Old 10-25-2007, 06:23 PM   #1
Illshou
Member#: 130985
Default rear diff ratio
How do I tell which ratio my rear diff has? Reason I am asking is that I am changing the diff this weakend and I am not sure if my parts car has the same one. One car is a 97, auto trans, 14 inch wheels and the other car is a 95, auto trans, 15 inch wheels. Does anyone think there should be any difference?
Illshou is offline   Reply With Quote
Old 10-25-2007, 10:24 PM   #2
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Not sure.
Are these the same model Legacys ? I think your best bet is to try rotating the differential input (drive shaft) and get a rough appoximate guesstimate of how far one input rotation on the drive shaft causes the rear axle (output) to rotate, and compare the figure for each.
The only real fool proof way is to take the diff apart and count the number of gear teeth, and compute the ratio from there.
Also checking out http://www.cars101.com might give you some insites.
I know, for sure that the 2.2 litre automatics and the 2.5 litre automatics used different final drive ratios, and the 2.5 was not available in 1995, but was in 1997. So there is a distinct possibility that these two rear diffs have different final drive ratios.
Also I am sure you already know this, but its worth mentioning that being an AWD vehicle you need to use the same ratio to assure that the transmission/transaxle final drive ratios for the front wheels is compatable with the rear differentials ratio.
Either that, or just plug in the FWD enable fuse.
Jonathan is offline   Reply With Quote
2004 WRX Rear Diff Ratio? Mumbles Transmission (AT/MT) & Driveline 6 07-15-2004 06:41 PM
what is the rear diff ratio for 97 GT 5mt? czo79 Legacy Forum 1 09-30-2003 01:19 PM
WRX rear diff ratio automatic? Also Driveshaft length? ciper Transmission (AT/MT) & Driveline 9 12-12-2002 06:09 PM
Rear diff ratios? Rovah Transmission (AT/MT) & Driveline 6 11-07-2002 09:08 PM
Rear Diff Ratios? Greg555 Transmission (AT/MT) & Driveline 10 03-28-2002 04:54 AM
