Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 01-19-2002, 04:52 PM   #1
Scoobie Newbie
Member#: 4184
2004 WRX
World Rally Blue,Moonroof
Default Block Heater Question
Is it safe to start your car while its still pugged in?
Scoobie Newbie is offline   Reply With Quote
Old 01-19-2002, 05:05 PM   #2
MixeD_MenacE
Member#: 1274
MY00 BRP 2.5RSTi
www.zucru.ca
its just a heat element, kinda like ur stove, i've started mine numerous times while it was plugged in, but i unplugged it right after i started the car. if u leave it in tooo long, u risk burning/overheating the element and frying the heater. hope this helps a bit =)
shaun
MixeD_MenacE is offline   Reply With Quote
Old 01-19-2002, 07:49 PM   #3
Scoobie Newbie
Member#: 4184
2004 WRX
Thumbs up
Thanks.
Old 01-20-2002, 08:22 PM   #4
Lt.Biggles
Member#: 10446
Default Block Heater plugged in while car running?
More likely all you'll end up suffering is a wrecked block heater cord from when you back out of your parking stall after forgetting to unplug it when you start the car... The heater element is immersed in the coolant, and whether or not its plugged in it gets up to the same operating temperature as the engine. It won't "burn out" if you leave it plugged in and the car running...
YMMV,
Lt.Biggles is offline   Reply With Quote
Old 01-20-2002, 09:02 PM   #5
Scoobie Newbie
Member#: 4184
2004 WRX
Thanks. How did you come up with that name (LT)?
Old 01-21-2002, 12:05 AM   #6
Rickd
Member#: 323
1999 Impreza RS
Rally Blue
It is generally not a good idea to leave the block heater plugged in while the motor is running. While you can/will get away with it with most cars, on some cars (80's Volkswagens,some Fords) will experience cavitation of the antifreeze in the vacinity of the heater element. Unlike the element on your stove, the element in an immersion style block heater cannot tolerate being in air for even a few seconds before burning out.
It is also not a good idea to add straight anti freeze to your cooling system. The newer anti freeze contain a high content of silica gel to prevent corrosion of aluminum blocks. This gel can attach itself to the heater element, insulating it from the cooling effect of the water, and cause a burnt element. Always premix the antifreeze with water before adding it to the rad.
I actually designed the heater for Subaru in about 1986 when working for an OEM supplier. I have the original prototype forging kicking around here at home somewhere, it was the first forging I had designed from scratch as a junior designer.
Rickd is offline   Reply With Quote
Old 01-21-2002, 12:56 AM   #7
MixeD_MenacE
Member#: 1274
MY00 BRP 2.5RSTi
www.zucru.ca
hey rick, are u an M.E.T by any chance?
Old 01-21-2002, 02:39 PM   #8
Rickd
Member#: 323
1999 Impreza RS
Rally Blue
Nope, when I was going to RRCC I was putting myself thru school and living on my own. I couldn't afford to take the 2 year CET course, so I took Machine Design/Drafting. The big difference was there was much less time available to do strength of material, & properties of materials. I've had to learn most of that on my own.
Questions about block heaters mike_b49431 Normally Aspirated Powertrain 5 09-13-2006 07:11 PM
Block heater question mr2guru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-29-2001 07:10 PM
Subaru engine block heater install - need HELP! Peaty Normally Aspirated Powertrain 2 11-17-2000 01:42 AM
Subaru Engine block heater tomrichardson Normally Aspirated Powertrain 5 11-11-2000 01:30 AM
Block Heater Silver2000RS Newbies & FAQs 3 10-21-2000 10:04 AM
