Old 10-26-2007, 02:39 AM   #1
mathroch
Member#: 122670
2010 Impreza WRX
Dark Grey
Default Need info on fuel pressure regulator on 2002 WRX
Hi, i am changing my fuel pressure regulator because my old one is due. I ordered an ajustable regulator and need to know if it's pretty much bolt on or is i need to change the rails or other things so i can order because i receive my new injectors and regulator. And i also have a JDM STi Version 7 in the car. Thanks
mathroch is offline   Reply With Quote
Old 10-26-2007, 02:01 PM   #2
quazimoto
Member#: 70395
Considering you didn't even state which FPR you bought,going with no.You will probably need an adaptor.Weapon-R and Sard make one.
quazimoto is offline   Reply With Quote
Old 10-26-2007, 05:27 PM   #3
mathroch
Member#: 122670
2010 Impreza WRX
Dark Grey
i bought an aeromotive FPR.
Old 10-26-2007, 05:41 PM   #4
quazimoto
Member#: 70395
Not a direct bolt on part.
Old 10-26-2007, 08:20 PM   #5
mathroch
Member#: 122670
2010 Impreza WRX
Dark Grey
Thanks alot, i got the adater and can't wait to get everything on there.
Old 10-26-2007, 08:56 PM   #6
MasterKwan
Member#: 98961
2003 WRX
You need a pressure gauge too. The "adjustable" part means you need to adjust it to the proper pressure for your car the first time you hook it up.
FPR's don't need to be replaced unless they break.
Anyone need a stock fuel pressure regulator for WRX/STi skimobile NESIC Private Classifieds 0 09-13-2006 09:20 PM
At what point, if any, does the FUel Pressure Regulator on the WRX need upgrading? ScoobyNubieToo! Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 09-30-2005 07:47 AM
Need help! Removing and reinstalling fuel pressure regulator on 2004 sti odin1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 06-24-2004 08:09 AM
('93-'01) What type of Fuel Pressure Regulator on an RS? RacerinLSL Impreza Forum 1 07-03-2001 02:25 PM
help on fuel pressure regulator Max Umbarger General Forum Archive 9 03-01-2001 06:57 AM
