Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 10-23-2007, 11:21 AM   #1
TheSilverFox
Member#: 142520
2006 STI - Protuned
308whp - SilverFox
Impreza WRX STi What to use to clean the inside of the tranny??
Need some recommendations here guys...
took a tranny apart and it's filthy inside (where the clutch is).
what products / methods should i use to clean it??
i was thinking of just spraying it down with brake cleaner and then wiping. also maybe some acetone to finish her off.
any other suggestions? what has worked for you best?
thx in advance.
--J
TheSilverFox is offline   Reply With Quote
Old 10-23-2007, 11:30 AM   #2
Tanj!
Member#: 9339
2005 Forester XT
80, 86, 87, and 88 RX-7
Your talking about the bell housing. Any heavy duty degreaser will work along with some elbow grease. I've even put gasoline in a spray bottle before to clean that stuff up and had to work at it. So their is no easy method. Only thing to watch out for is make sure you've removed the throw out bearing and that the shaft seal is in good condition. No reason to contaminate the fluids in the housing or degrease the throwout bearing.
Tanj! is offline   Reply With Quote
Old 10-23-2007, 11:36 AM   #3
TheSilverFox
Member#: 142520
2006 STI - Protuned
308whp - SilverFox
yes.. bellhousing. my bad. sorry for the confusion. i'm debating if i should try the degreaser and just letting it sit for 15 mins and then rinsing it off.
no worries about the T.O.B... i already removed it and have a new one waiting to put in.
so is degreaser and then spraying the housing down lightly a good idea, or should i avoid the water spray idea??
--J
Old 10-23-2007, 12:09 PM   #4
KevinHeist
Member#: 50667
2000 Impreza Coupe
Enginuity Tuned
brake cleaner... just spray it all over
KevinHeist is offline   Reply With Quote
Old 10-23-2007, 01:51 PM   #5
Sn00py
Member#: 132408
2009 Lamborghini
Gallardo Supperleggera
+1
Sn00py is offline   Reply With Quote
Old 10-24-2007, 09:32 AM   #6
todd_fuller
Member#: 79004
2005 Impreza WRX STi
Crystal Grey
If you want to use something a little less toxic, Purple Power cleaner works pretty well (hell of a lot better than Simple Green). Just needs a brush to get deep into the gunk. Brake cleaner is hard to beat, but that **** is nasty stuff!
todd_fuller is offline   Reply With Quote
Old 10-24-2007, 09:45 AM   #7
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
fill your bathtub with gasoline, and soak the tranny overnight, then shoot it with brake cleaner, no need to use any rags.
in the event that gasoline is not legal to use as a solvent any more, just shoot the ****er with lots of brake cleaner and use plenty of shop towels to wipe it down, make sure you don't leave any fuzz from the towels in there.
samagon is online now   Reply With Quote
Old 10-24-2007, 10:29 AM   #8
TJ
Member#: 41735
I'm on your lawn
do something about it
TJ is offline   Reply With Quote
Old 10-24-2007, 10:31 AM   #9
TheSilverFox
Member#: 142520
2006 STI - Protuned
308whp - SilverFox
Impreza WRX STi
damn... so now i have to go buy a bathtub too?? this tranny job is turning into a more expensive project than i had hoped for.
and just for future references?? which gaso should i use..
93 octane?? or does the cheap stuff work too...?? or should i use diesel?
/sarcasm
--J
Old 10-24-2007, 10:53 AM   #10
samagon
Member#: 26859
of TXIC
/sarcasm
--J
C16.
Old 10-24-2007, 11:05 AM   #11
texas05sti
Member#: 126242
2005 STi/2012 GTR
TXIC's most loved
C16.
At least your apartment will smell nice
texas05sti is offline   Reply With Quote
Old 10-24-2007, 12:20 PM   #12
KevinHeist
Member#: 50667
2000 Impreza Coupe
Enginuity Tuned
i would imagine it would smell quite pleasant
Old 10-24-2007, 12:58 PM   #13
Davenow
Member#: 23676
I used to use brake clean for EVERYTHING when I was wrenching for a living.
I used it to clean my hands if I wanted to grab a snack while working
Old 10-24-2007, 01:09 PM   #14
TheSilverFox
Member#: 142520
2006 STI - Protuned
308whp - SilverFox
Impreza WRX STi
i might just start doing that at the hospy before i start iv's now..
"ok mam, i'm going to apply a nice cool spray, and it might burn and sting a bit... and then i will poke this piece of metal into your arm"
--J
Old 10-24-2007, 02:17 PM   #15
fastcb
Member#: 82942
2005 Sti
Stage 4 PSM
What are you doing with the tranny out?
I would not clean my tranny in the bath tub. That is way stupid.
CB
fastcb is offline   Reply With Quote
Old 10-24-2007, 02:22 PM   #16
TheSilverFox
Member#: 142520
2006 STI - Protuned
308whp - SilverFox
Impreza WRX STi
CB
it's not my subaru tranny.. it's my honda tranny. the T.O.B. was shot.. so all the more reason to just do a full stage2 clutch install and get that over with.
i'm not planning on cleaning it in a bathtub.
--J
Old 10-24-2007, 03:01 PM   #17
KevinHeist
Member#: 50667
2000 Impreza Coupe
Enginuity Tuned
brake cleaner is the way... might not even have to wipe if it has enough velocity on it
Old 10-24-2007, 03:16 PM   #18
samagon
Member#: 26859
of TXIC
talk about dry skin.
CB
Old 10-24-2007, 04:22 PM   #19
oscarmayer
Member#: 33863
2001 rs2.5
silver/champaign
break cleaner FTW! expect to use like 3-4 cans, and start from the top and work your way down. also save about 1/2 the last can and get some blue shop papertowels and use the spray in the towels tro help whipe the stuck on stuff. when done, ensure you put coating of lith greese on the slider shaft for the TO bearing and then the pivot points for the swing arm that pushes the to bearing. anyplace that metak touches should be lubed EXCEPT the clutch disc, plate and flywheel itself.
standard practice on any manual.
oscarmayer is offline   Reply With Quote
Ice on the inside of the windows, does this happen to anyone else? msingell Newbies & FAQs 11 02-25-2008 10:26 AM
How to remove those black spots on the inside of the rim? iNfEk Tire & Wheel 11 08-25-2005 10:09 PM
Any recommendations to detail the inside of the car for cheap? petawabit Southern California Impreza Club Forum -- SCIC 5 08-10-2004 01:00 PM
Someone please post a picture of the inside of the WRX diff eightballrj Transmission (AT/MT) & Driveline 5 09-12-2003 03:09 PM
pics of the inside of the roof vent? trinidriver Interior & Exterior Modification 5 05-06-2002 07:05 PM
