Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > 1993 - 2001 Impreza Specific Parts
Old 10-30-2007, 04:36 PM   #1
Aphex28
Member Sales Rating: (40)
Member#: 11506
2015 WRX
Default FS: MA - RS Turbo Kit - Everything you need but EM!
This is pretty much a complete turbo kit for a 2000-01 RS and can work for 98 & 99's as well if you figure out a recirc line for the bov.
The kit includes
Already clocked WRX TD04
Custom Rotated mount DP, Yes you can say you have a clocked and rotated mount td04 Divorced wastegate & exhaust wrapped.
Custom Up-pipe w/ EWG attachment & exhaust wrap.
HKS 40mm External Wastegate with dump tube set to about 5.5psi.
Charge pipe
Polished WRX intercooler w/ stock Y pipe. 1 Mounting bracket & red coupler. Coupler and ic are already trimmed to fit RS intake manifold.
XS Power Bov or Stock Recirc BPV, which ever your perfer.
Custom short ram intake w/ K&N Filter
Oil feed & Return lines. (Feed comes from oil galley plug on top of block & returns to oil pan)
Tapped oil pan
I did a Throttle body coolant bypass and used those to feed and return coolant to the turbo
Modded WRX Blue Injectors(didnt get them flow tested but they are either 800 or 850s) I was at about 35% IDC.
Rallitek O-ring adaptor kit.
04 STi Fuel Pump
Custom crush bent catless mid pipe. Comes with rear o2 sensor with electronic CEL fix on it. I didn't get any p0420 codes or any cat codes for that matter!
This pipe makes it BOLT ON! This bolts to any RS style cat-back exhaust so use the exhaust that is on your car now!
This kit made my car a torque monster, insta boost and was decently quick.
I will also include some breather filters for your valve cover vents.
You will NEED engine management with this!!!!
I used an emanage ultimate and it worked alright for a piggback. Turbo your car for under $2k!
I can try to answer your questions and give you guidance to the best of my knowledge!
I can also help you install if you are local.
Videos are here:
http://www.youtube.com/watch?v=u2ez6YnRQ-g
http://www.youtube.com/watch?v=eBMqf9xFiHQ
This shows the volume ,how fast it spools and how loud the intake & EWG are.
http://www.youtube.com/watch?v=9KrU_9NuolA
I am asking $1000 shipped OBO.
More pics here:
http://smg.photobucket.com/albums/v...hex28/turbokit/
Injectors not pictured
Located in Waltham, MA
Check out my other stuff for sale!
http://smg.photobucket.com/albums/v...hex28/For Sale/
Aphex28 is offline   Reply With Quote
Old 10-30-2007, 10:54 PM   #2
SilverSubie2.5
Member Sales Rating: (14)
Member#: 136144
2010 STi
Hm. What kind of numbers were you running with this setup?
SilverSubie2.5 is offline   Reply With Quote
Old 10-31-2007, 07:29 PM   #3
Aphex28
Member#: 11506
2015 WRX
Never put it on a dyno... but tuned right I've seen similar setups do 170-210whp
Old 11-02-2007, 03:57 AM   #4
Subey03
Member Sales Rating: (36)
Member#: 159909
2004 STI on AIR
Subey03 is offline   Reply With Quote
Old 11-03-2007, 02:12 AM   #5
Aphex28
Member#: 11506
2015 WRX
Originally Posted by Subey03 View Post
Hehe well... I've gotten that story about 3 times now I've been selling this since February.
So first to pay gets it... I actually just posted it on Ebay so it's going within a week no matter what
Old 11-06-2007, 12:01 AM   #6
rs4buddy
Member Sales Rating: (19)
Member#: 56959
1998 2.5RS
BRILLIANT RED Hybrid
bolts onto the stock exhaust manifold?
rs4buddy is offline   Reply With Quote
FS: MA - RS Turbo Kit/v5 DCCD Cluster/VF39/TB/ECU/Autometer/HKS/CBE/ej251 Aphex28 NESIC Private Classifieds 28 03-30-2012 03:29 PM
FS: MA - RS Custom TD04 Turbo kit everything you need but EM Aphex28 Engine/Power/Exhaust 11 09-15-2007 12:03 PM
The Element GT52 Bolt on Turbo kit,everything you need to Bolt it right on!! CHEAP! THE-95-STi Tri-State Area Private Classifieds 19 05-11-2007 12:48 AM
The Element GT52 Bolt on Turbo kit,everything you need to Bolt it right on!! CHEAP! THE-95-STi MAIC Private Classifieds 27 05-11-2007 12:46 AM
The Element GT52 Bolt on Turbo kit,everything you need to Bolt it right on!! CHEAP! THE-95-STi Engine/Power/Exhaust 25 05-07-2007 09:45 PM
