Old 10-26-2007, 02:46 PM   #1
shemoves
Member#: 80663
2005 STi
Default Miscellaneous Torque specs (list)
Thought it'd be nice compile it all in one place. These are the ones I could find with basic searching. Torque values are in Ft/Lbs unless otherwise stated. Please inform me of additions and/or corrections so this can be as complete and accurate as possible.
Engine:
Alternator Pulley: 47
Crank Pulley Bolt: 90-94 on NA 2.2; 130-134 on NA 2.5
Exhaust (Up pipe>header, Up pipe>turbo, turbo>downpipe/downpipe<turbo): 26
Ignition Coil/Igniter Assy: 11.7 (confirmed via 2004 Impreza service manual)
Front Cam Retainer: 7 (EJ257)
Oil Pump: 4.7 (EJ257)
Oil Drain Plug: 33
Oil Pan: 3.6
Power Steering Pump Pulley: 38
Spark Plug: 15.2 (SOHC and DOHC Impreza engines, confirmed via 2004 Impreza service manual)
Rod Bolt: 38.4 (EJ257)
Water Pump: 8.7 (EJ257)
Thermostat Housing: 4.7
Transmission/Drivetrain:
ATF drain Plug: 18.4
Flywheel: 58.2 ('02+ WRX, '02+ 2.5RS)
Clutch cover to flywheel: 11.6 ('02+ WRX, '02+ 2.5RS)
Oil Drain: Oil Pan side-32.5/Clutch housing side-51.6 (STi 6mt)
Oil Drain: 32.5 (WRX)
Rear Differential Bushing: 51.6 ('02+ WRX)
Rear Differential Drain/Fill Plugs: 36.2 ft/lbs
Rear Differential Studs (mounting bolts): 51.6
Transmission to engine: 36.9 ('02+ WRX, '02+ 2.5RS)
Suspension/Wheels:
Lug (wheel) Nuts: 66.5
Rear Sway Bar mounts: 18 (WRX)
Rear End-Links: 33
Strut top nut (holds the whole strut assembly together): 41
Front Hub Bearing (four bolts): 47.9
ABS Wheel Speed Sensor: 24.3
Front Strut Bolts (camber): 129
Front Tie Rod: 19.9
Ball Joint Through Bolt: 37
Front Ball Join Castle Nut: 19.9
Front Backing Plate to Upright: 13.0
Rear Backing Plate to Upright: 38.3
Rear Lateral Link: 103
Rear Trailing Link: 66
Rear Strut Bolts(To Upright): 145
Rear Strut Mount Tops: 14.5
Rear Strut Insert: 30
Axle Nut: 137-162? (rear possibly as high as 174)
Rear Axle Nut 140?
Brakes:
Bleed screw: 14.5 (STi)
Bracket Bolts: 59
Front Brake Caliper: 80
Brake Hose to Strut: 23.6
Brake Hose Banjo Bolt to Caliper: 13.0
Caliper: 19.5? (2002 non-turbo), 27.5? for 2002 Turbo
Front Brake Caliper: 80?
Rear Brake Caliper: 47.9?
Miscellaneous:
Fuel Tank Drain Plugs: 19.2
*Use at your own risk. I take no responsibility for things breaking, you getting hurt, or rioting by angry neighbors. While my hope is that these are as accurate as possible, I do not work for Subaru, I am not a professional machanic, and I have limited access to service manuals or tech docs. This is just a compilation of things I could find via various forms of media.
shemoves is offline   Reply With Quote
Old 10-27-2007, 02:07 AM   #2
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Add engine oil drain plug...33 ft lbs
z is offline   Reply With Quote
Old 10-27-2007, 04:18 PM   #3
shemoves
Member#: 80663
2005 STi
done, thanks
Old 10-04-2009, 10:45 PM   #4
Tom Hartz
Member#: 225284
2011 Impreza WRX
Spark Silver Metalic
66.5 ft lbs for lug nuts? Americas Tire did 80 ft lbs. 66.5 seems a little low. Is this what people are running? I looked in the owners manual and can not find the spec.
Tom
Tom Hartz is offline   Reply With Quote
Old 10-04-2009, 11:23 PM   #5
leecea
Member#: 37359
2003 WRX
Tom
That is the correct spec - surprisingly low.
For what it's worth, I use 68 ft/lbs rear (stock studs), 72 ft/lbs front (upgraded studs). I have no proof that my choice is better or worse than anyone elses.
leecea is offline   Reply With Quote
Old 10-05-2009, 12:34 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
many of these values are applicible to new hardware as installed at the factory and are a bit low for reused hardware
I usually increase some---not all....by 10-15%...exhaust system bolts are one example
and I use 70-75ft-lbs for lugnuts
Old 10-05-2009, 12:46 PM   #7
Tom Hartz
Member#: 225284
2011 Impreza WRX
Thanks for the info guys. I love this car and want to take care of it.
Tom
Old 12-02-2010, 07:16 PM   #8
lsito5revo
Member#: 248213
Tom
Thought it was 95 FLBS? even 80 seems a bit shy.
lsito5revo is offline   Reply With Quote
Old 12-02-2010, 11:26 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
Tom
and YES 65.7ft-lbs is a bit low, I think
but too many idiots think that they have to get all gorilla with lugnuts and end up ****ing all sorts of **** up
I'm surprised that some have even got 90 on them before they twist right off
IT IS JUST A 12MM STUD d0000000ds...........
