Old 10-29-2007, 09:21 PM   #1
TVA
Member#: 16464
Chapter/Region: HIIC
2008 Audi
Bad decision
Default EJ20G Problem. Please help ASAP
I have an interesting EJ20G problem that I was hoping someone might be able to help me resolve. When starting the car on a cold start it generally starts fine. Once it warms up if you try and turn it off and turn it back on it will just crank until the battery dies and not start. It smells like gas and seems as though the car has flooded itself out. When warm if you try and start the car with you foot on the gas all the way to the floor it will usually start.
It has been throwing a CEL, blinking code 42 which is "Unusual voltage from the idle switch" The problem has been getting progressively worse and now has been having a hard time with cold starts as well. Hopefully someone has an answer or a suggestion. Also, could someone show me a picture of the idle switch on an EJ20G? I'm not sure of the location or what it looks like. Thanks for your help guys.
TVA is offline   Reply With Quote
Old 10-30-2007, 12:53 PM   #2
Arctic Assassian
Member#: 91875
91 legacy TD04
04 WRB/carbon fibre STI
My 93 impreza used to do this. I can't offer any usefull advice.
Arctic Assassian is offline   Reply With Quote
Old 10-30-2007, 01:21 PM   #3
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Sounds like your IAC is ether now wired up properly or is broken. Check for Voltage going in, as well as Voltage coming out going to the ECU. Also make sure that the ground is hooked up properly.
Kirill
RallySport Direct is offline   Reply With Quote
Old 11-01-2007, 01:47 AM   #4
TVA
Member#: 16464
2008 Audi
Bad decision
Little update, attempted cleaning the TPS sensor with electrical parts cleaner and the problem, along with the CEL, disappeared for about a day. Shortly thereafter the CEL came back and it started not wanting to catch at all, just cranking. I've found that if I disconnect the TPS sensor and the harness for the 5th injector and crank the car with the gas pedal on the floor it will start reliably. The TPS sensor is going to be replaced with a USDM 2.2L Legacy Turbo sensor later this week and we'll see how that works.
Old 11-02-2007, 11:58 AM   #5
mikolaj
Member#: 160591
1999 RSti
I had the same problem on mine. It is $10 sensor, the cam timing sensor I believe it's called. Well i'll double check that name, but i think it's right
gl
mikolaj is offline   Reply With Quote
Old 11-02-2007, 03:00 PM   #6
96WRX
Member#: 30610
1996 WRX STi Type R
555 Blue
This sounds like a problem that I had with my EJ20G conversion (minus the CEL code), I found that it was the cam and/or crank angle sensors. I was told this is a common problem with all Subaru EJ engines. I have changed mine and the problem went away.
96WRX is offline   Reply With Quote
Old 11-03-2007, 02:43 AM   #7
TVA
Member#: 16464
2008 Audi
Bad decision
Installed the new TPS sensor, no more code thrown and the idle is behaving more as it should. Starting problem still occurred occasionally so I pulled both the crank angle sensor and the cam position sensor and cleaned them with electronic parts cleaner. Both had a slight build up of black soot. So far the starting issue seems to have gone away and all is well. More updates to come.
Old 11-05-2007, 11:30 PM   #8
Oldbluelegacy
Member#: 107482
Had a similar problem , it was my coolant temp sensor
Kris
Oldbluelegacy is offline   Reply With Quote
Need help ASAP with smoking engine problem! PLEASE HELP! DJS_02_WRX Newbies & FAQs 14 10-10-2009 09:59 AM
Serious problem please help asap JEEENKINNNS Normally Aspirated Powertrain 19 11-24-2007 10:09 PM
turbo problem speculations... please help ASAP bxracer69 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 04-18-2005 07:18 AM
Uppipe Install Problems. Please help ASAP! KevinWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-28-2003 10:19 PM
New problem, need help ASAP please.. legacyej22 Normally Aspirated Powertrain 1 10-24-2002 02:01 AM
