Old 10-24-2007, 12:22 PM   #1
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Default 4 speed -> 5 speed -> 6 speed
Back in the day my 1972 MG was a 4 speed. My next manual car was a 1989 Honda Accord...5 speed.
Now, as we all know, 6 speeds are fairly common.
Why the changes over the years? I remember a friends 196something Bronco was a 3 speed manual (three on the tree baby).
Is this due primarily to fuel economy concerns or technological advances?
Reciprocity is online now   Reply With Quote
Old 10-24-2007, 12:23 PM   #2
El Camino
Member#: 78760
the floor everybody
walk the dinosaur
My first car (and namesake) had a three speed on the floor.
R 2
1 3
El Camino is offline   Reply With Quote
Old 10-24-2007, 12:23 PM   #3
Keith
Member#: 191
2012 J train
Brown
it is because of el nino
Keith is offline   Reply With Quote
Old 10-24-2007, 12:24 PM   #4
Mr.Sparkle
Member#: 83725
2015 WRX
I would say both.
Mr.Sparkle is offline   Reply With Quote
Old 10-24-2007, 12:24 PM   #5
boxered
Member#: 61884
I drove a '71 Chevy p/u with 3 on the column.
boxered is offline   Reply With Quote
Old 10-24-2007, 12:25 PM   #6
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
Advances, I'd say.
Lighter, stronger metals. Better assembly control means they can make smaller gears and parts.
Also higher speeds, of course. An old MG wouldn't do much past 50, now you need to go up to 100 so you need more gearing to accommodate that.
rogue is offline   Reply With Quote
Old 10-24-2007, 12:25 PM   #7
r0bman
Member#: 87015
Performance, economy, forward thinking, and technology to back it up. If you gear a car better, it's faster. It also gets better mileage. And the more gears it has, the better it is.
"Wider is better"
It also completely depends on the type of car / engine. NASCAR still has 4MTs... food for thought.
r0bman is offline   Reply With Quote
Old 10-24-2007, 12:26 PM   #8
ekw
Member#: 92141
2004 STi-WRB on gold
Street prepped by TiC !
"three on the tree"
ekw is offline   Reply With Quote
Old 10-24-2007, 12:26 PM   #9
MidnightSti05
Member#: 74064
Paddle is the way of the future.
MidnightSti05 is offline   Reply With Quote
Old 10-24-2007, 12:26 PM   #10
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
I'm looking forward to my 2028 v31 STi with 14 speed
Neek is offline   Reply With Quote
Old 10-24-2007, 12:26 PM   #11
Xio
Member#: 3805
2011 STi Sedan SWP
2011 Outback ABP
Which, as you know, is Spanish for..."The Nino".
Xio is offline   Reply With Quote
Old 10-24-2007, 12:27 PM   #12
r0bman
Member#: 87015
... You know how I know you're gay?
Old 10-24-2007, 12:28 PM   #13
Keith
Member#: 191
2012 J train
Brown
that would be the jdm version. We would have a 10 speed.
Old 10-24-2007, 12:29 PM   #14
Kaiser
PM me for
great turkey recipes
Member#: 7170
Aut Kaiser,
aut nullus.
And still no Recaros.
Kaiser is offline   Reply With Quote
Old 10-24-2007, 12:32 PM   #15
aod
Member#: 7121
Don't forget Lexus with their automatic 8 speed. I don't know if it is a true 8 speed, or 4 speed with overdrive for each gear though.
aod is online now   Reply With Quote
Old 10-24-2007, 12:34 PM   #16
Mr.Sparkle
Member#: 83725
2015 WRX
GM is coming out with an 8 speed.
Old 10-24-2007, 12:35 PM   #17
Matt K
Member#: 45204
16 you don't
respond to danger
how could you have overdrive for every gear? That makes no sense. 4 OD gears would be silly. Unless you just meant a 4spd with low/high for each gear...
Matt K is offline   Reply With Quote
Old 10-24-2007, 12:36 PM   #18
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
suck 8 dicks (or 4 dicks twice).
Cosworth is offline   Reply With Quote
Old 10-24-2007, 12:38 PM   #19
Paraskass
Member#: 51735
2006 2.5i
Steel Gray
"Wider is better"
My GF says it's all about girth.
That's why my 2" long, 7" wide dong is the bomb.
Paraskass is offline   Reply With Quote
Old 10-24-2007, 12:39 PM   #20
preach
Member#: 139559
1999 2.5 RS
SeacoastSubarus.com
Don't forget the old Spitfires (and whatever else) that had a 4 spd but had an electronic OD for 3rd and 4th.
Oh man this is turning into a mind****.
preach is offline   Reply With Quote
Old 10-24-2007, 12:53 PM   #21
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
That's right...my dad had some other British car (I want to say it was an MG too, MGA) with "electric overdrive". 4 speed with a button for a magical 5th.
I was thinking it was both economy and technology too. Improved metals/design means we can fit more gears in the box and more gears can translate into lower RPM at higher speeds...as well as having higher speeds in general.
Yes the MG wasn't fun above 50. I got it to 80 MPH once (I think...that was long ago). Whatever speed it was I was very scared for my life.
CVT will be the future however. That's infinite speeds with min/max determined by pully sizes. In that situation you could have an engine stay at a constant RPM with the gear ratio changes controlling your speed.
Old 10-24-2007, 01:03 PM   #22
themarxist
Member#: 104555
1996 VW Passat Wagon
TDi White
With the way the planetaries in an automatic transmission work, there's really no difference between the two. Each ratio is just a different comb0nation of clutching of the planetaries, there's not a "first gear" gear like in a manual.
themarxist is offline   Reply With Quote
Old 10-24-2007, 01:04 PM   #23
anechoic
Member#: 28601
2007 Outback
gold opal something
That's pretty much what GM did with the 80's Vettes. 4 speed manual plus an "overdrive" on 2nd, 3rd, and 4th (I have no idea if it was a true overdrive ratio below 4th, though).
One of my friends has an old Austin Healy with a similar setup as well.
anechoic is offline   Reply With Quote
Old 10-24-2007, 01:11 PM   #24
docwhorocks
Member#: 13772
79 Chevy
Scottsdale
Description: A rare limited edition 379 X with Brand New rubber. In excellent condition, ready to go to work today.
Brand: Peterbilt
Year: 05
Model: 379-127
Color: Blue
Engine: C-15
Mileage: 488000
Wheelbase: 278
Transmission: 18 Speed
Suspension: FLEX-AIR
Type: Tractor
Horsepower: 475
Tires: 11R24.5
Sleeper: 70HT
Ratio: 3.36
Trim Level: PLATINUM
docwhorocks is offline   Reply With Quote
Old 10-24-2007, 01:16 PM   #25
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Brand: Peterbilt
Year: 05
Model: 379-127
Color: Blue
Engine: C-15
Mileage: 488000
Wheelbase: 278
Type: Tractor
Horsepower: 475
Tires: 11R24.5
Sleeper: 70HT
Ratio: 3.36
You can have a gearbox the size of a MG in one of those.
5 speed clutch flywheel on a 6 speed? mikeis300 Transmission (AT/MT) & Driveline 12 12-20-2009 02:51 AM
jdm sti 5 speed vs. usdm/jdm sti 6 speed mannyOlicious Transmission (AT/MT) & Driveline 3 06-24-2008 05:18 PM
5 speed shifter yoke to a 6 speed? 2ndGearFling Transmission (AT/MT) & Driveline 3 02-12-2008 12:40 PM
2001.5 Audi S4 6-Speed Twin Turbo sayuncl Private Vehicle 'For Sale' Classifieds 14 09-07-2007 01:44 AM
