Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 10-22-2007, 10:51 AM   #1
boyleia1
Member#: 141519
1997 OBS
Colbolt Firemist Blue
Default 2.2l Engine whistle at high RPM
Hello,
I have a 1997 OBS with 185000 miles on it and it is making a weird noise. The engine will whistle at high RPM. I can drive the car half throttle from 0 to redline and not hear the noise but at about 3500 or so if i am at full throttle the engine will hiss or whistle. it sorta sounds like a tea pot heating up. the noise stays the same pitch until it hits about 5800 than it changes to a higher pitch whistle. Does not seem to have anything to do with the speed only RPM. My Mechanic said it was nothing more than air coming in through a hole in the firewall but speed has nothing to do with the noise so i thought i would put up this post and see if anyone knew anything.
boyleia1 is offline   Reply With Quote
Old 10-22-2007, 10:58 AM   #2
deadlydave
Member#: 131119
1996 Impreza LWRXSTI
91 BMW 318is
It's nothing major, my legacy did the same thing. So no worries.
-Is your intake completely stock?
+Look for the air intake silencer box in the fender. Without this, it'll whistle
-Are you running a K&N stock replacement filter?
+Mine added to the whistling noise generated by removing the air intake silencer from the fender.
Hope this helped.
deadlydave is offline   Reply With Quote
Old 10-22-2007, 12:27 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
My 97 OBS does the same thing. I have not been able to find an intake leak, and the engine seems to run fine. The only other things I've noticed is the exhaust sort of makes a putting sound....and the gas mileage is so-so. 19-22 mpg in city with 10% ethonal
Legacy777 is offline   Reply With Quote
Old 10-22-2007, 01:50 PM   #4
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
At around 100k miles, I remember hearing a whistle. I didn't bother to conciously look for it...
but after I changed the midpipe and axleback I noticed it was gone. :shrugs:
bl_easy is offline   Reply With Quote
Old 10-22-2007, 02:12 PM   #5
renyo
Member#: 93577
98 Impreza
My 98 L has a whistling kind of sound around 2500-?? at one point the rest of the engine gets too loud for me to hear it.. I'm pretty sure it's intake related cause if I take my foot off the gas for as little as a second it goes away.. then when I push the gas again it comes right back... No clue where it's coming from either.. everything is tight..
renyo is offline   Reply With Quote
Old 10-22-2007, 06:22 PM   #6
99Lcoupe
Member#: 75789
the sound is cool ...make people think u have a supercharger.
99Lcoupe is offline   Reply With Quote
Old 10-22-2007, 09:11 PM   #7
boyleia1
Member#: 141519
1997 OBS
I just replaced the intake with a cone filter but not a complete intake, just the filter. my gas millage is also bad 18-20 in the city. the noise was there before and after i replaced the filter. the intake in the fender is no longer in use but it is still there. I don't know if no one thinks its anything problematic i will probably just leave it alone even though it gets annoying at times.
Old 10-23-2007, 12:36 PM   #8
Locky1138
Member#: 73285
2004 cobb Stg2 WRX
theres your issue, all of the cone filters i've ever heard whisltle and moan like crazy. its the cone filter, and its working as intended.
Locky1138 is offline   Reply With Quote
Old 10-23-2007, 12:45 PM   #9
Legacy777
Member#: 4800
He said
Originally Posted by boyleia1
...the noise was there before and after i replaced the filter...
Old 10-23-2007, 12:52 PM   #10
Locky1138
Member#: 73285
2004 cobb Stg2 WRX
disreguard that >_>
Old 10-24-2007, 02:29 AM   #11
jtram2
Member#: 160330
Question PLEASE HELP 2.2 won't start
I just completed some major work on my 96 2.2 Impreza. It won't start at all now and I have a question:
I knocked one of the teeth off of the center timing belt sprocket while taking it off. Would this alone affect the sensor and cause the engine not to start?
Also, please give me a definitive answer on how to line up the camshaft pulleys and the main center sprocket (referred to in question 1) to set the timing correctly.
I am a newbie, and any help would be greatly appreciated. This site has helped me alot in this process.
Regards,
-Joe
jtram2 is offline   Reply With Quote
Old 10-24-2007, 04:37 PM   #12
Storm
Member#: 5218
96L Most Over-
Developed Beater
It's definately going to cause a problem. I have a few spares if you need one, PM me. The timing marks on the cam pulleys line up with the notches on the backside of the timing covers.
Regards,
-Joe
Jay Storm
Engine "stutters" at high rpm and after corners? Help please masterpickle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 09-03-2008 02:57 PM
engine hesitates at high rpm tsukuba speed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-24-2007 05:36 AM
chek engine light at high rpm bigislandracing Off-Topic 18 07-19-2007 07:22 PM
Engine sputter at high RPM? kenithzs Normally Aspirated Powertrain 4 06-29-2006 06:40 PM
Need Help - loud whistle at high rpms Mephisto318 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-21-2003 11:28 AM
