Old 10-25-2007, 08:39 AM   #1
alphagoose
Member#: 158302
2010 legacy gt
Default winter map
i bought an xpt stg 2 map with gm bcs map for my 04 wagon. i was wondering how hard it would be to change the map to make a winter map. lower boost is mainly what id like.
alphagoose is offline   Reply With Quote
Old 10-25-2007, 02:34 PM   #2
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
Not hard at all. Air density in cold weather might change by 10% at most I'd say so you can just drop your boost targets by 10% or so. Will probably run rich at WOT when you go open loop but you can adjust those to if needed. The ECU might be able to compensate for that a little, even if you left the fuel map alone.
/Brox
Broxma is offline   Reply With Quote
Old 10-25-2007, 04:53 PM   #3
Freon
Member#: 88322
2009 BMW 135i
Reflashes should not need to be specially winterized if the map is setup well to begin with.
Freon is offline   Reply With Quote
Old 10-25-2007, 10:08 PM   #4
alphagoose
Member#: 158302
2010 legacy gt
yea i just dont wnat to run as much boost in the winter. figure i might be safer that way.
Old 10-26-2007, 02:56 PM   #5
quazimoto
Member#: 70395
I would rather run more boost in the winter if i have the fuel for it.
quazimoto is offline   Reply With Quote
Old 10-26-2007, 04:26 PM   #6
Freon
Member#: 88322
2009 BMW 135i
There are compensation maps for boost control to do this. That's one of the nicer points of the stock ECUs. Mainly there is a wastegate duty and timing compensations based on intake air temp.
The colder inlet air and colder air over the intercooler means you're flowing a lot more air at the same boost. Higher loads for sure. Spool improves, you need less wastegate duty, etc. Add more boost on top of that and you're *really* flowing a lot more air and definitely making more power. I guess I don't care to set up my car to do that when I'm running poorer tires in poorer conditions. YMMV.
FS : Dunlop Winter Sport 3d 205/55r16 SubiRS05 Wheels/Tires 8 07-06-2010 08:52 AM
Building a base map ATR skater0422 AccessPort 5 06-07-2010 11:24 PM
winter maps STYLIN North West Impreza Club Forum -- NWIC 7 11-21-2008 01:49 PM
Winter maps for utec and cheap gas serious Engine Management & Tuning 2 10-01-2004 04:17 PM
Crappy/ Winter gas maps Bolster Engine Management & Tuning 3 02-26-2003 12:30 AM
