Welcome to the North American Subaru Impreza Owners Club Thursday April 2, 2015
Old 10-28-2007, 08:37 PM   #1
teh POD
Member#: 90195
Default Revealed: Ferrari FXX Evoluzione
http://www.autoblog.com/2007/10/28/r...xx-evoluzione/
Originally Posted by Autoblog
Following earlier reports, Ferrari unveiled a new, modified version of the super-Enzo during this past weekend's Ferrari World Finals at its Mugello race track in Italy. As the name suggests, FXX Evoluzione is a further evolution of the FXX program that places "client test drivers" (i.e. obscenely wealthy Ferrari aficionados playing Schumacher) behind the wheel of developmental test beds to try out new equipment for Ferrari. In fact, Schumacher himself was reportedly on hand to unveil the car, having sporadically participated in the program over the past two years.
The FXX Evoluzione picks up where the "ordinary" FXX program left off, extending the program by an additional two years, based on an even more radical version of the track-only machine. With 35,000 kilometers worth of telemetry from the 20 cars, engineers compiled a series of tweaks to sharpen the car's capabilities. Output is boosted to a staggering 860 HP, redline is up to a shrieking 9,500 rpm, and shift times are down to a lightning-fast 60 milliseconds. The traction control system has been modified to be less invasive, more adaptable and can be adjusted in-cockpit on the fly between nine distinct settings from corner to corner. Suspension geometry has been modified, as has the aerodynamic package, which, along with fresh livery, accounts for a slightly different appearance compared to the previous version.
The result of all these and a few other small modifications (which you can read about in detail in the press release after the jump) means that the FXX Evoluzione can now lap the company's private Fiorano test track two seconds faster than its predecessor at 1 min 16 sec. The kit can be retrofitted to any of the 20 FXXs that took place in the program until now, and includes participation in a renewed program that will take these most extreme machines to two events each in North America, Europe and Asia (for a total of eight track events) each year over the next two years. Money may not be able to buy you happiness, but it can buy you a seat as a Ferrari test driver, which sounds like happiness to us.
[Source: Ferrari]
PRESS RELEASE:
FXX programme extended for further two years thanks to new evolution kit developed with assistance of Client Test-Drivers
Maranello 28th October 2007 - The innovative FXX programme, based on the eponymous prototype car and launched by Ferrari in June 2005, is being extended to 2008/2009. The FXX, which is the most advanced GT ever created at Maranello, has been updated with an evolution package aimed at further improving its handling and performance. The package was developed as a result of Ferrari's collaboration with its Client Test Drivers and with the invaluable support of Michael Schumacher. The FXXs equipped with this package will also sport a new livery in addition to new rear wing profiles.
The FXX is not homologated for road use and there are no plans to compete with it either. In fact, the FXX prototype is designed exclusively for track driving as part of a specific R&D programme agreed with a selected group of just over 20 clients involving 14 group test sessions and 14 private ones in the last two years. Thanks to readings taken over the 16,500 kilometres of tests carried out in 2006 and the 18,500 kilometres covered in 2007, the modifications made to the car have focused on honing its aerodynamics, running gear and electronics. Seven-times Formula 1 World Champion Michael Schumacher also joined the ranks of the client test drivers and gave the programme the benefit of his vast experience on several occasions.
Maranello's engineers studied the wealth of information gained to develop a kit which will cut the FXX's Fiorano lap time to under 1'16'' (previously it was 1'18''). The FXX's 6262 cc V12 engine can now punch out a massive 860 hp at 9500 rpm. Gearshifting takes just 60 ms, a drop of 20 ms on the previous time, and the gear ratios have been adapted to make use of the extra 1000 rpm now delivered by the engine.
The car's new traction control system, developed in close collaboration with the GES Racing Division engineers, gives the driver a choice of no less than nine different settings (plus the off position) which are selected using a switch on the central tunnel. This means that the driver really can modify the car's behaviour on the track from corner to corner, just as the Formula 1 drivers do to maximise performance and reduce tyre wear. The FXX's traction control is also now less invasive and more flexible, adapting more efficiently to the individual driving style of each driver - a requirement pinpointed when this very extreme car was being driven on the track by non-professional drivers.
