Old 10-26-2007, 05:10 PM   #1
Lethality
Member#: 162770
Exclamation Cylinders 3 and 4 not firing...HELP!!
I have just swapped a 2002 Impreza Outback Sport EJ22 into a 1999 Legacy Brighton I used all the wiring harnesses from the Legacy and the manifold, throttle body, and all the sensors from the Legacy. But I still have the exact same problem I am not getting any spark to 3 and 4, and my ECU is throwing out codes about the camshaft and Circuit A, but I pulled the timing cover and it's timing is perfect. Did you ever find the reason for this?? Please HELP!
Thank You
Lethality
Lethality is offline   Reply With Quote
Old 10-26-2007, 11:10 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Thank You
Lethality
No, I didn't ever find the reason for this. Then again, I didn't realize I was supposed to be looking.
Old 10-26-2007, 11:13 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
[color=#ff0000]I have just swapped a 2002 Impreza Outback Sport EJ22 into a 1999 Legacy Brighton I used all the wiring harnesses from the Legacy and the manifold, throttle body, and all the sensors from the Legacy. But I still have the exact same problem I am not getting any spark to 3 and 4, and my ECU is throwing out codes about the camshaft and Circuit A, but I pulled the timing cover and it's timing is perfect.
What problem did you have before that led you to swap out the engine?
Are both engines DOHC or SOHC?
Do both engines have the same cam timing pickups on the cam sprocket? On my DOHC EJ25, the cam sensor is on the driver side intake cam and if I pull off the intake cam sprocket I can see the metal triggers on the back of it.
What are the specific codes? I don't know what a "code about the camshaft" is or what "Circuit A" refers to.
Old 10-29-2007, 01:08 PM   #4
bry593
Member#: 161594
1972 Datsun 240Z V8
Can-am White
sounds like the coilpack for 3&4. start there and work your way backward. if 1&2 are firing, it has nothing to do with your timing belt, cam or crank sensor. furthermore, it has nothing to do with the igniter as it's on/off switch. sounds like coil pack. check the grounds.
bry593 is offline   Reply With Quote
Old 10-29-2007, 01:23 PM   #5
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
check the wire harness first as some wrx's have misfires because of the wire harness at the coilpack. twist the connectors slightly then see what happens.
Old 10-29-2007, 01:51 PM   #6
deadlydave
Member#: 131119
1996 Impreza LWRXSTI
91 BMW 318is
Um...you either have the wrong engine, or the wrong year in your original post.
In 2002 the OBS only came with the 2.5 Litre engine.
deadlydave is offline   Reply With Quote
Old 10-29-2007, 02:29 PM   #7
MYfirst00
Member#: 22928
2011 Outback 3.6R
Gray
^ My thoughts exactly.
MYfirst00 is offline   Reply With Quote
Need Help Cylinders 3 And 4 Missfire joshua olean Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-20-2008 06:36 PM
Cylinders 3 and 4 not firing...HELP!! Lethality Alaskan Impreza Club Forum -- AKIC 0 10-26-2007 05:09 PM
Cylinders 3 and 4 not firing...HELP!! Lethality Engine Management & Tuning 0 10-26-2007 05:07 PM
Cylinders 3 and 4 not firing...HELP!! Lethality Newbies & FAQs 0 10-26-2007 05:01 PM