Old 12-03-2010, 01:07 AM   #10
lsito5revo
Member#: 248213
Just what i was taught through out my education. maybe teach was wrong. but i torque my lugs to 95 and havnt spun one yet.
Old 12-03-2010, 01:46 AM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
guess you should question you education as suspect and wrong
too bad so much of that goes on
Old 07-19-2011, 08:27 AM   #12
paulpat
Member#: 237145
02 WRX
12 FXT
<3 thanks
paulpat is offline   Reply With Quote
Old 07-19-2011, 08:50 AM   #13
Big-E
Member#: 123843
2016 STI LTD CWP w/
blade wing from factory
Originally Posted by shemoves View Post
Brakes:
This specification is for the OEM STI Brembo front caliper, 2004-2007 (I do not know about the newer models), and yes, it is correct.
The OEM repair manual states a higher number and it is wrong so do not rely on the manual. Other reference: http://www.iwsti.com/forums/gd-braki...per-bolts.html
Old 07-19-2011, 10:30 AM   #14
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
i dont have exact number
but i just changed my oil pan and was suprised when a mechanic told me
only 8lbs for STi oil pan bolts!
any higher and fugi bond woudnt seal and the pan will leak!
AliBenn is offline   Reply With Quote
Old 07-19-2011, 11:20 AM   #15
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Spark plugs are 18.5 ft lbs to 22 ft lbs. 20 ft lbs is good if you don't want the range. Don't under torque the plugs.
See Q18: https://docs.google.com/leaf?id=0B8l...wY2Vm&hl=en_US
Bacon117 is offline   Reply With Quote
Old 07-19-2011, 03:48 PM   #16
shemoves
Member#: 80663
2005 STi
Based on what I have seen on NASIOC and Scoobymods, 15-19 seems to be the range. Anyone have a Subaru manual they can post or link to get confirmation?
Old 07-19-2011, 04:44 PM   #17
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
^Google "ken gilbert sti manual".
OrbitalEllipses is offline   Reply With Quote
Old 07-19-2011, 05:49 PM   #18
shemoves
Member#: 80663
2005 STi
Per Subaru's 2004 Impreza service manual, Spark Plug Torque on both SOHC and DOHC engines is 15.2 lbs, and the DOHC ignition coils are 11.7 lbs.
Old 07-19-2011, 10:06 PM   #19
Uncle Scotty
Member#: 16200
OK buy Nates beans
actually it is only 3.6ft-lbs per the factory manual....I use 5ft-lbs
the bolts dont really hold the pan on....they just hold the pan in place while the sealant cures
Old 07-20-2011, 09:32 AM   #20
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
That's interesting. The Subaru manual for my 2002 does say 15 ft lbs. However, NGK (the maker of the plug) recommends 18.5 - 22 ft lbs. If torque is too low, there is chance the plug could back out. It's happened at some OEM's, but I have not heard of it with Subaru.
So, let's call it 19 ft lbs so it encompasses all known information.
Old 07-20-2011, 09:51 AM   #21
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Yea, that's lower than NGK's recommendation. Not sure why. Unfortunately, Subaru does not work with NGK USA, so I cannot really ask why the torque is different.
Anyway, I recommend sticking with NGK's torque. Having too low torque is a lot worse than too high torque (don't go higher than 22 ft lbs)
Old 07-20-2011, 09:59 AM   #22
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Subaru possibly chooses the lower torque recommendation due to the aluminum heads. No sense to go higher than factory spec, as you risk stripping the threads.
fastnoypi is offline   Reply With Quote
Old 07-20-2011, 11:51 AM   #23
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
You might be right. I'm still going to stick with the 20 ft.lbs I've recommended to my customers since I started at NGK 4.5 years ago. 15 ft.lbs may be ok, but it's not what we use here, which is why it's strange.
Old 07-20-2011, 01:01 PM   #24
Uncle Scotty
Member#: 16200
OK buy Nates beans
I think subaru uses the lower torque to make it less likely to seize the plugs in the heads and have issues with removing them without removing the engine.
I have had times with broken off plugs in subaru engines and it is quite easy for n000bs to **** up the install and make things
but that's just what I think
and I DO use a torque wrench when I install plugs
Old 07-20-2011, 03:23 PM   #25
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
What's strange is that Honda has some issues with the plugs backing out, and they want to specify a torque higher than what we recommend. (It took quite a few months of testing before everyone would buy off on that one). Plus, as I've mentioned we get a lot of plugs returned that have blown up engines b/c they were too loose. The plugs couldn't transfer heat quickly enough, and overheated. You can calculate the torque used by measuring the thickness of the gasket (it crushes when you torque it), and some of them were barely crushed.
Have you tried running the engine for a while to get things hot before removing the plugs? That's the "NGK recommendation" Never had stuck plugs, so I've never had to try.
Although it goes against NGK's recommendation, I have not heard 15 ft.lbs causing issues, so I suppose it's adequate.
('93-'01) Need torque specs Patrick L Impreza Forum 4 05-15-2001 06:41 PM
('93-'01) Torque Specs? Dan00RS Impreza Forum 4 05-10-2001 08:24 AM
('93-'01) Need torque spec pronto Patrick Olsen Impreza Forum 2 05-07-2001 12:36 AM
('93-'01) torque spec on exhaust manifold nuts? nils Impreza Forum 1 04-23-2001 06:11 PM
Torque specs for pulley? JGard Normally Aspirated Powertrain 9 04-12-2001 10:01 AM
