Old 10-28-2007, 10:15 PM   #1
shemoves
Member#: 80663
2005 STi
Default '05 WRX slave cylinder work with '92 SS Master Cylinder?
I am in the process of putting an '05 WRX transmission into a '92 SS. We ran into a snag where we can't bolt the Legacy's slave cylinder up. The stock Legacy trans has holes to bolt/mount the slave cylinder to it, and the WRX trans does not. So, I need to get an '04 or '05 WRX Slave Cylinder. That being said, I am wondering if the new slave cylinder will work with the old master cylinder.
C/N: '05 WRX Slave Cylinder compatible with '92 SS Master Cylinder?
shemoves is offline   Reply With Quote
Old 10-29-2007, 02:41 AM   #2
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
it SHOULD work. It's not like the clutch system is that complicated on either car, that it would require some vastly different parts/design. As long as the hose connects between the two, it should function fine.
janikphoto is offline   Reply With Quote
Will my WRX master cylinder work with sti brembos or a BBK? WRX-17 Brakes, Steering & Suspension 71 02-10-2015 05:29 PM
WTB: '04/'05 WRX slave cylinder and/or master cylinder shemoves Private 'Wanted' Classifieds 2 11-01-2007 12:04 PM
WTB: 06 WRX pull-type clutch, pressure plate, fork, master cylinder, 3.7 FD rear diff gling Private 'Wanted' Classifieds 0 06-07-2007 05:54 PM
'02 WRX Struts/Spring work with '05 FXT mounts?? e28fixer Brakes, Steering & Suspension 1 09-12-2006 09:59 PM
Single Stage Brake Booster with ABS-ready Master Cylinder vrg3 Private 'For Sale' Classifieds 9 05-19-2004 12:29 AM
