Old 10-31-2007, 12:30 AM   #1
rebizap
Member#: 79402
'05 STi
Default maf scaling and ecu definitions
I need to rescale my maf.
Using a lm-1 wbo2 and and will be using enginunity for the changes.
USDM 2005 sti
Im running rich right now.
Idle 13.9-14.2
Redline in 4th 10.1
Im looking to lean out
So when rescaling will i need to change anything else (any other tables) other than my maf sensor scaling table?
Also there is a new ecu definition on scoobypedia for my year and model.
Should i use that for my adjustments and then flash that to my ecu?
Or use the copy taken from my ecu?
What is the difference?
This is what i pulled off my ecu---A2BJB10J,AJ930
This is (?new?) one from scoobypedia--- A2BJB11J.AJ931
rebizap is offline   Reply With Quote
Old 10-31-2007, 02:50 AM   #2
MasterKwan
Member#: 98961
2003 WRX
13.9-14.2 at idle suggests you're not in closed loop. I'm curious why you're messing with the MAF and not a fueling table. How do you decide to do one or the other? I was under the impression you only had to jerk with the MAF when something changed with the MAF like a different intake.
With my WRX, I installed the newest stock subaru rom and I'm been modding with it as a baseline. I didn't see any difference in the tables though I didn't check them all.
Old 10-31-2007, 03:31 AM   #3
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
Might want to look at the Open loop fueling delay tables as well. I know for 02-03 you can zero the one table we have which can make OL/CL switching alot faster, but for the 05 I'm not sure.
I know there are long posts about all these topics on the Enginuity forums. Might want to do a few searches over there. I'll give it a look myself.
/Brox
Broxma is offline   Reply With Quote
MAF Scaling and LESS power? PSSSHHH Open Source Reflashes 2 04-25-2010 03:14 PM
stage 2, adding cai, change MAF scaling and what else? harryson Open Source Reflashes 7 12-19-2009 03:14 PM
Knocking on throttle down and lift after MAF scaling Fongers Open Source Reflashes 2 01-04-2009 06:17 PM
Injector and MAF Scaling xolosis UTEC 3 10-07-2006 05:06 AM
a/f learning and maf scaling deluxsti Engine Management & Tuning 2 06-06-2005 04:22 PM