The FXX's special 19" Bridgestone tyres now last longer too thanks to a new car setup and new front suspension geometry, while the Brembo brakes, which boast large Composite Ceramic Material (CCM) discs, are more efficient with the result that the brake pads last twice as long. Thanks to the drivers' feedback the Ferrari engineers have also developed new aerodynamic solutions aimed at increasing downforce over the rear axle. The FXX now sports a new rear diffuser, nolder and rear flaps which have combined to increase aerodynamic efficiency by 25% overall. The active front spoiler control system settings have been adjusted to take these modifications into account too. New telemetry monitoring of the steering angle and brake pump pressure will further boost the interaction between Client test drivers and the company's engineers also. From next year onwards, it will be possible for drivers to have two extra video cameras mounted on their car in addition the existing rear-facing one. This will, of course, give the drivers excellent rear visibility without having to impinge in any way on the car's aerodynamics.
The FXX evolution package includes participation in a series of track events that Ferrari is organising at international circuits for 2008/2009. Six events are planned for each year (two in North America, two in Europe and two in Asia). In addition to these, the FXXs will also be participating, as per tradition, in the prestigious end-of-season Ferrari World Finals.
As happened in 2006/2007, the cars will be backed up at each event by a 15-member official team made up of engineers, electronics experts and mechanics capable of providing complete assistance to clients. Needless to say, the latter will still be able to organise their own private individual track sessions in their car as well.
teh POD is offline   Reply With Quote
Old 10-28-2007, 08:39 PM   #2
teh POD
Member#: 90195
Old 10-28-2007, 09:12 PM   #3
Ghosthound
Member#: 110979
2010 FJ Cruiser
1999 Miata
hmm... i would not mind seeing that every time i opened my garage door... then again, it wouldnt be my first pick if money was no option either.
Ghosthound is offline   Reply With Quote
Old 10-28-2007, 09:17 PM   #4
ptclaus98
Member#: 87888
1988 Toyota Supra
Boredom Personified
Yeah, that's SO much better than any SUV.
ptclaus98 is offline   Reply With Quote
Old 10-28-2007, 09:35 PM   #5
tdm74
Member#: 65464
god damn these
electric sex pants
I wonder what it is like to be uber-rich?
tdm74 is offline   Reply With Quote
Old 10-29-2007, 12:22 AM   #6
MER
Member#: 38723
I can see those video camera "mirrors" making it into production; big "ooh ahh" factor, little expense (these days), and lots of additional possibilities for designers (no exterior mirrors, no field of vision considerations). Wonder if they're legal.
MER is offline   Reply With Quote
Old 10-29-2007, 12:25 AM   #7
kaptainkevlar
Member#: 80109
07 spec B
9500 rpm and over 800 na hp out of a 6.3 liter v12? yes please. id love to hear that thing screaming around a track, the "normal" fxx sounded like a beast, i can only imagine what another grand on the tach sounds like. going along with all the speculation about ferrari going with a smaller motor in their new supercar, would it be too crazy to imagine them having a motor in a street car that revs to over 10k? i think not
kaptainkevlar is online now   Reply With Quote
Old 10-29-2007, 12:27 AM   #8
choloman05
Member#: 99359
02 wagon
blackish-blue
geez.
choloman05 is offline   Reply With Quote
Old 10-29-2007, 12:50 AM   #9
importdriver
Member#: 96927
Just another supercar...
importdriver is offline   Reply With Quote
Old 10-29-2007, 03:39 AM   #10
scottjua
Member#: 2937
2002 WRX Wagon WRB
2006 STi Aspen White
man... I'd love to have access to one for even five minutes on the track
scottjua is offline   Reply With Quote
Old 10-29-2007, 09:06 AM   #11
registering
Member#: 89332
2007 Miata
So would I but I'd probably crash it in about 2 or stall the engine.
registering is offline   Reply With Quote
Old 10-29-2007, 12:48 PM   #12
imprezaL2345
Member#: 108188
1993 Impreza L 1.8T
Lotus Storm Titanium
no. a Lamborghini is just another supercar. this is a masterpiece.
imprezaL2345 is offline   Reply With Quote
Old 10-29-2007, 01:34 PM   #13
Yoo Shin
Member#: 87327
2010 12 parsec Evo X
I still kill threads
Still ugly.
