South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 10-30-2007, 08:53 PM   #1
subietumbler
Member#: 109121
2002 Impreza WRX
WRB-world rally blue
Default power loss
Just curious if anyone else has had a problem when accelerating past 4000 rpms if your car starts to act like it red lined. Everytime when I am accelerating past 4000 rpms my car feels like its hit a govenor and just bucks like crazy, then I shift to a higher gear and its fine until I hit 4000 rpms. I feels like if you were to unhook a hose or line going to the intercooler or something, not sure, I am totally lost any help would be greatly appreciated
subietumbler is offline   Reply With Quote
Old 10-30-2007, 09:05 PM   #2
gormonk
Member#: 98960
1978 brat (fo realz)
red
possible overboost
gormonk is offline   Reply With Quote
Old 10-30-2007, 09:06 PM   #3
M.Ehle
Member#: 62391
2006 Legacy Spec.B
TSM 98/500
Subaru Stars
No, That's not right at all. Once all the service guys see this thread they'll want to know what year, model and of course, what mods you have. List 'em now for their benefit. If you're still under warranty then just get it to one of our dealerships, N S E or W, just get it in. Good Luck Sir.
M.Ehle is offline   Reply With Quote
Old 10-30-2007, 09:07 PM   #4
subietumbler
Member#: 109121
2002 Impreza WRX
is it possible to over boost on a stock turbo?
Old 10-30-2007, 09:22 PM   #5
M.Ehle
Member#: 62391
2006 Legacy Spec.B
TSM 98/500
Possible, but still not right.
Old 10-30-2007, 11:24 PM   #6
gormonk
Member#: 98960
red
uhhh..... dude ive had this problem myself. AND i'm a tech.
but thats why i said "possible" overboost
Old 10-30-2007, 11:25 PM   #7
subietumbler
Member#: 109121
2002 Impreza WRX
Well the car is an 02 wrx, not to many mods, just AER intake, GFB blow off valve, cat back exhaust, fidanza short throw shifter, tein lowering springs. The only thing that I can think of that would have any effect would be either the blow off valve tubing but thats all connected and no leaks, the other would be the mass air flow sensor might be failing but how would i check that aside from buying one and praying that it is it.
Old 10-30-2007, 11:28 PM   #8
gormonk
Member#: 98960
red
what codes is it throwing if any?
Old 10-31-2007, 12:05 AM   #9
dubya05
Member#: 91319
2005 05wrbWRX...SOLD
gas sucker yukon
Anyone remember AZRALLY"S car doing this? Turbo inlet may have a tear in it...
dubya05 is offline   Reply With Quote
Old 10-31-2007, 12:21 AM   #10
02WRX06STI
Member#: 115023
2006 STI
my dad's 02 is doing this same thing it is in stock form just has AP running stage 1 OTS map, and once he hits 14 lbs of boost, he get a sudden loss of power
02WRX06STI is offline   Reply With Quote
Old 10-31-2007, 04:36 AM   #11
Poweredbysnail
Member#: 74753
2003 Wrx 2.5Lw/gt30r
Team Snail
Yes yes blackfalcons car was do it too
Poweredbysnail is offline   Reply With Quote
Old 10-31-2007, 10:26 AM   #12
racingfish
Member#: 60976
1969 LGT
FATURBO
is it making any unusual noises under boost?
racingfish is offline   Reply With Quote
Old 10-31-2007, 11:06 AM   #13
gormonk
Member#: 98960
red
usually you can hear that once the car goes into boost
Old 11-01-2007, 09:52 AM   #14
subietumbler
Member#: 109121
2002 Impreza WRX
no unusual noises at all, not throwing any codes just the power loss/sputering at 4000 rpms, I will check the inlet hose to the turbo and see if that may be it.
Old 11-01-2007, 10:49 AM   #15
dubya05
Member#: 91319
gas sucker yukon
I drove the car and didn't hear anything.
