Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 10-30-2007, 01:13 AM   #1
04Silverex
Member#: 77322
2011 WRX
SSM
Default Is it ok to put on one new tire?
So driving on a local LA freeway, my tire blew and my strut bent. So the question i have is, Is it ok to buy one new tire or do i have to buy two new front or buy all four
Thanks for the help
04Silverex is offline   Reply With Quote
Old 10-30-2007, 02:16 AM   #2
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Apparently all wheel drive cars need to have very similar diameters on all four wheels or else there is danger to your differentials. Depending on the age of your existing tires, you will want to have your single new tire shaved to match their as worn size. Or perhaps you should just replace all four, depending on their mileage/age.
specialev is offline   Reply With Quote
Old 10-30-2007, 02:29 AM   #3
niblick
Member#: 151390
Not only do you need similar diameters, you need all 4 of the same tires. For example, you can't have 2 225/45/18 Michelin's and 2 225/45/18 Pirelli's. However, if you have over, I believe, 7/32nds of tread on the other three, you should be able to replace just the one you blew out.
niblick is offline   Reply With Quote
Old 10-30-2007, 09:29 AM   #4
NW OBS
Member#: 101361
05 OBS
Obsidian Pearl Black
Exclamation
Myth Buster: If you blow one tire you do NOT need to buy all four NEW tires. Measure your depth of your existing tires (they should NEVER have a larger diameter difference then 1/8" between ANY tire ~ use a sewing soft measure tape to measure this).
When you have your average tread depth (use a tread depth gauge ~ any good tire shop will have one ~ or the Tire Rack will send you one) call the Tire Rack and have the new tire (same brand/model and size) 'shaved' to match the existing rubber. It will cost you an extra $25 ~ but save you from buying 4 new tires. Pass it on!
NW OBS is offline   Reply With Quote
Old 10-30-2007, 09:33 AM   #5
Phatzilla18
Member#: 86475
Chapter/Region: HIIC
2001 Impreza 2.5RS
STM
Originally Posted by NW OBS View Post
Myth Buster: If you blow one tire you do NOT need to buy all four NEW tires. Measure your depth of your existing tires (they should NEVER be a larger diameter difference ~ use sewing soft measure tape ~ then 1/8" between ANY tire).
When you have your average tread depth, call the Tire Rack and have the new tire (same brand/model and size) 'shaved' to match the existing rubber. It will cost you an extra $25 ~ but save you from buying 4 new tires. Pass it on!
+1, good advice
Don't run different tire brands (as the actual rolling diameter is different even between tires of the same size) and don't run 3 bald tires with one new.
Phatzilla18 is offline   Reply With Quote
Old 10-30-2007, 10:11 AM   #6
04Silverex
Member#: 77322
2011 WRX
SSM
thanks for all the responses.
Old 10-30-2007, 10:54 AM   #7
Howl
Member#: 57830
1/8" diameter gives you 3/8".
Subaru.com recommends all tires be within 1/4" circumference, which is about 5/64" diameter. circumference.
http://www.subaru.com/common/faq/tech_info.jsp#4
Howl is offline   Reply With Quote
Old 10-30-2007, 09:56 PM   #8
NW OBS
Member#: 101361
05 OBS
Oooops! OK, I think it was like 5:30 AM when I posted that ^^^ The rest is spot on... and most people DON'T know shaving is an option!
Old 10-30-2007, 10:53 PM   #9
04Silverex
Member#: 77322
2011 WRX
SSM
I asked the tire shop to shave the tread and they looked at me like i had smoked some crack
Old 10-31-2007, 01:19 AM   #10
NW OBS
Member#: 101361
05 OBS
Exclamation
Did you read my read my post???? THE TIRE RACK! They shaved my tires for years when I was racing ~ 888-541-1777
Old 10-31-2007, 03:53 PM   #11
smurfwrx
Member#: 151928
09 Triumph S3
^^^ great graphics
smurfwrx is offline   Reply With Quote
Is it OK to put the stock downpipe back on to get inspected? breathinez Newbies & FAQs 6 12-14-2006 02:01 PM
Is it OK to put PRELOAD on Tein Flex Coilovers? ProdriveRex Brakes, Steering & Suspension 29 07-25-2006 04:34 PM
Is it time to put on the summer tires? darkmist2k1 Tri-State Area Forum 38 03-14-2006 03:31 AM
Is it ok to put on a new rotor with halfway worn pads? waitandbleed92 Brakes, Steering & Suspension 1 01-14-2004 04:40 AM
is it ok to put MBC on AT WRX? Kopid Interior & Exterior Modification 10 04-10-2003 04:11 PM
