Old 10-26-2007, 07:20 AM   #1
C-Rock
Member#: 135187
2007 WRX
Default Taking the plunge into Tactrix, now which Wideband?
So ya, I just ordered the tactrix cable I plan on just logging for a little while, so I can get a better idea of what is going on. After I'm comfortable with that I hope to either get an OTS map and tweak that to suit my car, or just make small changes on the stock map(I'm definitely going to be posting any changes I make before I flash).
I'm stock except for an HKS catback. Hope to get to stage 2 in the near future. Most likely with the HKS DP (I know its not bellmouthed, I don't plan on upgrading past VF series anytime soon).
I've done lots of reading for the past few weeks and it seems as though getting a wideband sensor will keep me pretty safe and EGT isn't quite a necessity. Correct me if I'm wrong please.
Ok, so I'm ranting, sorry. Now for the real question. Is this WO2 compatible with the open source software? http://www.prosportgauges.com/wideband.php I don't really know anything about wideband sensors or how they even connect through tactrix. I have much more reading to do I guess. This appears to be an amazing deal and I hope it's not too good to be true.
Thanks for any input, like I said I'm completely new to this, so I'm open to any opinions, input, flaming, or recommendations.
P.S. The dealer can find out pretty easy that an ecu has been flashed, even if flashed back to stock right? So, do any of them just turn their heads about this. Or am I pretty much screwed if something ever happens, even if it isn't caused by me?
C-Rock is offline   Reply With Quote
Old 10-26-2007, 07:37 AM   #2
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
EcuEdit supports wideband O2s
you can read up more about this here
I've been using it for a long time with great results!
Hyper is offline   Reply With Quote
Old 10-26-2007, 11:32 AM   #3
WeldingHank
Member#: 98645
2002 WRX Wagon
Enginuity also supports the LC-1 which is very inexpensive.
WeldingHank is offline   Reply With Quote
Old 10-26-2007, 11:35 AM   #4
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
LC-1 all the way. It's already integrated into the enginuity logger.
06rexwagon is offline   Reply With Quote
Old 10-26-2007, 02:02 PM   #5
Freon
Member#: 88322
2009 BMW 135i
LC-1 and a gauge of your choice. If you're going to log and tune, the cheap needle gauge is enough to serve its purpose as a quick check if you think the car is running funny and you don't have your laptop.
Freon is offline   Reply With Quote
Old 10-26-2007, 02:05 PM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
i love my FJO, i've used both the LM-1 and LC-1, while the LC-1 is nice it's still not the best quality product out there.
the LM-1 i used crapped out a sensor in under 6000 miles of driving, my FJO has nearly 6000 and works perfectly
Old 10-26-2007, 02:08 PM   #7
Freon
Member#: 88322
2009 BMW 135i
I have over 20,000 miles on the Bosch sensor that came with my LM-1 and it is still working fine. Used on two of my own cars and used to tune many others. 6000 miles is horrible if you're just running pump gas.
Did you run race gas? Leaded? Where is your bung?
Old 10-26-2007, 09:48 PM   #8
C-Rock
Member#: 135187
2007 WRX
Thanks for the input guys
^I have noticed you may know a thing or two about tuning heheh, hopefully you can give me some pointers and help me get dialed in once this cable gets here.
Old 10-26-2007, 10:37 PM   #9
06rexwagon
Member#: 114730
[email protected]
You got it.
Old 10-30-2007, 02:49 PM   #10
Member#: 82064
2011 sti & evo ix
white
lc1 i have tuned over 100 cars with the 02 sensor that came with it and still kicking
Ray@revitup is offline   Reply With Quote
Old 10-30-2007, 03:57 PM   #11
Jon [in CT]
Member#: 2992
02 WRX Sedan
You should've asked for advice before buying anything. You could've bought the Tactrix/LC-1 Bundle for about $270 at http://tunertools.com/proddetail.asp?prod=IN-3791, assuming you entered the word Enginuity as the checkout coupon code.
Jon [in CT] is offline   Reply With Quote
Old 10-31-2007, 04:40 PM   #12
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
What about the PLX SM-AFR? does it work with Enginuity?
minifreak is offline   Reply With Quote
Old 11-01-2007, 03:10 AM   #13
C-Rock
Member#: 135187
2007 WRX
K, looks like I'm going for the LC-1.
Now, can anyone recommend a cost effective gauge to go along with this badboy? I'll be looking on my own but it's always good to get recommendations.
Old 11-03-2007, 11:21 PM   #14
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
anyone ever use the TXS wideband and enginuity?
Wheeler Bement is offline   Reply With Quote
Old 11-03-2007, 11:43 PM   #15
benw
Member#: 103320
1998 swapped
Forester L
I haven't, but the test release of Enginuity looks like it has provisions for it (don't quote me on that)
www.enginuity.org
benw is offline   Reply With Quote
Old 11-04-2007, 12:31 PM   #16
Jon [in CT]
Member#: 2992
02 WRX Sedan
http://www.enginuity.org/viewtopic.php?t=2178
Old 11-04-2007, 07:05 PM   #17
crazymikie
Member#: 56321
2006 Honda El Camino
Green
I've used the AEM Uego and the LC1 and I greatly prefer the AEM. It reads quickly and seems more robust. It's never given me a hint of trouble in nearly 20k miles...that's more than I can say about the LC1.
crazymikie is offline   Reply With Quote
Old 11-05-2007, 01:17 AM   #18
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
i spent an hour or two trying to figure out what exactly I needed for this unit. it looks like the gauge itself is $190, but then you can get a kit for 399 which looks like a gauge, sensor, and some mystery box to hook up to the PC? but then there is a full blown kit for $600. nothing made much sense to me as to how much it was going to cost me, or what exactly I needed?
Old 11-05-2007, 05:11 AM   #19
C-Rock
Member#: 135187
2007 WRX
Originally Posted by Jon [in CT] View Post
You rock
taking the plunge into subarus DocBertoldo Newbies & FAQs 7 04-08-2009 06:43 PM
Finally taking the plunge! Jakezor Car Audio, Video & Security 9 03-12-2002 11:08 AM
Taking the plunge. Forty5L New England Impreza Club Forum -- NESIC 2 12-09-2001 12:33 PM
Taking the plunge - Wagon or Sedan? pearlbluesoul Newbies & FAQs 11 11-07-2001 03:47 PM
