Old 10-29-2007, 03:11 PM   #1
97obw
Member#: 109426
97 OUTBACK
mud brown
Default balancing w/ weights on the inside?
since the weights on the outside of the rim look horrible, would there be any problem with putting them on the insides of the wheel?
97obw is offline   Reply With Quote
Old 10-29-2007, 04:05 PM   #2
mossie4
Member#: 83997
2008 STI
Smile
Most of the shops I work with here don't even think about putting the weights on the outside of the rim (unless it is a stock rim) My assumption is that there are certain cases where they must to get a good balance.
mossie4 is offline   Reply With Quote
Old 10-29-2007, 04:11 PM   #3
Crawdads
Member#: 30907
SWP GDB-G
They should be able to balance the wheel using stick on weights that go inside the hoop of the wheel instead of crimp on weights that go on the outer lip...inboard and outboard placement does not yield the same balance. A good machine will tell the operator if the weight should go inboard or outboard to correct vibrations.
Crawdads is offline   Reply With Quote
Old 10-29-2007, 04:29 PM   #4
97obw
Member#: 109426
97 OUTBACK
mud brown
hmm, just got the outback done with all the weights on the indside, discount tire said "no prob".....
oem wheel weights on the inside? subzero_Legacy_Gt Vancouver Impreza Club Forum -- VIC 6 02-18-2008 01:59 PM
oem wheel weights on the inside? subzero_Legacy_Gt Tire & Wheel 4 02-17-2008 07:56 AM
Does wheel weight on the dyno affect the tune? theabyss85 Newbies & FAQs 7 11-06-2007 02:19 PM
Factory headlights on WRX all have a coat of haze on the inside? hilfiger4you Interior & Exterior Modification 5 08-17-2005 05:26 PM
Problem w/ asking to balance w/ weights on "inside" of BBS's jsavage Tire & Wheel 6 10-25-2004 06:15 PM
