Old 10-23-2007, 05:58 PM   #1
skipperwrx
Member#: 124232
2005 wrx
Default Bigger TMIC with open source tuning
Does anyone know if it's alright to put a much bigger intercooler (like the ebay one) on an 05 wrx that has an open source stage 2 map for EM? Pros/Cons...Thanks.
skipperwrx is offline   Reply With Quote
Old 10-23-2007, 06:21 PM   #2
skatefather
Member#: 143287
02 Wrx wagon
WRB, stage 2 and a bit
I believe it to be alright. A good source for info like that is enginuity.org forums. I think that they refer to it as a stage 2.5 upgrade and you will need a retune. The car will build boost beyond what you have it set to now only because of cooler and denser air coming in. Also winter is right around the corner so you may see a 1 to 2 pound boost fluctuation. Good if your car is ready for it.....bad if it isn't.
skatefather is offline   Reply With Quote
Old 10-23-2007, 06:29 PM   #3
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
As was stated, the bigger TMICs flow a bit better than stock. That means the turbo can work at a lower pressure ratio for a given boost at the manifold, the wastegate tables will need to be adjusted to compensate.
Other than possible overboosting, it should be fine. The better cooling should allow you to run more boost, leaner afr, or more timing over the Stage 2 map you are currently running.
Old 10-23-2007, 06:38 PM   #4
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
I don't see major adjustments needed unless you went with a FMIC. Probably just adjust the WGDC/Continuous/Burst a bit if it's oscillating, and boost table if your running alot more (3-4 PSI) boost than before but hitting target and it is steady.
If Boost goes up by 1 PSI or so, but the dynamics stay the same, I'd say it's probably fine and just a result of less pressure drop.
I just put an STI TM on my car today and will be doing some tuning with it tomorrow. I'll let you know if I change anything.
/Brox
Broxma is offline   Reply With Quote
Old 10-23-2007, 07:31 PM   #5
skipperwrx
Member#: 124232
2005 wrx
Thanx guys,
I was thinking about it because I know people put bigger intercoolers on their stock cars without even having a tune plus everyone says they work fine with Cobb Stage 2...
Old 10-24-2007, 09:37 PM   #6
crashtke
Member#: 120912
The difference between the stocker and the majority of bar and plate designs (like the majority of the ebay ones) is that there is a .2 psi pressure drop vs a 2-3 psi pressure drop on the stock intercooler. What this means is you can realistically run 2-3 psi more boost and the turbo is in the same range as it was before since it is not having to work as hard. This means the ability to run more boost while keeping the turbo in its efficiency range. The difference in cooling is going to be minimal until you go to a front mount. So, as others have said, adjust wgdc and MAYBE turbo dynamics.
crashtke is offline   Reply With Quote
Old 10-24-2007, 11:55 PM   #7
MasterKwan
Member#: 98961
2003 WRX
I'm assuming going from a WRX to STI intercooler is why I started to overshoot my boost target. I adjusted the TD table to lower the speed that boost increases. I also notice in the logs I don't need nearly as much WDGC as the Stock ECU had dialed in to make target boost.
where to begin with open source tuning JustinS STi Commercial ECU Reflashes 34 02-01-2016 11:57 AM
Question about open source tuning Chasey Newbies & FAQs 8 06-05-2010 09:02 AM
Anybody in Harrisburg good with open source tuning? mgoss79 Mid Atlantic Impreza Club -- MAIC 2 12-03-2009 09:22 AM
07 STI tuned with Open Source! ITP Proven Power Bragging 24 02-28-2007 04:22 PM
07 STI tuned with Open Source! ITP Commercial ECU Reflashes 0 02-25-2007 02:57 PM
