Old 10-24-2007, 05:33 PM   #1
Mechkiller31st
Member#: 38474
1998 Impreza Wagon L
Brilliant Red
Default EJ22 head Gasket for turbo on non turbo
Ok as most now from a post just a few notches down i am putting a TD04 Turbo onto my 1998 L subaru Impreza EJ22 now i have since found out that i have a blown head gasket and have decided to replace them while putting the turbo on.
Now this is kinda stupid to ask after the fact but imight as well ask anyways. I have ordered Cometic head gaskets for the EJ22E turbo for my EJ22E non turbo the only difference is the EJ22E non Turbo is .40" where as the EJ22E Turbo is .051" now i know this "MAY" affect my timming slightly but other than that is there any problems with doing this?
Mechkiller31st is offline   Reply With Quote
Old 10-24-2007, 06:39 PM   #2
silentt
Member#: 119995
2004 Outback XT
Peachy
No problems if you ordered an ej22e headgasket for your ej22e car. If you ordered an ej22t headgasket, it may be different routing for coolant but I'm not sure.
silentt is offline   Reply With Quote
2.2 turbo and non turbo head questions legacydreamz Built Motor Discussion 2 03-28-2006 06:18 PM
are the EJ22 turbo and non-turbo ECUs swappable? JonofScio Normally Aspirated with bolt-on Forced Induction Powertrain 2 07-03-2004 11:49 PM
use the DOHC head gasket (0.152cm) on SOHC (0.058cm) ChAi Normally Aspirated with bolt-on Forced Induction Powertrain 2 06-05-2004 10:07 PM
Head gaskets for 90-93 EJ20 turbo (Liberty RS?) suberboy Normally Aspirated with bolt-on Forced Induction Powertrain 0 06-11-2002 03:29 AM
Head gasket for Legacy turbo jwooman Legacy Forum 0 05-25-2001 05:12 PM
