Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 10-21-2007, 07:52 PM   #1
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Default PERRIN - 2008WRX: Front Mount Intercooler
Click Here to return to the links page
As always the starting point to the front mount Intercooler is getting it mounted to the car. Starting with one of our Steel Legacy GT I made a few simple cuts, some welding, and beam was done.
In order to get the intercooler to fit, I had to modify some of our WRX end tanks to allow them to fit tighter to the beam. I just grabbed a set with no holes and re-drilled them where I needed it.
With the core mounted, plumbing was next. Every tube on the 2008 WRX FMIC is completely different than any tube from our other front mount intercooler kits.
A little welding, grinding and off to the powder coaters they went for that perfect, STI wrinkle red finish!
PERRINJeff is offline   Reply With Quote
Old 10-21-2007, 07:53 PM   #2
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Old 10-22-2007, 11:56 PM   #3
vtboost
Member#: 155580
2002 w/ 04 front end
& STi drivetrain
HOLY PIPING BATMAN project 2008wrx is looking good. is this the blueprint thats going to be the otc product?
vtboost is offline   Reply With Quote
Old 10-23-2007, 11:02 AM   #4
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Yes, it is! That is the exact thing you will see for the 2008 WRX, and maybe the STI. The only thing that might be different is the parts will look better than the proto!
Old 11-04-2007, 06:48 PM   #5
wuuusaa
Member#: 92894
2015 Wrx
very good job, more pics of intercooler on car please
Old 11-05-2007, 11:30 AM   #6
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Here is one for you!
Old 11-05-2007, 01:34 PM   #7
wuuusaa
Member#: 92894
2015 Wrx
Thanks for pics, now is the fmic the same as the lgt fmic design?
Old 11-05-2007, 09:35 PM   #8
PERRIN
NASIOC Manufacturer
Member#: 6776
Well yes and no. The PERRIN WRX, STI and Legacy GT FMIC all share the same core. But that is where most similarities end. The bumper beams are different from the early WRX/Sti vs. the Legacy GT vs. the new WRX/STi. We certainly use similar plumbing sizes, couplers, clamps etc. What we don't do is force the wrong part into a place it doesn't belong. Hence in Jeff's how to you can see the painstaking work involved in creating the proper endtanks, beams etc.
Also, little side note, his car was just featured in KONIG wheels booth at SEMA. We just got it back yesterday and we will have more photos coming soon. PLUS we have signed a contract directly with KONIG to offer some exciting new style of wheels through the PERRIN website to our clients like YOU! Stay tuned!
[email protected]
PERRIN is offline   Reply With Quote
Old 12-08-2007, 08:32 PM   #9
PropBoyBlu
Member#: 148020
BugI WRX Wagon
Battle-Tested Blu
Perrin FMIC ftw!
Plastic Intake Manifold ftl
PropBoyBlu is offline   Reply With Quote
Old 12-10-2007, 11:43 AM   #10
PERRINJeff
NASIOC Manufacturer
Member#: 74110
PIM..............FTW!
Smoother inside, bigger inside, lighter, won't blow up...
The only down fall is it looks funny.
Since i had to look up what FTW means, i decided to make up my own. PIM. Plastic Intake manifold.
Old 01-14-2008, 09:05 PM   #11
HeliKelby
Member#: 168742
1998 Legacy GT
Such quality work, I love it
HeliKelby is offline   Reply With Quote
Old 01-14-2008, 10:18 PM   #12
PERRIN
NASIOC Manufacturer
Member#: 6776
Hey thanks!
Old 04-08-2008, 12:45 AM   #13
BMonkey
Member#: 176893
Perrin Jeff, looking at the piping returning from the intercooler to the TB, when the hood is closed, is this positioned directly in the path of the incoming air from the now vacant hood scoop?
I was thinking that if you mounted a few of those ARC cooling fin units on the pipe thats about 8" long (guesstimating) between the two silicone couplers under the scoop and possibly drop the temperature of intake charge some more.
