 PM   #5
EPskate
Member#: 84800
02 wrx rip / 05
sti
If they make the decision to sell this as a bolt on kit I'm sure the downpipe will be redesigned so you would not have to remove material off the transmission.
EPskate is offline   Reply With Quote
Old 11-12-2007, 01:24 AM   #6
minhha2006
Member#: 154914
2005 WRX
UGM
where can i get that red wrinkle finish?
minhha2006 is offline   Reply With Quote
Old 11-12-2007, 10:48 AM   #7
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
I believe you have to do it with their other kits depending what 6 speed you have. People are constantly saying their kits do not fit well at all. I haven't personally tried yet.
garface is offline   Reply With Quote
Old 11-12-2007, 02:43 PM   #8
garface
Member#: 1581
MY00 RS/STi7
Is that the same finish as the APS pipes?
Old 11-14-2007, 12:56 PM   #9
PERRIN
NASIOC Manufacturer
Member#: 6776
Sorry, i missed these posts!
All of our kits use the newer Gt housing. This was a recent change to every kit.
While we do have a couple changes to do before the 2008 parts fit, moving the entire system over to fit the 5spd may not happen right away. The amount of material removed is very little, and took about 5min of work. The pics are a little exaggerated as to the amount of material. The kits were all meant to fit the STI (2.5L engines at the time) then secondly the 5spd cars. The 5spd cars are becoming more and more popular so this motivates us to make it fit these even better. But off all the people that have installed them on 5spds (besides not getting the oil line they needed) the tranny issue is not something customers complain about.
We offer this on almost every part now. The boost tubes, intakes, and other items are all starting to come in wrinkle red.
The only people that have issues with hitting the tranny is the 5spds and some 2005 6spds. There are some models that have some strange part in the casting that sticks out for no reason. If customers have problems and they called us, we took care of them. But like alot of things on the net, they get blow way out of proportion. We don't hide that we had some that didn't fit well, but customers were taken care of. Its silly to think that all have problems. With our newer kit we have also changed some things to help add clearance for the normal tolerance changes when welding. So the few problems once seen on the older ones, have gone away.
Its the same finish as the STI intake manifold. Its a wrinkle red powdercoat. We have even done this for existing customers that have polished pipes and what not.
PERRIN is offline   Reply With Quote
Old 12-10-2007, 08:47 PM   #10
tunermt
Member#: 158767
yes slowly i see all the 08 parts coming out, i must say the perrin set up is very clean! will you offer the kit with a non catted down pipe?
tunermt is offline   Reply With Quote
Old 01-21-2008, 11:21 PM   #11
Le Saboteur
Member#: 142244
2007 SWP STi
WFC #243
very sexual
Le Saboteur is offline   Reply With Quote
Old 01-22-2008, 11:21 AM   #12
PERRIN
NASIOC Manufacturer
Member#: 6776
Might for race only setups. Likely not to have a flange at the rear to work with race only exhaust systems.
More to come!
adam.taft@perrinperformance.com
Old 02-19-2008, 06:09 PM   #13
GDB-E-06
Member#: 139721
Free Speach
Mother****ers
Pretty sweet looking guys.
GDB-E-06 is offline   Reply With Quote
Old 02-20-2008, 01:25 AM   #14
dubya-R-ex
Member#: 113698
SWEET! looks like one of the first real kits to come out.
dubya-R-ex is offline   Reply With Quote
Old 02-20-2008, 01:30 AM   #15
PERRIN
NASIOC Manufacturer
Member#: 6776
Yup should be out VERY soon! Final development on the STi and WRX is continuing! Thanks for the kind remarks!
Adam.Taft@perrinperformance.com
Old 02-26-2008, 12:03 PM   #16
shakur45
Member#: 165106
2008 WRX Stage 1
Obsidian Black Pearl
Talking
I can always trust you guys to ROCK the 08 first...
shakur45 is offline   Reply With Quote
Old 02-27-2008, 01:58 PM   #17
PERRINJeff
NASIOC Manufacturer
Member#: 74110
We were the first! Awesome you noticed! The 08 WRX parts are starting to roll in so keep an eye out!
