Old 10-25-2007, 11:32 PM   #1
slapnuts
Member#: 146513
01 Legacy GT
forest green
Default Time to do another clutch
Well after spending 2 days doing the clutch on my 91 sentra a couple weeks ago, I find that the Throw out bearing in the subi is starting to take a poo . Dealership said they did the clutch on the car before we bought it in march, they must have done a crappy job or none at all(lots of chatter from an un-machined fly wheel, chirping bearing). So I need to start thinking about getting some new stuff in there. I am thinking about going with a higher performance clutch and possibly one of the slightly lighter chromoly flywheels. Anyone have any input on what to get and where to get it. I cheaped out on the nissan as its a just a $700 commuter car, but i need to do the subi up right. Also, whats the best way to do a clutch on a LGT? I dropped the tranny out on the nissan, and it was a fair bit of work. Would it be better/easier to pull out the engine instead? Never done much hardcore work on the sub, havent really even looked at it to see if its even something I could do.
slapnuts is offline   Reply With Quote
Old 10-25-2007, 11:42 PM   #2
rougeben83
Member#: 115154
2005 Outback XT
White on grey
The most recommended for a backyard mechanic is to lift the engine a couple of inches and you can get about 6" of clearance between the engine and tranny...
rougeben83 is offline   Reply With Quote
Old 10-26-2007, 01:03 PM   #3
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
I would NOT go with a performance clutch. Just do the lightened flywheel. I was going to do both upgrades, but the shop talked me out of it. They said the heavier pedal would drive me mad after a while. I'm glad I lisened to them. The flywheel was more than enough performance boost, and my leg doesn't kill me at the end of the day.
Now, if you will be doing some major autox or other high-demand racing, that's a different story. Otherwise, the new stock clutch holds tough and doesn't hurt your leg...
janikphoto is offline   Reply With Quote
Old 10-26-2007, 02:10 PM   #4
deadlydave
Member#: 131119
1996 Impreza LWRXSTI
91 BMW 318is
Stock clutch is good to keep--it's much better to have that brake than something else in the driveline.
deadlydave is offline   Reply With Quote
Old 10-26-2007, 03:16 PM   #5
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
I went with the Exedy sport and lightened flywheel, and I'm happy with it. It's not really much stiffer than stock. From what I hear, it's the same clutch used in a stock WRX, and most don't complain about the feel of that one.
Speedwagon is offline   Reply With Quote
Old 10-26-2007, 03:47 PM   #6
rougeben83
Member#: 115154
2005 Outback XT
White on grey
The full disc clutches have a similar pedal effort as the stock one for the most part. (stage 1 or something). It's when you get to the puck-types that it gets heavier.
Although I'd like to point out my ACT street is a little stiffer than stock, but from experience, the stock subaru clutch is on the heavy side when it comes to stock clutch effort anyway, so the difference isn't as dramatic as say on a Honda or Toyota (both have really light pedal effort).
Old 10-26-2007, 03:52 PM   #7
b4wantab
Member#: 21293
05 OB Black Bean
1969 W-30
Make sure you replace the pilot bearing/bushing. A lot of them do not get replaced because they "look good" and that is what can cause chatter. It may be what happen to you.
I am unsure if Subbie uses a bushing or bearing but you should be able to step up to a bearing. Anyone know what subbie uses?
Peace,
Greg
b4wantab is offline   Reply With Quote
Old 10-26-2007, 05:34 PM   #8
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
+1. I have a Fidanza lightweight flywheel, and I love it - best $300 upgrade I ever did to the car, and I got it done while the clutch was getting replaced anyway.
jey is offline   Reply With Quote
Old 10-26-2007, 05:52 PM   #9
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Peace,
Greg
They use a bearing. There's bearing/snout fix you can buy to get rid of that clutch chatter too. I think PDM makes it - it's around $125. May as well do that too to reduce the noise (have it and it really does work).
Old 10-26-2007, 10:05 PM   #10
janikphoto
Member#: 10471
2000 BMW Z3
Yeah... ALWAYS replace the bearing when doing the job. They are cheap enough that you'd be stupid NOT to...
Old 10-26-2007, 11:06 PM   #11
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Most good clutch kits will come with a pilot bearing and a throwout bearing.
I went with the exedy OE style replacement clutch for about $300, and it had all that stuff.
IronMonkeyL255 is offline   Reply With Quote
Old 10-27-2007, 10:38 PM   #12
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
now if your talking like a stage 2+ clutch, that'll be the problem. i currently have a exedy stage 1 organic with primative racing's 14lbs flywheel. the setup is very much like stock but bites about 1/4 of the way up. btw, my leg doesn't kill me in rush hour also
choung
illegal2.2 is offline   Reply With Quote
Old 10-29-2007, 02:45 AM   #13
janikphoto
Member#: 10471
2000 BMW Z3
choung
just going on what the service guys told me. I WANTED a bit more bite, but they said all the aftermarkets they had would be tougher on the leg muscles. Maybe they didn't carry the stage ones? They got me the cobb flywheel, so special parts shouldn't have been a problem...
At least the new stock clutch feels real strong, or at least strong enough.
Old 10-29-2007, 11:44 AM   #14
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Yeah, generally speaking getting any uprated clutch will get a stiffer pedal, but like I said before on the subaru, I've found the stock clutch to be relatively stiff as is, so stepping up to a stage 1 won't be that noticeable.
If you've tried the clutch pedals on a toyota or honda, you'll know what I mean about how heavy the stock subaru clutch pedal is compared to those manufacturers.
Old 10-29-2007, 09:51 PM   #15
janikphoto
Member#: 10471
2000 BMW Z3
Oh yeah... I've tried a honda. It's like you are pushing your foot into a tub of warm butter. I hate those clutches... no feel at all.
Old 10-30-2007, 08:39 AM   #16
b4wantab
Member#: 21293
05 OB Black Bean
1969 W-30
I have 60K on my car now and the clutch was replaced at 20K something because of cold morning chatter. The "new" stock clutch was noticably softer than the old stock clutch. I am used to it now so I am sure if I had the origonal clutch back it would feel harder for awhile.
Either way, both were a lot softer than my other car so it never really bothered me. It was more of soft and softer.
Peace,
Greg
Old 10-30-2007, 09:17 AM   #17
96legacy28
Member#: 140158
1996 Legacy
Green
yeah i only paid like 175 for my clutch w/throw out bearing, lightened flywheel, etc.....my car feels and drives like its new still even after 2 months
96legacy28 is offline   Reply With Quote
time to do wrx timing belt! scoobynoobEMT Service & Maintenance 6 04-21-2009 07:14 PM
So, what exactly do I need to do a clutch install? Jard Mid Atlantic Impreza Club -- MAIC 25 10-24-2006 01:00 AM
PP: Time to caption another pic DubyaAreEcks Political Playground 15 02-15-2006 12:19 PM
Time to caption another company's employees again -=C=- Off-Topic 7 05-04-2005 05:06 PM
Time To Add Another Legacy To The Family MY99 2.5GT Legacy Forum 3 02-08-2005 05:09 PM
