Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 10-29-2007, 01:10 AM   #1
Member#: 155145
2004 WRX STI
Default Airbag Computer Reset Question
I have two airbag ECUs for an 2004 STI. (both tested on the same car)
On the first I have fault codes:
55 41 42 11 62 65
On the second I have fault codes:
22 11 62 61 12 15
I have replaced the airbags and pretensioners.
Ive tried to reset the codes on each by grounding pin #2 on the diagnostic harness according to the shop manual, but the error codes remain. Im using the fault code reset procedure (Called 'Clear Memory Mode' on page AB-26) Has anyone been able to reset the codes before?
Also, there is a green male and matching female connector next to the SRS diagnostic harness. Can someone tell me what it is for?
pilotstephen is offline   Reply With Quote
Old 10-29-2007, 07:37 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
...leave the green connectors unplugged---they are for ECU diagnostic mode ONLY and NOT to be connected for normal operation.
I would say that either someone f000ked with the SRS wiring and screwed ya on the other.....and/or....airbag controllers are a ONE TIME USE unit and are garbage and can NOT be 're-set' after any airbag deployment of any kind and must be replaced with a NEW unit.
Old 10-29-2007, 08:09 AM   #3
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Scotty is correct, once the module records a deployment it must be replaced. Deployment codes can't be reset.
Computer resetting itself??? Stroke Off-Topic 21 08-24-2006 12:50 PM
Computer reset BMXspears Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 01-31-2006 05:59 PM
something wrong with your computer? reset it. alacrity024 Off-Topic 13 04-08-2005 04:45 PM
Zex nitrous computer reset Kevin Thomas Normally Aspirated Powertrain 2 04-16-2002 02:47 AM
Challenge: CEL/computer reset "button" couldnthinkaone Normally Aspirated Powertrain 14 03-21-2002 04:04 PM