Old 03-23-2008, 07:04 PM   #18
speed51133
Member#: 168617
do you have any pics of the exhaust manifold?
does it use the original one?
speed51133 is offline   Reply With Quote
Old 03-24-2008, 12:45 PM   #19
PERRIN
NASIOC Manufacturer
Member#: 6776
uses the OEM exhaust manifold or our updated header system. Either one work well with the kit.
Thanks for asking!
Old 04-18-2008, 08:26 PM   #20
RC0310
Member#: 63479
08' WRX
Any updates/pricing on turbo kit?
RC0310 is offline   Reply With Quote
Old 04-20-2008, 11:02 PM   #21
PERRIN
NASIOC Manufacturer
Member#: 6776
The kit is on several cars right now finishing beta testing. Production will begin very shortly. I would expect pricing to the same as our current prices on 07 WRX/STi kits.
Let me know if I can help further!
Thanks again!
Old 02-08-2009, 11:12 PM   #22
tscharf18
Member#: 195383
2004 PSM WRX
2011 yamaha R1
cant wait till the kit comes out
tscharf18 is offline   Reply With Quote
Old 02-17-2009, 09:49 PM   #23
kwilson36
Member#: 67449
03 VF22, TXS FMIC
EcuTek, Catless...:)
What exactly will the kit include?.
Will it be like the "complete rotated turbo kit" you presently offer: http://www.perrinperformance.com/pro...Kit?category=5
... header.... accessport.... all the goodies. With a great knock the competition out of the game price...
Do we have a date yet for all this creammy goodness to hit the market?.
kwilson36 is offline   Reply With Quote
Old 02-18-2009, 03:19 PM   #24
PERRIN
NASIOC Manufacturer
Member#: 6776
Thanks for asking. The 08 STI kit is out now. The WRX should be within the next 3-4 weeks. (Pressure PERRINJeff with PM's to make it move faster!!!!)
On the link above, we haven't designed that complete of a package yet for either the 08 STI or the WRX BUT it will be done shortly. In the meantime the kits being released would be the Rotate Turbo Kit, but not with the ancillary items. CLICK HERE for an example.
Hope that helps!
Let me know!
Old 02-20-2009, 04:18 PM   #25
kwilson36
Member#: 67449
03 VF22, TXS FMIC
Thanks for the response.
Ok... so to clarify. No "ancillary items" as yet are packaged with the rotated turbo kit itself.... which would be:
1) Front Mount Intercooler: (Does the one that is offered on the website for the 08 Sti have adapted piping for the rotate mount setup?).
2) Fuel Rails: (I see that it is a recommended upgrade from the turbo kit link for the 08 Sti).
3) Turbo Inlet hose.
4) AccessPort: (Are there maps that you have created for the whole setup... rotated turbo kit, fuel rails.
This leads me to another question. Does either the 08 WRX or Sti need injectors and or fuel pump upgrades for this setup.
Thanks again.
FS MD: Perrin Rotated Turbo Kit (Minus the Turbo & WG) 9vapors MAIC Private Classifieds 9 06-13-2011 08:23 PM
Perrin FMIC, Perrin GT3076r turbo kit, Helix catted DP crashnscar Engine/Power/Exhaust 30 08-15-2008 10:11 PM
FS MD: Perrin Rotated Turbo Kit (Minus the Turbo & WG) 9vapors Engine/Power/Exhaust 9 06-01-2008 02:58 PM
Can the Perrin GT turbo kit work with a TMIC? Capt Crunch Factory 2.0L Turbo Powertrain 3 02-12-2006 06:50 PM
Perrin GT30r Turbo Kit midnightsti Factory 2.5L Turbo Powertrain 7 10-20-2005 06:02 PM
Message Board Statistics All times are GMT -4. The time now is 08:03 PM.
