Old 01-19-2002, 09:43 PM   #1
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
Talking 60,000 service! ....purrrr.....
I'm posting here 'cause it's a Legacy.
Just got my car back from the 60,000 service today. I did it a bit early because I don't know what was done previous to me. Anyway, I'm sooooo happy I did! Suby Specialties in Monrovia is the most amazing place ever. They are soooo good! They fixed the rough shift into 2nd (AUTO) by replacing tranny fluid, so now it's as smooth as all the others. The car now idles in D about as well as it does in N. Before, the idle in D was fine, but more perceptable. The whole car runs smoother in general. They also did things I didn't ask for, like clean any hint of rust off of all visible surfaces, they make the parking brake work soooo much better, as well as adjusting the normal brakes to actually work . I need to go see if the engine tick while cold has changed at all, probably not.
ahhhh.... like I said, I'm happy. It's one of the best "mods" I've done.
oh, and another thing I did while I was there was put on titanium windshield wipers. It was a total impulse buy, but they look really good. Only cost about $30 and are from somewhere in Japan judging by the packaging. They are silver instead of black and add another subtle touch to the car. They took .75 sec of my 1/4 mile . I'll post a pic one of these days.
Anyway, this is just a friendly remider to do all scheduled maintinence. Your car will love you for it.
total cost - $415.00
-S
monovich is offline   Reply With Quote
Old 01-20-2002, 01:59 AM   #2
VOLTIS5
Member#: 2353
98' LegOver GT
dark whiteish pearly red
did you have yours done at the dealership? im about to go get my 52k maintenence next month but im not sure if i can trust my dealership, bunch a slackers is what they are . but either way im gonna have to do it and i think its around that price range. im planning to get new wippers as well i hope i get the same ones that you got , i've seen em b4 and they look nice
VOLTIS5 is offline   Reply With Quote
Old 01-20-2002, 09:35 AM   #3
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
I had my 60K service done at the dealer. They did a good job. They told me the next BIG service is 90K. That is when they change the timing belt. The whole service is going to be around $550. The best part about the 60K service was they didn't find any problems with my car except I needed new pads. I did that myself, super easy.
I bought the 4/48,000 mile extended warranty at the same time. So I am under warranty untill around 2005 or 108,000 miles. This was my first Subaru so I was kind of unsure how reliable they were. I got it for some piece of mind. I was starting to wonder if I wasted my money. Untill one day I started her up, put her in reverse, and all the sudden the ABS light comes on. All the lights in the dash were diming and totally screwed. Well to the dealer I go. Turns out after 3 days of searching that a small wire(third brake light) had rubbed untill it grounded. They showed me the invoice. The total bill would have been around $600. That made the warranty look like a very wise purchase. I have had zero problems since and they did a great job on cleaning up and putting everything back together. I went in to look one day and my car was in many pieces I was so worried they would screw it up or break something; but nope.
HIHO is offline   Reply With Quote
Old 01-20-2002, 02:50 PM   #4
VOLTIS5
Member#: 2353
98' LegOver GT
is there anyway i could have the dealer show me the history of my cars mainetenence. i just wanna find out if my car is up to date with its scheduled maintenence, not quit sure what the previous owners have done to it . but so far sinec i got the car a year ago it still runs great.
Old 01-20-2002, 02:53 PM   #5
HIHO
Member#: 7624
BD5; family sedan
They did for me but it all depends on where the service was done.
Old 01-20-2002, 03:14 PM   #6
VOLTIS5
Member#: 2353
98' LegOver GT
HIHO,
what kinda service did they do for the 60k.
Old 01-20-2002, 04:08 PM   #7
HIHO
Member#: 7624
BD5; family sedan
Replace Engine oil
Replace Engine oil filter
Perform Replace engine coolant and inspect cooling system, hoses and connections
Replace Air cleaner element
Inspect Transmission/Differential (Front & Rear) lubricants (Gear oil)
Inspect Automatic transmission fluid
Replace Brake fluid
Inspect Disc brake pads and discs, front and rear axle boots and axle shaft joint portions
Inspect Brake linings and drums
Perform Inspect brake lines and check operation of parking and service brake system
Inspect Steering and suspension
Recommended Inspection Front and rear wheel bearing lubricant
Replace Drive belt(s) [Except camshaft]
Perform Replace fuel filter and inspect fuel system, hoses and connections
Replace Spark plugs - 2200cc
Replace Spark plugs - 2500cc SOHC
Replace Spark plugs - 2500cc DOHC
Inspect Clutch and hill-holder system
Old 01-20-2002, 05:29 PM   #8
VOLTIS5
Member#: 2353
98' LegOver GT
HIHO,
i have a few questions if you dont mind .