Yoo Shin is offline   Reply With Quote
Old 10-29-2007, 03:15 PM   #14
ptclaus98
Member#: 87888
1988 Toyota Supra
Boredom Personified
Originally Posted by Yoo Shin View Post
Still ugly.
It's a couple of notches down from an LMGT1. Who gives a **** what it looks like.
Old 10-29-2007, 06:38 PM   #15
Optimus Prime
Member#: 69847
2010 Evolution X
Still ugly.
Says the Impreza driver.
Optimus Prime is offline   Reply With Quote
Old 06-03-2014, 05:23 PM   #16
torquemada
Member#: 128484
2006 EDM WRX STI
Old 06-03-2014, 05:43 PM   #17
carlos.danger
Member#: 363268
2015 WRX STi
dear god....
carlos.danger is online now   Reply With Quote
Old 06-03-2014, 05:48 PM   #18
69subaru360
Member#: 159682
1995 WRX
1998 2.5 RS
Not bad. I still would prefer an F40.
Old 06-03-2014, 07:10 PM   #19
Lrn2Corner
Member#: 246224
2012 WRX Sedan
12 Rav4 V6
That engine sounds just beautiful.
Lrn2Corner is offline   Reply With Quote
Old 06-03-2014, 08:03 PM   #20
OrbitalEllipses
Member#: 178811
2013 Why don't you
just GFY?
I had ~2-3 seconds when it started to fiddle with the volume because I didn't hear anything. Then it turned on and I yelled out loud "oh ****!" because I was so startled.
Story of the day sponsored by Mastercard.
OrbitalEllipses is offline   Reply With Quote
Old 06-03-2014, 11:52 PM   #21
delongedoug
Member#: 124113
and beyond!
So from what I gather from Wiki, these are the same original 30 FXXs, just enhanced over the years using the name Evoluzione. What caught my attention was the driving to be honest. Whoever is behind the wheel is quite competent. Far from the generalization I would make of someone who rents a $3million car to track every so often.
delongedoug is offline   Reply With Quote
Old 06-04-2014, 07:09 AM   #22
SCRAPPYDO
Member#: 873
2013 F150 King Ranch
Datsun 71 240Z & 68 2000
Nope, ugly is right... and useless.
SCRAPPYDO is offline   Reply With Quote
Old 06-04-2014, 01:25 PM   #23
sotti
Member#: 33474
04 M3
Imola Red
Not useless, they are brilliant.
Ferrari got someone else to pay for their R&D cars. I'm sure they are getting gobs of data off these cars that is trickling it's way into real production car. Any company that get it's customers to fully foot the bill for product testing gets a tip of the hat from me.
sotti is offline   Reply With Quote
Old 06-04-2014, 02:08 PM   #24
spazegun2213
Member#: 91208
the 05 Sti-zzle
+1 there... not to mention the sound...
spazegun2213 is offline   Reply With Quote
Old 06-04-2014, 04:34 PM   #25
SCRAPPYDO
Member#: 873
Never said it was useless for Ferrari.
Ferrari Fxx STIkiller Off-Topic 29 07-28-2009 11:21 PM
Ferrari FXX P-TownWRX Motorsports 45 12-07-2006 10:22 PM
A ferrari FXX on a track i sweden sti_driver@swe Member's Car Gallery 40 10-06-2006 08:46 PM
Ferrari FXX video trev0006 Off-Topic 0 03-06-2006 03:21 AM
Forget the Ferrari FXX.... SilverBoosted Off-Topic 56 02-08-2006 05:33 PM
