Welcome to the North American Subaru Impreza Owners Club Sunday April 19, 2015
Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 10-25-2007, 03:29 AM   #1
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Default Perrin- H6_STI: The Engine
THE H6 ENGINE
There are many things about this engine that are very cool. Just looking at the specs doesn't do it justice. 3.0L, 6 cylinders, DOHC, AVCS, AVLS, 250HP in stock form, aluminum block, forged steel crank, chain driven cams, and only .700" longer than an EJ20! Did I mention 3 point zero liters! Being familiar with the 4 bangers, the first thing that I was interested in seeing was how the Variable lift worked. The cams are the first strange thing you see as each valve has 3 lobes. One central lobe for the low lift and 2 outer ones for high lift, longer duration. The bucket is where the magic happens. There is an inner and outer piston that rubs on both cam lobes all time. When the solenoid allows oil pressure to shoot through the oil gallery, it locks the inner piston to the outer piston/bucket, and bam, new cam profile. I have to say this is probably the coolest part of the engine. Word is this is a co-developed technology from Porsche and Subaru, sure enough the parts are made in Germany.
Cutaway of EZ30R, aka H6
After getting the engine in hand a few other things that surprised us. The manifold is plastic, which sounds scary. But like other intake manifolds on cars, this is a glass-filled Nylon, which is good to 400+degrees and will hold high pressures at these temps. Plus the way these are manufactured, they allow for very smooth, very large internal diameters. Second surprise is the ports on the head. They are huge compared to the 4 cylinder ports. I was a little worried as since each runner is feeding smaller pistons they might be smaller than the 4 cylinder ports which feed larger pistons. But we were wrong. Another thing that we really liked was the throttle body. Yes its feeding a bigger engine, but it is feeding less power, so smaller throttle body??? Nope! Even better it was bigger! 3"OD vs. the WRX 2.75".
This build was a test of the basics of the H6, so drop in pistons were the answer we were looking for. We went to Supertech products and sent them an OEM piston set to build our custom pistons. Because this was a SEMA car, Willy at Supertech, was very excited about doing the H6 build as it was nothing he had seen before. This was a huge help in getting our pistons right away and getting the ball rolling with the build.
PERRINJeff is offline   Reply With Quote
Old 10-25-2007, 03:31 AM   #2
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Old 10-27-2007, 12:56 AM   #3
likeawd
Member#: 100884
jeff,this seems to be the engine to build if i want to minimize lag? will you make headers?
likeawd is offline   Reply With Quote
Old 10-30-2007, 12:20 PM   #4
PERRINJeff
NASIOC Manufacturer
Member#: 74110
It is a great way to get rid of lag, but expensive. Header's are not something we plan on making at this time. They are just too expensive, and not enough people wanting them. BUt you never know!
Old 11-16-2007, 09:45 PM   #5
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Now for the real question..is the EZ30R a 4G63 killer?
mxpunk is offline   Reply With Quote
Old 11-17-2007, 11:49 PM   #6
S L O W W R X
Member#: 95109
Jeff you don't happen to have any extra exhaust flanges laying around you could sell do you. I was trying to avoid getting a set cut if I didn't have to.
S L O W W R X is offline   Reply With Quote
Old 11-19-2007, 06:49 PM   #7
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Well yes, but not if you compare the Money aspect to the 4g63
None left, try calling PDXtuning, they might.
Old 11-19-2007, 10:05 PM   #8
S L O W W R X
Member#: 95109
Cool Thanks
Old 12-02-2007, 03:01 PM   #9
Roo
Member#: 14931
If you know your Subaru history, you MIGHT be able to adapt them to fit another, larger H-6 motor...the one that was, until 2008, the largest PRODUCTION Subaru motor installed in a car available in the United States.
Roo is offline   Reply With Quote
Old 12-03-2007, 01:43 PM   #10
PERRINJeff
NASIOC Manufacturer
Member#: 74110
They have different ports is the problem. They have the larger single port Exhaust. The older H6, the 3.6L one, might have 3 ports, i am not sure though. If Subaru would just put one of these in an STI, then we are getting somewhere!
Old 02-03-2008, 10:57 AM   #11
JDMCRX
Member#: 153791
What car did this motor come in ?
JDMCRX is offline   Reply With Quote
Old 02-15-2008, 09:34 PM   #12
Dubya R Ex
Member#: 119223
2006 WRX
tribeca if im not mistaken
Dubya R Ex is offline   Reply With Quote
Old 02-16-2008, 06:42 AM   #13
the oracle
Member#: 142120
97gc 831's most miss
ed subie
is the water pump chain driven?
the oracle is offline   Reply With Quote
Old 02-16-2008, 07:47 PM   #14
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
I was thinking this was gonna be an EG33, the SVX engine. Which is relevant to my interests.
