Old 10-27-2007, 02:12 PM   #1
lennyTR
Member#: 142379
2007 WRX TR
Satin White Pearl
Default Bad idea to drive to shop on un-tuned parts?
I have an '07 TR. I would like to get my car tuned at Agile Auto, but it's like 7 hours away from where I live.
I am fully capable of installing my new turbo, STi TMIC, Downpipe, and fuel pump at my house.
Is it a big deal to make a long drive on these parts being un-tuned?
If I stay out of boost, would my motor be fine?
Reason I'm asking is because I'll save $$$ money installing the parts myself.
Let me know what you think. Thanks.
lennyTR is offline   Reply With Quote
Old 10-27-2007, 02:54 PM   #2
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
What type of EM are you using..........Get a break in map from your tuner for the ride up there.
JMK508 is offline   Reply With Quote
Old 10-27-2007, 03:10 PM   #3
lennyTR
Member#: 142379
2007 WRX TR
Satin White Pearl
I'll be using a Cobb Accessport.
Old 10-27-2007, 03:16 PM   #4
timeless
Member#: 46316
30R STI 440 whp/wtq
Prodrive gc010e 18x9.5+25
maybe ur tuner can send u a temp map...i drove my new turbo setup untuned to my tuner but then again it was a 40 minute drive.
timeless is offline   Reply With Quote
Old 10-27-2007, 03:42 PM   #5
jdmdave
Member#: 116197
06 sti obp
sqc # 177 , lisc # 32
what turbo are u using?
jdmdave is offline   Reply With Quote
Old 10-27-2007, 06:45 PM   #6
muffnbluff
Member#: 94415
2005 STi
As long as you're not installing bigger injectors or a 70mm intake you should be fine if you stay out of boost.
muffnbluff is offline   Reply With Quote
Old 10-27-2007, 06:49 PM   #7
wuuusaa
Member#: 92894
2015 Wrx
but how likely is that going to be?
good luck
Old 10-27-2007, 06:58 PM   #8
Freon
Member#: 88322
2009 BMW 135i
You can load the Cobb stage 2 map and connect a boost line straight from the turbo compressor to wastegate, then block the line that goes to the solenoid so it won't leak air out of the intake. If you have stock injectors and stock size intake you should be able to drive the car ok. If you have a big diameter intake or new injectors, you probably shouldn't drive the car without at least some minimal immediate fi
Freon is offline   Reply With Quote
Old 10-27-2007, 08:01 PM   #9
lennyTR
Member#: 142379
2007 WRX TR
Satin White Pearl
When I go to get tuned, exact modifications will be:
SPT intake
VF22
STi TMIC
ERZ downpipe
SPT Cat-back
Walbro 255 fuel pump
Old 10-27-2007, 08:24 PM   #10
CynicX
Member#: 48199
06 WRX
If you have an AP Hill at Agile shouldnt have a problem with sending you a temp map.
If not you can look into your opensource options to just get a map that you dont have to worry about blowing anything up.
I would say stay out of boost but I've made that trip up i-95 many of times and it would be impossible without getting killed to stay out of boost. I guess you could always disconnect the bcs run at wastegate pressure and baby it. Leave at night to minimize traffic but you will run into traffic around Richmond, DC and Baltimore no matter what time you drive.
You could also have Agile install the turbo and I think they charge 300-400 for a turbo install. Which sounds like a lot but if you are running a temp (crap) map you'll probably spend an extra 100 in 93 octane on the trip lol.....
I got a tuning date at Agile coming up on the 9th of Nov. Maybe I'll see you up there, but probably not
CynicX is offline   Reply With Quote
Old 10-27-2007, 08:49 PM   #11
lennyTR
Member#: 142379
2007 WRX TR
Satin White Pearl
so maybe I should just install the downpipe and call it quits and let Hill do the rest...?
Old 10-27-2007, 09:03 PM   #12
muffnbluff
Member#: 94415
2005 STi
good luck
I drove almost 5 hours from St. Louis to Chicago staying below 5psi when I went to get tuned at P&L. It's not THAT hard.
Old 10-27-2007, 09:05 PM   #13
hector
Scooby Scammer- Do Not Buy From User
Member#: 132902
2006 wrx tr silver
99 BMW 323is
man just pop out your restrictor pill and baby the car there. I have done that like 5 times lol as long as you stay out of boost and you dont have larger injectors your car will be ok.
hector is offline   Reply With Quote
Old 10-28-2007, 10:40 AM   #14
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Staying out of boost is the best choice, but how hard is that to do??? so hard I parked mine after I installed my SZ55. I loaded the COBB Econo Map very limited boost and even under WOT won't fully engage the turbo 100%. If your tuner can toss a map your way thats the way I would go. I have 2 weeks before I can get in for tune with SEMA coming up this week in Vegas many of the tuners will be gone.
+1 for driving 5 hours to P&L
4ST-AIR is offline   Reply With Quote
Old 10-28-2007, 05:52 PM   #15
Got Boost?
Member#: 113096
06 sti
how about you install everything but the injectors and baby the car. Install the injectors when you get there..... just a thought in case you can't get a base map
Got Boost? is offline   Reply With Quote
Old 10-28-2007, 06:31 PM   #16
wuuusaa
Member#: 92894
2015 Wrx
not hard but very tempting, but he if doesn't want to replace a motor he'll do the right thing
very good idea imo
Old 10-28-2007, 06:42 PM   #17
muffnbluff
Member#: 94415
2005 STi
very good idea imo
Well, just like banging that prostitute without a condom is TEMPTING, but any logical human being with an ounce of restraint would slap that rubber on.
Old 10-28-2007, 06:51 PM   #18
wuuusaa
Member#: 92894
2015 Wrx
nice comparsion
If you were willing to drive 800 miles for a tune... kc jazz Engine Management & Tuning 7 03-02-2010 11:12 PM
Installing Super16g, then having to drive to get tuned..what to do? forsaken Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 01-28-2006 04:14 PM
A few parts for sale...Locals only please! Im willing to drive to deliver also! Ceyvme NWIC Private Classifieds 7 01-13-2006 11:05 AM
probably a bad idea, but a thought "graphite on axles"? -=C=- Off-Topic 6 09-14-2005 03:03 PM
anyone want to drive to cobb tuning with me saturday? jmott Texas Impreza Club Forum -- TXIC 5 11-09-2001 10:52 AM
