Old 10-29-2007, 10:11 AM   #1
PolarisSnT
Member#: 85905
2004 WRX
Default Why its a good idea to wrap your headers
Dont know if this has been shown before but here is a boost plot from my car with my Synic Equal length headers pre-wrap and post-wrap. This was made using UTI's Log analyzer. Green line is with the wrap, its making more boost becasue it was cooler out that night than the pre-wrap night.
PolarisSnT is online now   Reply With Quote
Old 10-29-2007, 01:18 PM   #2
wrxhard
Member#: 108091
Very nice. I'm surprised something this simple hasn't been done before. Bravo!!
wrxhard is offline   Reply With Quote
Old 10-29-2007, 01:47 PM   #3
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Cool, so, unless I'm reading it wrong, you're boosting ~500 (give or take depending on the RPM's) RPM sooner? Saweet.
bushflyr is offline   Reply With Quote
Old 10-29-2007, 01:53 PM   #4
sharkmonkey
Member#: 118566
2005 WRX
What's the ambient temperature difference? I wouldn't trust the data until I knew that.
sharkmonkey is offline   Reply With Quote
Old 10-29-2007, 02:12 PM   #5
Magnum626
Member#: 62856
MBP SQC#197
Stockpiling parts...
Would the cooler temp also shift the graph to the left a little? Or just affect top boost?
Magnum626 is offline   Reply With Quote
Old 10-29-2007, 02:27 PM   #6
nimaxpro
Member#: 46318
isn't:
colder air=denser air?
denser air=more power?
Looks like exactly what that graph shows. More boost at all RPMs. Due to lower intake temperatures.
nimaxpro is offline   Reply With Quote
Old 10-29-2007, 02:30 PM   #7
noahrexion
Member#: 107048
07 Civic Si Sedan
GG
I don't get it....
Are you trying to show the difference that a wrapped header makes? You are comparing two different nights with different temps and obviously much different boost plots.
noahrexion is offline   Reply With Quote
Old 10-29-2007, 02:37 PM   #8
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Yes, but look at the top of the plot from 4700 to 6000. There's only about 1psi difference. Throughout the rest of the plot the difference is 2.5 to 5psi or so. While it may not be completely scientific (eg. identical temp, baro, and humidity) to me, at least, it's a good indicaton that he's making boost significantly sooner when wrapped.
Old 10-29-2007, 02:49 PM   #9
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
too many variables.. but im sure the header wrap is helping regardless
PaulRex is offline   Reply With Quote
Old 10-29-2007, 05:23 PM   #10
Mitsu
Member#: 93557
2002 STid wagon-SOLD
it defiantly helps. just by keeping engine bay temps way down and keeping the EGTs slightly higher too the turbo, which equals better spool. I have wrapped headers/uppipe and would never not wrap a set.
Mitsu is offline   Reply With Quote
Old 10-29-2007, 06:06 PM   #11
rbcsaver
Member#: 78039
02 WRX
WRX Blue
This is NOT a new concept and many have done it on any vehicle or engine use (ie generators). The documented down side: potential corrosion of your headers by retaining moisture, salts, etc. Spilled oil will also soak in to the wrap. The best, more effective option, although more expensive is to have them ceramic coated, at which time you can also port and polish.
regards,
Steve
rbcsaver is offline   Reply With Quote
Old 10-29-2007, 10:09 PM   #12
PolarisSnT
Member#: 85905
2004 WRX
Dont think I mentioned this was using an MBC
Yes its not scientific but it is a good indication of how the car is spooling. No matter how cold it gets, its not going to account for a ~500rpm difference in spool up.
Intake temperature(speed density/blow through) on the cooler night was 46 degrees vs 57 from the warmer night. I had recently added a GM solenoid to my setup to take advantage of Ride5000's hybrid method of controlling boost and Im realizing now that some of the tubing I had to use was of different sizes and that may have affected the boost. I test drove it after the install and I had to adjust my boost back down becasue it was >25psi after this install of the solenoid.
Regardless, you can see how the spool is dramatically improved.
regards,
Steve
Coating is better in terms of keeping the lifespan of your parts to a maximum. However, I am going to have to say that wrapping is a more effective way of retaining heat inside the pipes.
Case: Races XS on this board has a coated perrin header and recently went to a track day where he melted part of the plastic on his motor.
I can touch the headers on my car after a run and not get burned, if I try and get near my coated uppipe, I will almost certainly get burned.
I know its not new, but I have not seen documented proof that header wrap decreases lag, so I figured Id add it.
Old 10-30-2007, 02:43 AM   #13
Magnum626
Member#: 62856
MBP SQC#197
Thanks for the graph either way.
As far as the wrapping goes, wouldn't coating it also help preven the degredation of the metal once it's wrapped?
Old 10-30-2007, 07:46 AM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...after having seen failed power steering lines and oil leaks on these cars that have sprayed the exhaust.....I would say that header wrap soaked in either of these would make a most spectacular, and inextinguishable, fire
....coated pipes would be far less prone to this sort of conflagration
Old 10-30-2007, 08:38 AM   #15
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I'm sorry, because you're just a dude trying to share/show something, but you're wrong.
jblaine is offline   Reply With Quote
To wrap or not to wrap borla header?? scoobysnack69 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 08-08-2006 05:04 PM
Bad idea to wrap entire exhaust? StiPete Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 05-26-2006 10:09 AM
Why its not good to be 16 and have a WRX 2.5 SUBY General Community 178 06-11-2005 05:46 AM
is it still a good idea to get a clearbra even if you have scratches on your car? Supaboom Interior & Exterior Modification 11 06-06-2004 10:49 AM
EBC's and boost tapering, its a good idea but do they all do it? Turbo Tin Can Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-14-2002 02:19 PM
