Old 01-18-2002, 10:34 PM   #1
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
Default WARNING. If you have installed an aftermarket fuel pump PLEASE READ.
I just had a VERY scary experience installing my PE fuel pump.
I felt I needed to post this right away. If you have an aftermarket fuel pump on your WRX you must Check the size of the lugs on the connection of the pump. Even though the connector might look the same from the outside the lugs or connection point might be different.
On the PE pump the connector is identical except for the fact that the stock lugs are 1/4 inch in size and the PE pump has 1/8th lugs. This caused a loose fit and ARCING! The pump and connector are INSIDE the fuel tank.
Serious injury or even death may result if the fuel is ignited. Especialy if the tank is near empty.
PLEASE CHECK YOUR AFTERMARKET PUMP!
CT
AZScoobie is offline   Reply With Quote
Old 01-18-2002, 10:56 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Solder the wires directly to the pump terminals... you won't have to worry about arcing . How often are you going to need to change a fuel pump ?
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
Old 01-18-2002, 10:59 PM   #3
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
Brian
You missed the point. The PE pump is a direct replacement pump. There are no terminals to get to. You cant solder to this pumps connector. The connector is vulcanized into the housing and there is a plastic guard over those parts.
CT
Old 01-18-2002, 11:02 PM   #4
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
True!
Good thing this post came out. I was just about to order one!
Leo
PS- Sticking it for like a week so it gets arround!
Leonardo is offline   Reply With Quote
Old 01-18-2002, 11:07 PM   #5
GoodFinder
Member#: 8943
2006 MINI + Corvette
Both Blue
... wow ... thanks for the post ...
GoodFinder
GoodFinder is offline   Reply With Quote
Old 01-19-2002, 01:43 AM   #6
JenisonWRX
Member#: 6049
02 WRX & 99 RS
well now I'm REALLY waiting to install this pump.
AZ...how did you see it was arching???
JenisonWRX is offline   Reply With Quote
Old 01-19-2002, 05:46 AM   #7
xphilxcorex
Member#: 12462
02 wrx sedan
wr blue 200ALTR
Default hmmmm
just my 2c but...
my walbro/bbk fuel pump for mustang fits perfect.
and the connectors clip in and are the right size even...
the best thing is... i bought it from summit racing so they of course had it in stock and it was only 115 bucks for a 255 lph.
just for people who are now afraid fo that style pump...
this was a good alternative.
thanxxx
ahren
p.s. good lookin out!
xphilxcorex is offline   Reply With Quote
Old 01-19-2002, 12:01 PM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
soo i am still confused?
is there a solution to this proublem
or are you saying that the connector on the PE fuel pump is WRONG and can cause arcing -->fire
Old 01-19-2002, 01:30 PM   #9
WeRX
Member#: 3652
1989 Honda Pirate
Type RRRRRR
That sounds eerily similar to what is suspected to have brought down TWA flight 800.
Article
WeRX is offline   Reply With Quote
Old 01-19-2002, 09:48 PM   #10
aspera
Member#: 7879
xphilxcorex,
Tell me more of this Walbro pump. Is it the same Walbro pump available from several Subaru vendors? What is the Summit part number and such? $115 is a good price.
I'm looking for a pump that fits PERFECTLY.
aspera is offline   Reply With Quote
Old 01-20-2002, 07:37 AM   #11
xphilxcorex
Member#: 12462
02 wrx sedan
wr blue 200ALTR
Default hmmmmm
this pump is a perfect clip in replacement. no modifications neccessary.
part number
bbk1607. that is a summit racing part number.
it keeps pressure the same as stock but flows much more.
it is a 255lph pump.
not sure if it is same part as what the other scoobie guys are running... but you could easily find out if it is by calling whoever it is and giving that part number.
hope this helps... if not just ask more questions...
thanxxx
ahren
Old 01-20-2002, 12:47 PM   #12
Fast Reggie
Member#: 10625
Black - TXS Stg 4+
Got my Walbo replacement TT pump here, part # GSS341:
http://www.autoperformanceengineering.com/
Same thing, fit without problems, and was about $115 shipped from TX to VA. Another option, especially if you're close to TX.
Fast Reggie is offline   Reply With Quote
Old 01-21-2002, 12:02 PM   #13
Sophocles
Member#: 7794
Default PE user
Reggie, I don't see that part number listed on his site.
Can you double check?
Thanks!