1. would i be able to do a 60k service even though im only at 52k from the dealer?
2. would it vary from dealer to dealer as to what they would do or can do for that 60k service (i.e. would my dealer do the same things as was done in your car)
thanks
Old 01-20-2002, 07:07 PM   #9
HIHO
Member#: 7624
BD5; family sedan
Go here it well give you alot more info------------>http://my.subaru.com/formslogin.asp
Create your own site it will help keep you up to datr on all services.
Old 01-20-2002, 07:18 PM   #10
VOLTIS5
Member#: 2353
98' LegOver GT
Thanks
Old 01-20-2002, 11:31 PM   #11
White Knight
Member#: 2864
'05 Legacy GT Wagon
Limited Red
I had the i-club/friends do my service
Just look at the post:P
http://www.i-club.com/forums/showthr...hreadid=117276
Mark
White Knight is offline   Reply With Quote
Old 01-21-2002, 12:17 AM   #12
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
The place I did mine was not a dealership. The dealership I've gone to is too expensive and in my opinion, shady. Suby Specialties came HIGHLY recommended from people here in SoCal and they've done some generous things for our local subie community like sponser free installfest days where they'll install most anything for free. Plus they are cool guys.
By the way, I think I might have a bad bearing in my front left wheel, there is a really subtle grinding kinda sound I can only hear on smooth roads with the radio off. Any way I can diagnose it easily? Do bearings go bad on Legacies?
-S
Old 01-21-2002, 01:41 AM   #13
VOLTIS5
Member#: 2353
98' LegOver GT
i had the same prob. but it turned out to be just my OEM rotors but when i got my KVR's it all went away
Old 01-21-2002, 01:45 AM   #14
sovereignmk1
Member#: 11858
1998 Silver Legacy
They can if you take on a curb hidden under some snow The general effect I noticed was the slight sound (whawhawha) of the bum bearing while speeding up when I was on the gas and slowing down as I braked. Wasn't too expensive to replace/fix it. Only about $200 or so with labor if memory serves well.
/Mark
sovereignmk1 is offline   Reply With Quote
Old 01-21-2002, 08:53 AM   #15
DoughtCom
Member#: 12565
1997 Swapped L Coupe
Steel Blue Mica
I've had the wheel bearings go out on 3 of my wheels. If you find a cheap place it's about 250 dollars with labor, and can go up to (from what I saw) about 400 dollars. But as you can tell, yeah they can go bad, 2 of the 3 were just from wear, and the 3rd one was from when I hit a curb doing about 5-10 miles per hour. BTW our stock lower control arms suck
DoughtCom is offline   Reply With Quote
Old 01-21-2002, 06:12 PM   #16
nitrohuffer
Member#: 6982
2001 Legover
04 forester xt
I would rather do the work my self. I just did my 20k tune up(k&n air filter, new pcv, ;fuel filter, Mobil 1 synthetic oil&filter, inspected everything) total cost- $70
nitrohuffer is offline   Reply With Quote
Old 01-21-2002, 06:19 PM   #17
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
I'd just assume pay someone else. The time it takes plus the chances of me screwing something up make it worth paying someone else.
I do install the occasional mod, though.
-S
60,000 mile service on WRX WR-Xtasy Service & Maintenance 15 08-27-2008 11:33 PM
Whats done on the 60 000 service runner19 Service & Maintenance 1 08-16-2005 06:08 AM
60,000 mile servicing.....need suby technician MekoNY Tri-State Area Forum 10 06-19-2002 05:46 PM
60,000 mile service Loki General Community 6 03-06-2002 02:07 PM
60,000 mile service? MechBoy2 Technical Forum Archive 4 05-16-2000 10:41 AM
