Old 01-20-2002, 02:59 PM   #1
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Question My car is running BETTER with the CE light on..!!??(kinda long)
Hi all,
Could someone possibily shed some light on this situation.
A little history first. Back in december i had my CE light come on, so i took it in (to a dealership) and they plugged it in and the code led them to a minor exhaust leak just before the muffler, i mean right were the muff clamps onto the pipe. Now this is a cat back i had made up out of 2.25" pipe and a simple universal SS DTM muffler. They told me that i would have to put the car back to stock for them to do anything.......I guess they couldn't see that just 1.5' away there were 2 HUGE holes in the muffler (Twin 3" tips )
So i'm really just trying to outline the some of the grap i've gotten from dealerships about this.....bear with me, please.
Ok, i've been driving around threw the holidays with the CE light on, i know not good, but here's the thing.
THE CAR RUNS BETTER WITH THE CE LIGHT ON........?????????
Just 2 days ago, i reset the ECU after installing some stereo equipement (more on that in the stereo forum soon) After the reset the car was running like crap, major hesitation from 4k to ~4800 rpm (MY99 hesitation issue)
I decide to re-pad the knock sensor like i have done in the past. So i made some new pads out of an old bike innertube and proceded to instal them under the KS and re-reset the ECU....
Well it STILL RAN LIKE CRAP.......so i'm gettin quite pissed by now...the CE light stays off for a few driving cycles (peroids of running engine) and it comes BACK ON......
The STRANGEST part of all this is that just AS SOON as the CE light comes on, the hesitation goes away, the part throttle roughness goes away.....the CAR RUND GREAT WITH THE CE LIGHT ON......????!!!!!
I'm pulling my hair out here. I'm going this week to get the CE light issue fixed, but could someone help me understand this sick and twisted phonomon.............??
Thanks very much,
Peas,
AaRoN
Old 01-21-2002, 01:27 PM   #2
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Come on now...........59 peeps looking at this and not a single reply.................?????????????????
Peas,
AaRoN
Old 01-21-2002, 03:56 PM   #3
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Wierd. I have no advice for you, just figured I would answer since you want something in here! Have you tried putting the stock cat-back back on and seeing what happens? I have no idea, never heard of anything like this before.
HondaH8er is offline   Reply With Quote
Old 01-21-2002, 04:40 PM   #4
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
Maybe think of it this way,
Everytime you reset the ecu, it begins it's learning cycle.
At just about the point where it figures out it's base map.... it also figures out that something is wrong with the engine. Voila. At that point, you simultaneously get a better running engine and a CEL.
Yeah, this idea is far-fetched... but it may have some basis in reality (yes I understand that the ecu doesn't go from stupid to smart just like that, but you get the jist....)
--Roy
LUME is offline   Reply With Quote
Old 01-21-2002, 04:51 PM   #5
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
Don't quote me on this, but I was under the impression that when the CE light is on, the car usually runs richer than normal (I could be wrong, though). Could it be that with the particular exhaust set up you have, that when the CE light isn't on, the car may be running lean, and having the CE light on kinda richens things up to the point where it drives better? Maybe I'm way off base here, but maybe not . . . who knows?
Jason
2.5GT is offline   Reply With Quote
Old 01-21-2002, 05:45 PM   #6
jhonas
Member#: 9015
2002 Impreza 2.5RS
Platinum Silver Metallic
Another idea...
When your cel isn't on, and you're leaking some exaust from the holes in your muffler (causing some wierd flow issues throughout the piping maybe), your oxygen sensor may be getting wierd readings and sending them to your ecu, causing it to alter your fuel delivery or whatever and in return, it runs as you described.
Then, when your ecu figures out theres something wrong with the exaust, it bypasses the input from the oxygen sensor and runs on some default setting causing it to run fine (because it isn't getting erroneous readings from the oxygen sensor).
Crazy idea, probably, but it's a possibility. Try plugging the holes in your exaust and resetting the ecu and see if that does anything. Or as someone said, put your stock exaust back on and see if it does the same thing.
jhonas is offline   Reply With Quote
Old 01-21-2002, 10:24 PM   #7
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
jhonas,
the "holes" i mentioned are the tips themselves. The "leak" is very minor and is were the stainless muffler clamps to the regular pipe....
Thanks for the input though....
Peas,
AaRoN
Old 01-21-2002, 11:56 PM   #8
DustinR
Member#: 8264
2001 Impreza 2.5 RS
95 Impreza 1.8 Coupe
sorry to hear that your still having problems with it!! That really stinks.
DustinR is offline   Reply With Quote
Old 01-22-2002, 07:54 AM   #9
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
No, the engine should be running off of normal maps (and the 02 sensor) even when the CEL is on.
Old 01-22-2002, 09:59 PM   #10
foolio
Member#: 9351
2006 trailblazer SS
black
I had a problem with my fuel injectors and my can ran better with the CEL on also. i found out that when the ECU sences a problem or problems it trys to correct it. Some problems are possible for it to correct, some airnt. But if i were you i would take it back to a dealer and have him hook up the select monitor, get the code again and try to figure out the problem from there.
J
foolio is offline   Reply With Quote
Old 01-23-2002, 12:48 AM   #11
Wheels
Member#: 5410
2008 BMW 335XI
If I was you I`d trade it in. I've no need for it now I have my two impreza's. Just take it to Albany and get a WRX in return.
You will get 8,875 on a trade in against a WRX at invoice (23,200)
Leaving you 14,500 to finance which will be 250 over 4.5 years (plus what eva you owe if you do), So better do it now before your no longer employed.
Oh yeah
Peas
Wheels is offline   Reply With Quote
My car is running like poop from my butt Strider Tri-State Area Forum 9 10-13-2002 11:54 PM
anyone here got the CE light on their WRX? jacklock New England Impreza Club Forum -- NESIC 1 05-07-2001 08:26 AM
can i leave my car for a week with the e-bake on?? Keith General Forum Archive 15 08-11-2000 10:33 PM
the ITC deal with the CE light Donnie Mid West Subaru Owners Club Forum -- MWSOC 1 06-04-2000 08:40 AM