Here's a little article on them from Turbo magazine, not sure if you're familiar with the product
http://www.turbomagazine.com/tech/08...fin/index.html
BMonkey is offline   Reply With Quote
Old 04-10-2008, 10:47 AM   #15
CO WRX
Member#: 8719
2008 06 FXT, 08 STi
Grey, White
What is the ETA for the FMI on the STi?
CO WRX is offline   Reply With Quote
Old 04-10-2008, 12:35 PM   #16
PERRINJeff
NASIOC Manufacturer
Member#: 74110
This is a long standing argument people have with boost tube routing and that going over the turbo is bad. But when cruising down the road, there is enough air flow over that tube that its not an issue at all. Those cooling fin things are cool, but putting them on a tube isnt going to change the temps that much. If you think about it, the tube has very little surface area touching the air in the tube. Esspecially compared to an intercooler where the fins touch alot more of the air. So while it will cool the air, its not going to do much. But at the same time its not going to hurt things either. On a fluid filled thing, i would say those are a good idea.
Old 04-10-2008, 12:37 PM   #17
PERRINJeff
NASIOC Manufacturer
Member#: 74110
The FMIC's will be shipping in about 5 weeks. You may have seen a couple floating around, or on Subiesports cover, but these were prototypes we made to start building hype on the part. In the next few days we have some really good results with stock FMIC vs. PERRIN TMIC, vs PERRIN FMIC. Should be good!
Old 04-18-2008, 05:51 PM   #18
beaudawg
Member#: 57770
2005 Audi S4 Avant
Arctic White
Any chance you'll tweak the routing so it doesn't go over the top of the oil filler?
beaudawg is offline   Reply With Quote
Old 04-20-2008, 11:19 PM   #19
PERRIN
NASIOC Manufacturer
Member#: 6776
Things are TIGHT in this engine bay. So there will be some close quarters on this pip, but it isn't directly on top of it either. you can still remove the filelr cap, and fill the engine easily. But you might be forced to use a funnel (but shouldn't you anyway in all cases to prevent getting oil all over you pretty engine?)
Let us know if we can help in anyway further!
[email protected]
Old 04-21-2008, 12:58 PM   #20
beaudawg
Member#: 57770
2005 Audi S4 Avant
Arctic White
Good to know the filler is still accessible without removing any of the FMIC piping. That was my main concern.
Old 06-02-2008, 02:38 PM   #21
mixinitup
Member#: 165871
2015 wrx
red
wow looks great any plans on a project 4 door 2008 wrx you can use mine
http://
mixinitup is offline   Reply With Quote
Old 07-27-2008, 10:07 PM   #22
PERRIN
NASIOC Manufacturer
Member#: 6776
http://
We did! And in fact that test mule is now available for purchase:
CLICK HERE
ADAM TAFT
Adam Taft
CEO
PERRIN Performance™
503.693.1702 Ex. 110
WWW.PERRINPERFORMANCE.COM
WebsiteBlogMyspaceE-mailAIM
Old 07-27-2008, 10:09 PM   #23
PERRIN
NASIOC Manufacturer
Member#: 6776
These are available NOW!
CLICK HERE
ADAM TAFT
Adam Taft
CEO
PERRIN Performance™
FS/FT : 02-07 wrx/sti front mount intercooler NocturnalRacing Engine/Power/Exhaust 1 07-13-2011 03:42 PM
FL: Perrin polished front mount intercooler the2.5insider Engine/Power/Exhaust 20 05-15-2009 11:46 AM
Perrin Front Mount Intercooler SS (wrinkle red Piping) W/ Perrin Intake PENNYWISE330 Engine/Power/Exhaust 7 10-19-2008 09:43 PM
Perrin Performance Front Mount Intercooler Sneak! vividracing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 137 08-18-2003 06:17 PM