Old 11-01-2007, 11:32 AM   #16
gormonk
Member#: 98960
red
check all your IC connectoins and your bpv as well. sounds to me like theres a possible boost leak somewhere
Old 11-01-2007, 02:29 PM   #17
stimobetta
Member#: 110287
Well if it feels like your hittin the govnor, its prolly overboostin.
stimobetta is offline   Reply With Quote
Old 11-01-2007, 04:07 PM   #18
subieyacht
Member#: 84087
98 Legacy GT
over boost will damn near shut the car down wont it? btw, do you have boost controller?
edit: if you are over boosting, You should have a C.E.L. as well
subieyacht is offline   Reply With Quote
Old 11-01-2007, 04:36 PM   #19
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Will it buck like crazy when you go over 4k no matter how much throttle? Be hard to overboost when only give it 30% throttle.
Have any check engine lights? Did you buy the car modded? I would see if you have any codes that are turned off. Good ol fashioned reset after that and see if you have the problem, if it doesnt come back right away then maybe you need tuned. You should be fine with those mods on an 02 tho. Do you have a stock intake? I would try that and see if you still have the problem. I have an extra if you need to borrow it. Do a boost leak test and see what comes up.
Where do you live? I can hook up my laptop and see wtf is going on. It wont be until Monday because I am going out of town today.
Smoby is offline   Reply With Quote
Old 11-01-2007, 04:39 PM   #20
Black-Falcon
Member#: 106318
16 Cadirrack
ATS-V
Yeah but mine didn't hit anything that felt like redline. Mine would just uncontrollably detonate at 3200 RPM, then be fine after that.
Black-Falcon is offline   Reply With Quote
Old 11-01-2007, 10:25 PM   #21
desmo750
Member#: 111256
1992 Legacy Turbo
don't call me white...
Take off your rad intake and revert to your stock air box.
desmo750 is offline   Reply With Quote
Old 11-01-2007, 10:30 PM   #22
whiteout06
Member#: 138375
2006 WRX, stage 2
aspen white
haha then why cant you figure it out there MR. TECH
whiteout06 is offline   Reply With Quote
Old 11-02-2007, 12:03 AM   #23
boosted20
Member#: 79576
Maybe yer MAF has oil on it if you have an intake. But that wouldn't explain why it is fine until 4k. sounds like a boost control issue or a leak. probably a leak. yah der.
boosted20 is offline   Reply With Quote
Old 11-02-2007, 12:47 AM   #24
Kdub
Member#: 129501
1996 Eclipse GSX
Red
could be a major boost leak or you could be running wayyyyy lean. when my fpr went to **** i couldnt pass 4k because i was running so lean. check that and vacuum lines too.
Kdub is offline   Reply With Quote
Old 11-02-2007, 01:54 PM   #25
SaabaruMike
Member#: 113342
2014 WRX
This is most likely something related to the MAF (bad MAF due to oiled filter or leak somewhere after), but I had this exact same issue on my old Porsche 924S and it turned out to be a loose ground cable bolt. I had a similar problem on my GN and it was also related to bad grounding. Just check your battery cables and ground connections. A good test is to take a set of jumper cables, connect one end to your negative battery terminal, and the other to the motor or the frame. Tuck it so you can close the hood and go for a drive. If the problem changes to a higher RPM or disappears, uoi found your issue.
SaabaruMike is offline   Reply With Quote
Power Loss? Need Advice. BrysImpreza Normally Aspirated Powertrain 18 06-02-2001 11:36 AM
Power Loss Rayman Newbies & FAQs 2 04-21-2001 09:37 PM
Power loss in 3rd gear Jazz95 Newbies & FAQs 4 04-10-2001 06:59 AM
Power loss due to ignition kill Stavros g Technical Forum Archive 2 07-05-2000 03:24 PM
low end power loss... solutions: (tec2 ?) alastair Technical Forum Archive 8 07-03-2000 10:49 AM