XanRules is offline   Reply With Quote
Old 02-16-2008, 09:04 PM   #15
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
Could you not use the new 3.6L H-6? Bigger......Not sure if it's better.
tux121 is offline   Reply With Quote
Old 02-18-2008, 01:35 PM   #16
PERRINJeff
NASIOC Manufacturer
Member#: 74110
It sure is! Not sure if that is bad or not, but it seems to still be working just fine!
It is bigger, but not sure if it is less durable or what.
Old 04-07-2008, 08:18 AM   #17
Kansei
Member#: 173080
1997 Legacy 2.0 GT
Forest Green Metallic
the 3.6 was belt driven so not too much better. just bigger.
the 3.0 was the better choice anyways. It fit better.
Kansei is offline   Reply With Quote
Old 07-10-2008, 11:48 AM   #18
HillbillyLes
Member#: 178340
2002 WRX Speedwagon
Platinum Silver Metallic
Since I'm doing some research on what kind of swap I want to do for my 98 RS, Would you recommend this engine as a straight across swap (with wiring, etc) for the 2.5? The 250 or so rated HP should be plenty to keep a smile on my face and to surprise many a challenging G8 or Bimmer owner on the highway so the plan would be to leave it as is just car to car swap (maybe CAI and larger Exhaust system per availability....realizing commercial headers are out of the question currently).
Would a swap like that be fairly straightforward and would the stock engine offer enough street challenge satisfaction to be worth the trouble as compared to the higher cost of an STi or later WRX swap?
A reliable daily driver with power-a-plenty for daily use and a few highway challengers who seem to always be intimidated by the looks (which are a bit faster than the NA 2.5 allows...WRB with gold wheels). I am thinking about a 100 HP more than the currently rated 165 should be enough to keep from being TOO embarrased on the road. Not the fastest but able to hold it's own without sinking $4 or 5K+ into a turbo swap.
Just weighing options....
Thanks for your time and opinion.
Les
HillbillyLes is offline   Reply With Quote
Old 07-10-2008, 11:56 AM   #19
HillbillyLes
Member#: 178340
2002 WRX Speedwagon
Nother question... What is the ez30R based out of? I have found a few used ones out of 01-04 Legacys but they are rated in the 210 to 215 Hp range. Is the 30R a factory direct engine or is it based in a production model?
Again, thanks
Les
Old 07-12-2008, 06:56 PM   #20
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Again, thanks
Les
That's the EZ30D. The EZ30R is out of the 05-07 Legacy Outback, 08Legacy 3.0R Limited and Outback, and 05-07 Tribeca. Hardest part of any work with this engine in any car is the electical.
-Gaddis
Seraphinwolf is offline   Reply With Quote
Old 07-29-2008, 01:10 PM   #21
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
any progress on this H6 build?
elislider is offline   Reply With Quote
Old 07-29-2008, 01:39 PM   #22
wrxwagon253
Member#: 125620
05 3076R Wagon
B5 S4 w/ Stg.3 RS6 kit
I'd have to say no because ive yet to see one power a car down the strip at 198mph doing a 7.7 in the 1320 nor make 1130whp so im gonna have to say no for now.
wrxwagon253 is offline   Reply With Quote
Old 07-29-2008, 01:49 PM   #23
PERRINJeff
NASIOC Manufacturer
Member#: 74110
The H6 project is long since done.
The customer that bought the car lives in CA and has been driving it for more than year now, had it tuned on 91 a couple of times by Surgeline Tuning, makes great power and still holding up just fine!
Old 07-31-2008, 12:02 PM   #24
lucky#7
Member#: 153492
7707 07 wrx 07 sti
wrb
plz dont tell me this is the only one. cuz i want one too.
lucky#7 is offline   Reply With Quote
Old 07-31-2008, 12:28 PM   #25
PERRINJeff
NASIOC Manufacturer
Member#: 74110
its the only we built. But there are a few around now. Mr Jeff Sponaugles car lives again as of yesterday, and Ron at Axis racing has built a few engines. So they are around!
PERRIN - H6_STI: Project Overview PERRINJeff NASIOC Project Cars 33 03-23-2011 01:43 AM
Where is the engine code on the block engine for a wrx or sti? ejcivicdee Newbies & FAQs 3 08-12-2009 08:37 PM
PERRIN - H6_STI: The Complete Story PERRINJeff NASIOC Project Cars 3 11-06-2007 12:31 PM
How reliable are the MY04 WRX engines? Will the car and the engine last long? d-dvr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-10-2003 05:59 PM
When pulling the engine, which Engine mount bolts to pull? Eric SS Normally Aspirated Powertrain 3 10-04-2001 02:46 PM
