Old 10-25-2007, 06:03 PM   #1
darksc00by
Member#: 102140
your mom
Default Is there any way to tell what the motor is without the sticker?
I just bought a motor/trans. And I am trying to figure out what it was. I know what the transmission, but the motor is missing the sticker that tells what it is.
Is there another vin somewhere?
The serial number is 296110.
darksc00by is online now   Reply With Quote
Old 10-25-2007, 06:04 PM   #2
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
there should be a stamp on the motor below the intake manifold
Old 10-25-2007, 06:05 PM   #3
darksc00by
Member#: 102140
your mom
it just says EJ20
Old 10-25-2007, 06:20 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
what do you want to know about the ej20? jdm domestic that kind of thing?
Old 10-25-2007, 06:22 PM   #5
Pohenegamook
Member#: 134262
9 조 ☼
Ponik Sinopia
I'm not sure what you mean. So you need the EJ 20 specs?
http://www.google.com/custom?hl=en&s...rch=NASIOC.com
(oh and VIN goes with the whole vehicle, not just the engine)
Pohenegamook is offline   Reply With Quote
Old 10-25-2007, 06:22 PM   #6
darksc00by
Member#: 102140
your mom
What version it is.
I have pictures.. I need better ones though.
Old 10-25-2007, 06:23 PM   #7
darksc00by
Member#: 102140
your mom
(oh and VIN go with the whole vehicle, not just the engine)
I don't have the vin, no front clip. Just a JDM motor/trans together.
But they aren't from the same car. Trans says its a version 2 STi RA
Motor.. don't look like it, more like a 3/4
Old 10-25-2007, 06:24 PM   #8
darksc00by
Member#: 102140
your mom
I am trying to figure out if its a STi motor. The Intake manifold was redone crinkle red, so it could have been a WRX motor.. OR idk
Old 10-25-2007, 06:25 PM   #9
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
edit: didn't refresh after searching
but you're on the right track
Old 10-25-2007, 06:26 PM   #10
darksc00by
Member#: 102140
your mom
Originally Posted by nhat View Post
then what you have there is an 02-05 wrx motor
i'm not sure how to tell the difference between years or if there is in fact a difference at all
Its not a WRX motor from 2002-2005.
It's definitely a JDM one from like 94-98
Old 10-25-2007, 06:29 PM   #11
darksc00by
Member#: 102140
your mom
pics added.
it doesn't look as if the motor/trans are from the same car.
Intake manifold was definitely redone before it arrived in america.
Old 10-25-2007, 06:40 PM   #12
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
im gonna move this to conversions those guys would know best.
Old 10-25-2007, 06:40 PM   #13
darksc00by
Member#: 102140
your mom
thnx.
Old 10-25-2007, 06:51 PM   #14
legacy2003
Member#: 38338
2003 Outback Sdn H6
Looks like JDM Ver. 2 or 3 WRX. Could be STI, can't really tell much difference without seeing the intercooler or ECU.
Does the transmission have DCCD?
legacy2003 is offline   Reply With Quote
Old 10-25-2007, 06:59 PM   #15
darksc00by
Member#: 102140
your mom
It looks like its supposed to have it. But it doesn't I don't think. (like it was removed)
according to the trans vin its either a WRX-RA or STi-RA transmission.
But there is no intercooler, and the ECU I don't have pics of yet because the parts are still at the warehouse.
Old 10-25-2007, 08:34 PM   #16
legacy2003
Member#: 38338
2003 Outback Sdn H6
Is there a plug toward the back of the transmission? If there is then it should have DCCD. I can't remember if the plug is black or white.
Old 10-25-2007, 09:00 PM   #17
darksc00by
Member#: 102140
your mom
where exactly?
I had Kevin@GT look at the pictures. He says it's supposed to have DCCD but it doesn't look like it does.
Old 10-26-2007, 03:20 PM   #18
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
its parts from 2 cars
the tranny is the v2 RA 3.9
the engine is ver 3 or 4 ej20k
Old 10-26-2007, 05:01 PM   #19
johnkaldar
Member#: 51047
1999 gc8 RS/sti-ra
look at the turbo numbers and I believe the catherinandken site has the serial numbers listed. That should help with v3 or v4.
johnkaldar is offline   Reply With Quote
Old 10-27-2007, 03:26 PM   #20
darksc00by
Member#: 102140
your mom
The ECU says
A18 000 D35... which translates to a V3 WRX STi
Thanks everyone.
Now I believe the trans is a V2WRX-RA
Old 10-31-2007, 06:22 AM   #21
neko
Member#: 46500
V7 STi
so where did ya find out what the ecu number translate out to? post/thread? i've been trying to id my suspected v5 sti for confirmation (not to mention i should take a gander at how bad the ecu wiring is, as i didn't do it. i think it should be all stock on that end tho)
neko is offline   Reply With Quote
Old 11-01-2007, 01:13 PM   #22
kheff46
Member#: 66739
2002 WRX wagon
crinkle red mani is V3-4(or newer). iirc V2 had alum intake mani. unless someone redid it to look newer.
--keith
look at the turbo itself and see what it says. VF23-24(V3-4), etc
kheff46 is offline   Reply With Quote
Old 11-01-2007, 09:20 PM   #23
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
the v2 also had a red manifod
at least the RA and RA 555 edition did
Old 11-02-2007, 11:23 AM   #24
kheff46
Member#: 66739
2002 WRX wagon
correct. forgot those. iirc the V2 base STi had none but the better RA, and 555 had it.
seems like a lot of hybrids being sold around lately. i fear the worst when i see a mismatch sold as a V3 STi, etc. shady people.....
--keith
Old 11-10-2007, 12:53 AM   #25
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
I will have to research but I am almost positive that is not a V2 engine.
Here are the reasons
1. The plug wires run to a cap on the intake manifold (Ver 3 and later)
2. The turbo set up, the heat shield is Ver 3 or later older models had a vent hole that got air from the stock splitter on the hood. The Ver 2 had the same air intake set up as the older models.
3. The power steering pump is also different from a Ver 2 model.
This engine is from a Ver 3 or later, I am not sure if the V4 had the plug wire setup on the center of the intake manifold or to the left of it.
I will have to look in the books but everything visual on the engine itself says Ver 3 or later!!
DuoMaxwell is offline   Reply With Quote
Is there any way to exchange currency without getting ripped off? Wagon Joe Off-Topic 42 10-19-2009 06:37 PM
Is there ANY way to get urethane out of seats without ruining them? siqq subie Car Care & Detailing 4 08-09-2008 08:52 PM
is there a way to tell if my sti is stage II niko01979 Newbies & FAQs 20 02-18-2007 11:09 AM
Is there a way to tell if I have synthetic in my motor now? Layman Off-Topic 15 10-05-2005 07:17 PM
is there a way to read what my cel is akcel Engine Management & Tuning 4 02-23-2004 06:22 AM
Message Board Statistics All times are GMT -4. The time now is 09:54 PM.