Dan
Sophocles is offline   Reply With Quote
Old 01-21-2002, 01:45 PM   #14
Greenracer6
Member#: 7962
08 335i TwinTurbo
PSM 02WRX, 97 Dipped CRV
Default How fuel is needed?
If you have a turbo upgrade eg PE1820f and 15psi
550 or 620cc injectors, what size pump would we need anyway?
255 or higher?
Greenracer6 is offline   Reply With Quote
Old 01-21-2002, 09:20 PM   #15
phooka
Member#: 8486
2002 Impreza WRX
Regarding the sparking issue.. It's a good point, however very easy to fix. I installed my PE pump today, and yep - sure nuff the connector was loose enough that it could have sparked. However, simply inserting a sharp object under the connector to bend it helped to make a very tight connection. (makes more sense if you see it).
dale
phooka is offline   Reply With Quote
Old 01-21-2002, 11:55 PM   #16
Fast Reggie
Member#: 10625
Black - TXS Stg 4+
Default Part # for Walbro Pump
Dan,
Took that off the box the pump came in. Someone else told me the same thing, but APE sells two TT replacement pumps. Best to call them, because one supports higher pressure than the other.
Reggie
Old 01-23-2002, 02:10 AM   #17
pbnj9786
Member#: 4473
MY10 STi
Plasma Blue Pearl
cool,
i was thinking about the PE fuel pump, but am glad to have the walbro unit in my hands instead. injectors, vishnu rail/regulator kit, and unichip here i come.
pj
pbnj9786 is offline   Reply With Quote
Old 01-24-2002, 04:57 PM   #18
SkirtBoy
Member#: 11056
2012 MB C250 CPO
Black on Tan
Default Re: hmmmm
Ahren,
I got the same pump from www.jdsperformance.com for $109 - part no. is WAL255HPM
Allan
Originally posted by xphilxcorex
just my 2c but...
thanxxx
ahren
SkirtBoy is offline   Reply With Quote
Old 01-24-2002, 09:07 PM   #19
Greenracer6
Member#: 7962
08 335i TwinTurbo
Default hp????
How much hp is possible with a 255Wal fuel pump.
What size injectors?
Old 01-25-2002, 12:47 AM   #20
aspera
Member#: 7879
WAL255HPM shows to be a GSS340, not a GSS341 at www.jdsperformance.com.
Old 01-25-2002, 11:01 AM   #21
SkirtBoy
Member#: 11056
2012 MB C250 CPO
Black on Tan
Yep, it's the Mustang 255 LPH pump.
Old 02-02-2002, 05:32 PM   #22
geronimo
Member#: 6910
1988 Mustang
Purple
I know this is a little off topic, but I have noticed that in some cases you can use domestic pasrts that are easy to find a not to pricey. Has anyone looked into other injectors.. ie SVO or the like.
I don't know the price of high capacity WRX injectors but mustang injectors aren't very expensive. You can get 8 30#ers for $200, or 42#ers for like 450ish.
I knoe 42#ers would be large enough, since they will support a blown 5.0 making over 500fwhp
geronimo is offline   Reply With Quote
Old 02-02-2002, 08:58 PM   #23
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
Yeah. But there are eight of them.
CT
Old 02-06-2002, 02:57 PM   #24
Yellow Rex
Member#: 6725
2002 IMPREZA WRX
BLAZE YELLOW
Actually they make 0 fwhp. All the power in those cars goes to the rear wheels
Yellow Rex is offline   Reply With Quote
Old 02-08-2002, 08:42 PM   #25
AHP Products
Member#: 13956
Default Vishnu Rals, Reg?
pbnj9786 Wrote; Vishnu Rails and Regulator Kit.
I went to their site and didn't see any of those products. Actualy I didn't see much of anything. Am I missing Something?
Chris Anderson
AHP Products
AHP Products is offline   Reply With Quote
If you are a regular online-poker player please read... Drink Off-Topic 4 08-01-2007 11:27 PM
If you own COBB springs on 06 STI, please read TheSilverFox Brakes, Steering & Suspension 8 06-13-2007 06:50 PM
If you removed factory belts for race prep, please read this H2OSB Motorsports 6 03-31-2006 09:52 PM
If you sent me a E-Mail recently .... please read Luke@tirerack Brakes, Steering & Suspension 3 09-28-2001 06:20 PM
If you are going to Cherokee Trails Rally, please read! crash General Forum Archive 0 03-13-2001 01:57 AM
