Old 10-24-2007, 09:08 AM   #1
lobelsteve
Member#: 31992
2007 STI
UGM
Default CEL P0137 and Cruise Control
I am getting the cat voltage code when I use my cruise control.
07 STI, EcuTEK, AVCR, URGT35, DC headers, Greddy Evo2 exhaust
It is not coming on during regular driving, spirited driving, etc.
I have a mechanical fix with anti-foulers and this is not helping.
Anybody know if there is a link between cruise control and this code?
lobelsteve is offline   Reply With Quote
Old 10-25-2007, 10:33 AM   #2
lobelsteve
Member#: 31992
2007 STI
UGM
Bump.
Anyone know of a fix?
I thought the code could get deleted from the ECU using ECUtek.
Old 10-25-2007, 02:23 PM   #3
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
anytime the ecu throws a cel the cruise light blinks and cruise does not work
subarus way of making you bring the car in
a6n6d6y is offline   Reply With Quote
Old 10-25-2007, 06:08 PM   #4
Jon [in CT]
Member#: 2992
02 WRX Sedan
It's probably aggravating your rear O2 sensor trouble code. Take it off.
Jon [in CT] is offline   Reply With Quote
Old 10-26-2007, 08:23 AM   #5
lobelsteve
Member#: 31992
2007 STI
UGM
What am i missing? The mechanical fix is two antifoulers (one drilled out) with the O2 sensor screwed into them. This is in the rear O2 sensor at the back end of the downpipe. Should I take out the antifoulers here?
Old 10-26-2007, 09:06 AM   #6
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
P0137 is a voltage low, usually it throws P0420 for cat inefficiency. Try removing the anti-foulers and see if it works. You can just screw it right into the DP, right?
Outside of that, it could be possible you have a short, bad wire, or bad sensor.
cucamelsmd15 is offline   Reply With Quote
Old 10-24-2008, 07:10 PM   #7
IH8PVMNT
Member#: 178254
2006 Wrx Limited BUG
2006 Wrx Limited Wagon
i just threw this code today after my protune 180 miles ago. on a vf48, meth, catless tbe, spt intake, perrin inlet, 255 lpf fuel pump, dw 750 injectors, iriduim one step colder plugs, amr tmic. i had the p0420 code way back in january but thats when i was stock i upgraded to stage 2 and that code went away.. now i have this p0137, and i talked to my tuner he thinks its the sensor, the rear 02 IS disabled. any ideas?
IH8PVMNT is offline   Reply With Quote
CEL on and cruise control light flashing silversurfer307 Service & Maintenance 0 01-11-2008 08:08 PM
cel and cruise control numba1golfa Newbies & FAQs 5 11-30-2007 12:00 AM
CEL and Cruise Control Blinking #17B STI AccessPort 3 11-26-2007 10:24 AM
CEL and cruise control (couldnt find anything on search) SocalKTK Southern California Impreza Club Forum -- SCIC 16 08-25-2006 09:50 AM
need to clarify something about CEL, and cruise control problem GeLLo_Boi Newbies & FAQs 2 05-13-2006 11:19 PM
