Welcome to the North American Subaru Impreza Owners Club Saturday April 18, 2015
Old 10-30-2007, 04:35 PM   #1
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
Default Preferred Packages are the easiest way to outfit your vehicle for winter -- the ideal
Preferred Packages are the easiest way to outfit your vehicle for winter -- the ideal winter solution!
Our fitment specialists select a winter tire that best meets the performance level of your vehicle and add an affordable wheel option. Shipped to you mounted, balanced and with all the installation hardware you'll need, your Preferred Package is easy to bolt right on.
Take a look at The Tire Rack's Preferred Winter Tire & Wheel Package for the 2007 Subaru Impreza WRX Sedan:
The Tire Rack Perferred package
Preferred Packages are available for other Subarus as well. Or, you can build your own by selecting from the various tire and wheel (both steel and alloy) options that we have.
Read more about or build your own Winter Tire & Wheel Package here:
Old 11-01-2007, 12:05 PM   #2
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
ttt
Old 11-01-2007, 12:11 PM   #3
Rippen Griffen
Member#: 91708
AD Motorsports FTW
06 OBP - Cobb AP Stg 2
Do 15" wheels clear the OEM 4-pots?
Rippen Griffen is offline   Reply With Quote
Old 11-01-2007, 12:32 PM   #4
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
Depends on the wheel. There are some 15" rims that will clear the brakes.
khail19 is offline   Reply With Quote
What's the easiest way to check your O2 sensor? BGPunk2001 Off-Topic 44 07-24-2009 02:56 PM
What's the easiest way to search for your own posts? thehalogod Off-Topic 25 05-12-2008 08:30 PM
Preferred Packages are the easiest way to outfit your vehicle for winter Luke@tirerack Tire & Wheel 0 10-12-2006 04:19 PM
What is the best way to store your wheels/tires for the winter? Bankie Tire & Wheel 3 11-13-2005 10:30 PM
The easiest way to break up with your girl stryfewrx Off-Topic 10 06-24-2005 03:02 AM
