Old 10-30-2007, 06:17 PM   #1
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
Default Got a used tranny to put in...
Any great words of wisdom before I begin? Got the used tranny for $650 (with clutch, drive axles, rear diff, starter, flywheel). All I need to do is swap the tranny though(plus fix the leaking oil seperator behind the flywheel).
Easiest/quickest way to get it done?
Speedwagon is offline   Reply With Quote
Old 10-30-2007, 06:40 PM   #2
mattwalters
Member#: 422
1998 Legacy 2.5GT
Rio Red
If you can get the car up in the air a bit and have access to a tranny jack, drop the old unit / install the new unit from underneath. Otherwise pull the engine and tranny as a unit, separate, install new, reinstall as a unit.
Good luck!
-Matt
mattwalters is offline   Reply With Quote
Old 10-31-2007, 12:13 AM   #3
Speedwagon
Member#: 19681
Green
I planned to jack the car up, and drop the trans. Seems way more difficult to pull the engine(as I've done that before).
Anything else? Is it adviseable to remove the front hubs to get the drive axles out?
Old 10-31-2007, 12:25 PM   #4
96legacy28
Member#: 140158
1996 Legacy
Green
i just got done doing my clutch/rear main seal a whole bunch of stuff......the "oil seperator" is i belive your rear main seal your talking about....i just pulled the engine and tranny in one day by myself.....not too hard to work on/do
96legacy28 is offline   Reply With Quote
Old 10-31-2007, 03:03 PM   #5
Speedwagon
Member#: 19681
Green
According to the parts people, it's an oil seperator, not the rear main seal. It's currently a cheap piece of plastic, on the right (as you look at the rear of the engine) of the crankshaft.
Best OEM gears to put in an 02 WRX tranny. Cstmboxermotorsports Transmission (AT/MT) & Driveline 3 06-05-2008 06:04 PM
Need Help, car won't start after RA tranny was put in tmann Transmission (AT/MT) & Driveline 16 12-27-2006 06:25 AM
Want to put in a car pc can i use my laptop?? 2002bugeye Car Audio, Video & Security 22 12-09-2005 10:22 PM
Pulling out, loud clank, hard to put in gear... tranny?? kschmohl Mid Atlantic Impreza Club -- MAIC 11 08-15-2004 04:17 PM
Just got my plates... debating to put on front or not Andrman Mid West Subaru Owners Club Forum -- MWSOC 16 06-25-2004 06:06 PM
