Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 10-21-2007, 08:24 PM   #1
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Default PERRIN - 2008WRX: ECU if you can find one
Click Here to return to the links page
Hydra was kind enough to give us their first custom ECU for the 2008 Subaru's. Andrew (Hydra head honcho) sent us 2 harness to try out on the car. The first harness completely removed the OEM ECU. Unfortunately all the new cars have immobilizers which will not let the ignition switch work without the OEM ECU being turned on. So we used the second special pass through harness that kept the OEM ECU in place.
I created a base map using Hydraís 2006 WRX base map and a fuel map from tune a long time ago. The car fired right up and it was time to take it for the maiden voyage!
PERRINJeff is offline   Reply With Quote
Old 10-21-2007, 08:25 PM   #2
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Old 10-29-2007, 12:25 AM   #3
choloman05
Member#: 99359
02 wagon
blackish-blue
AND...?! Can't wait to hear about this.
choloman05 is offline   Reply With Quote
Old 10-30-2007, 12:52 PM   #4
PERRINJeff
NASIOC Manufacturer
Member#: 74110
This is where all of the links are for each part of the build
CLICK HERE
Also look HERE and you can see the entire story.
Old 10-30-2007, 02:12 PM   #5
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
stock trans!!!!!!!!!!!!!!!!!!! curious on how its holding up?
bluemax189 is offline   Reply With Quote
Old 10-30-2007, 06:19 PM   #6
PERRINJeff
NASIOC Manufacturer
Member#: 74110
So far so good! It is confirmed that it uses the same gears from the older 5spd RA gearsets. So that is a good thing! Thanks to Jeff Sponaugle for that bit of info!
Old 04-21-2008, 10:32 PM   #7
ACRTrexguy
Member#: 145576
04 wrx sdn
Hold up just one sec... this may not be the right thread but... I MUST HEAR MORE ON THIS!!!
subaru said that the 08's are as listed below
(http://www.driveperformance.subaru.c..._2/feature.asp)
1st gear: 3.166
2nd gear: 1.882
3rd gear: 1.296
4th gear: 0.972
5th gear: 0.738
and i found this right here on NASIOC about the 5spd STi RA ratios:
3.083 (1st)
2.062 (2nd)
1.545 (3rd)
1.151 (4th)
0.825 (5th)
so did things change for some years? or is somebodys info wrong? (mine most likely) because if Jeff is right, then the cost of a new 08 tranny is very good compared to an RA gearset. and if they use the old gears in the new cars, then the gears should be stronger and better ratios compared to our "glass trannys" in older 5spd WRX's. also being that everything is leggy based now, that must mean that the 08 trans is the weaker push type clutch, or am i misinformed on that too?
if anybody could clarify, please do so!
ACRTrexguy is offline   Reply With Quote
REWARD IF YOU CAN FIND THE OWNER of this ULTIMATE GF RaceComp Engineering Member's Car Gallery 87 09-02-2016 04:39 PM
$5 by paypal if you can find it zulater Off-Topic 4 01-05-2010 10:27 AM
OT: I'll give you a cookie if you can find this info... mav1c Mid Atlantic Impreza Club -- MAIC 12 07-07-2009 07:42 AM
If you can find me this SNL skit online....I'll give you a dollah!!! GooseMan Off-Topic 4 06-11-2007 10:50 AM
Looking for an old episode of HBO's REVERB, paypal 10 bucks if you can find it. munkis Off-Topic 0 10-29-2005 08:06 PM
