Old 01-19-2002, 08:55 AM   #1
Sooberman
Member#: 5344
Location: Greenwood Lake, NY...where the heck is that?!? :P
2002 WRX WRagon
Platinum Slipper
Question HVAC Control problem...
Just wondering if anyone has any ideas why my vent control won't turn all the way (clockwise) to the "Vent" position. It used to in the past, but one day it just wouldn't go to that position. It just stops halfway over as if it was hitting something. All the other positions are fine.
Sooberman is offline   Reply With Quote
Old 01-19-2002, 12:01 PM   #2
ViaW
Member#: 1414
01 Outback
Lightbulb
I had a similar problem after I changed the radio from stock. The vent controls are attached to a cable behind the face plate. The new radio was causing something to hang up on the cable a few inches from the vent control. A very nice mechanic at the dealer helped me and we pulled the center dash section out a few inches, messed around with the cables until everything worked right, then pushed is all back together gently.
Did you change any radio or CD components?
ViaW is offline   Reply With Quote
Old 01-19-2002, 03:22 PM   #3
Sooberman
Member#: 5344
2002 WRX WRagon
Platinum Slipper
Default Perhaps...
Well, I didn't mess with the radio, but I did install a temperature gauge (which required removing the cupholder area) and I installed a boost gauge (required removing different parts around the instrument cluster and leftward).
I thought of the possibility, but I don't recall ever getting into that area. I'll see if I can get a look sometime. Thanks.
P.S. - Great timing to have my window defroster option gone, huh?
FS socal: Center console, arm extension,hvac bezel, hvac controls snowcrzy Interior/Dressup/Audio & Security 7 09-14-2009 08:16 PM
hvac controls pop onto tr controls? dontgiva Interior & Exterior Modification 2 11-19-2007 09:06 AM
05-07 hvac control climate control wrxmase Interior/Dressup/Audio & Security 6 04-16-2007 08:36 PM
WRX Dash, Bar, HVAC Controls, HVAC ducting, Console, Glovebox, Silver Trim - $400 gedwrx Interior/Dressup/Audio & Security 7 03-18-2007 05:33 PM
HVAC Control Problem kev m Baja Forum 21 03-05-2007 11:26 AM
